Low disc space on drive c.
Computer backed up on to my c drive.
I have duplicate files on drive c.
How do i get my computer to recognise duplicate files and folders, and or to remove back up.
Computer is very slow.
no slang please- not very computer literate.
Thanks
  • Chris
    Chris May 11, 2010
    What brand of computer and model# do you have?
    In my computer, how many drives do you have, what letters, what names?
    Is this a backup you made or a factory backup?
  • 477 Answers
SOURCE: C: Drive space issue
Hello
if you have to little space on your C partition you can resize it, if you using vista.
1. right click on my computer->manage
2. choose storage->disk management
3. right click on the C volume and extend volume
4. put more space on C and then OK. that should solv your problem
you can also move your swap file to D: that gonna save some space on C.
1. rightclick on computer ->properties
2. click advanced system settings
3. click on the advanced tab settings on performance.
4. choose advanced tab->change
5. click on D: and write a custom size(it should be double of your amount of ram)
6. click set
7. then click C in same window and choose "no paging file"
8. click set and ok, then restart your computer.
good luck dont forget to vote.
Posted on Sep 08, 2008
  • 159 Answers
SOURCE: low virtual memory
Virtual memory means you're running out of memory, so it's using your hard drive storage as memory. This is slow. This is an indication you: Have too little memory and need to run fewer programs or install more memory; and also increase the size of your virtual memory, which will also make your disk space tighter. If you are really pinching the computer that badly, you may want to consider buying a new laptop altogether -- the prices have come down a -lot- just in the 2 1/2 years since you bought that. Anyway, to work around the immediate problem:
Your Gateway came with Windows XP Home Edition. Click Start: Control Panels. See if you can find the Performance control panel, possibly by switching to "Classic view." In there, look for the memory tab. Find the virtual memory section. It may be set to "Let Windows decide." change it to at least 1000mb.
You can get a bigger hard drive (after buying an external case to move stuff over) and upgrade your memory to as much as 1.25gb; but you may find those purchases to not be sensible relative to the price of a new laptop. Memory is cheap and relatively easy; the hard drive is more difficult and will set you back at least $100 if you do it yourself.
Posted on Dec 05, 2008
  • 5 Answers
SOURCE: "Recovery" folder in my D: drive taking up space. I can't access it.
That is your recovery partition. If you were to run system restore or I beleive on that paticular computer if you were to hit f10 when the system is booting it would also run the system restore. This will restore the computer back to the way it was originally from the factory. You dont want to lose or erase that partition or the only way to reformat would be with an OS disk and you might have to go hunting for drivers.
Posted on Apr 13, 2009
benwabnick
  • 2404 Answers
SOURCE: Acer Aspire 3610 - "C" drive full -- FAT32 error - HELP
Sounds like either you have corrupt system files or viruses that are not allowing the operating system to run properly.
when you first turn on the laptop hold down the ALT key and keep pressing F10, if it works then this will take you into the factory restore partition and you can bring your system back to factory defaults like it just came out of the box.
if that method doesn't work then If you have the cd's to your laptop you'll need to restore your laptop back to factory defaults doing it this way.
Posted on Jul 04, 2009
  • 37 Answers
SOURCE: I have a toshiba satellite L30 11D. The CD drive
Before you go puling it apart, check in device manager to see if it appears, if it does and still isn't recognised try downloading CDgone, right click on the downloaded file and choose Extract All, then double-click on cdgone.reg Say "Yes" to the merge question and then reboot. See if the drives have returned. You may have to re-install CD burning applications, since they're the ones that tinker with the filter setting in the registry that caused the drives to disappear. Good luck
Posted on Aug 02, 2009
Recieve error message that computer is running low on memory
Hi liciasol,
I see that you system is running low on memory, This can be that you have files in the Hard Drive that almost reach your Hard Drive maximum capacity.
to check you concern we will need to find out what files you have first in your Machine.
  • Check to see if you have programs that you have installed on the machine that you do no use anymore and uninstall it.
  • If there are no files on the machine that need to be remove and you Hard Drive space it taken up by something then we can try and free space from you Hard Drive by doing a Disc Cleanup on your system.
  • To do a Disc Cleanup, click on Start then All Programs, click on Accessories, under Accessories click on System tools then click on Disc Cleanup.
  • A screen should pop up asking you to select a drive letter that you want Disc Cleanup to free space on select the drive letter where windows is installed normally that should be Local Disc C:
  • Once you've selected the drive to free up space on you will see a window Disc Cleanup for (C:) and in the list will be system services or files to delete that take up space on your Hard Drive on the right of each will be Increments of disc space being consumed by each put a check on them except for those that have 0 on it then click on next or OK then a box should pop up Disc Cleanup asking you if you are sure that you want to do Disc Cleanup just click on YES it will start doing Disc Cleanup on your system.
  • If this did not correct fix your concern then I assume the you possibly have Windows Vista on you system.
  • We can try decrease the space the Shadowstorage of VISTA system restore from your machine this is known to take up disc space on the Hard Drive.
  • To perform the said procedure above follow steps below .
  • Click on Start then All Programs, Accessories, right click on Command Prompt and select run as administrator.
  • The Command Prompt window will appear, a black screen with a blinking cursor.
  • Once in the Command Prompt type in vssadmin resize shadowstorage /on=c: /for=c: /maxsize 1gb then press enter once you should get confirmation that the Shadow storage has been resized.
After Resizing the Shadowstorage type exit then enter this will close the Command Prompt window.
Restart your Computer then check your Hard Disc space again to see if any of the disc space has been recovered or free'd on your Hard Drive.
Note: also check if there are backed up files that possible you may have created that you have not burned on a dvd yet, and uninstall unnecessary documents and files from the machine or back up any pictures and videos that you may have on the machine.
I hope that this will be of help regarding you concern, have a nice day.
mvincentc
Apr 13, 2011 | Dell Vostro 1720 (bqcwd1z) PC Notebook
I have installed an extra 1G memory but it has not
Open "My Computer".
Right-mouse-click on the 'C:' drive.
Click 'Properties'.
A pie-chart will display, showing how much disk-space is "used"
and how much is "available".
Probably, the "available" pie-slice is less than 5% of the whole pie.
What Windows did was to "expand" the "paging" file, making it 1GB larger than it was before you added the RAM. So, the amount of "used" space on your C: drive is now 1GB _more_ than before.
So, burn some CD/DVD disks with some of your files,
and then delete the files, after checking that the disks are readable, to make more "free" space on your 'C:' drive.
Jan 09, 2010 | Acer Aspire 5315 Notebook
Why does my laptop show low disc space?
Hello
The low disc space message refers to the amount of free disc space on your c drive. The c drive is the drive on which your windows is installed, thus yu need to delete some games or not neccesary files to free up some space on your drive. Hope this can help you.
Kind regards
Andrea
Nov 13, 2009 | Compaq Presario Notebook
How to resolve low c drive space
Try restarting your computer. If you don't restart every so often, the cache memory in your computer, which holds temporary files, can run out of space. You can also go into your system tools under accessories in the start menu and use the disk cleanup to get rid of unnecessary and temporary files, or defragment your drive to rearrange files so the computer maximizes available space.
Sep 07, 2009 | Neoware Systems e140 Thin Client - Thin...
Low disc space cant upload pictures or anything i delted lots of files but still low disc space .zero space please i need help asap.
Just moving things to the trash or deleted files does not clear them from the disk drive.
Try empty trash or remove deleted files.
Jul 13, 2009 | Computers & Internet
Hp Pavilion a1620n, XP Edition. I Can't defrag my recovery drive.
Unfortunately you will need to do exactly what it states, which is free up some space. Defragging a drive requires there to be an ample amount of "swap space" available so that it can move files into that 15% of space while it rearragnes the placement of other files and puts them back in an order which will provide faster access to the files after the defrag is complete. being that it is your D: drive, can't you just move some files to your C: drive to make enough space for the defrag??
Please be sure to rate this solution.
Regards,
Joe
May 08, 2009 | HP Pavilion a1620n (RC655AA) PC Desktop
Low disk space and I did clear files.
Low disc space really means nothing, but low disc space.
I understand you have cleared your files, but your going to have to remove more....if you have excessive music, pictures, and videos...try backing them up to a DVD or flash drive, then deleting them off of the computer.
If you cannot seem to clear anymore space the next thing to do would be purchasing an external hard drive. This way you can save files on that drive while not adding anymore to the current drive. You can view some external hard drives here
Apr 23, 2009 | Computers & Internet
Duplicator freezes at 88%, or 98% when burnign and so discs are incomplete
check the amount of free space you have on your computer,if it too low this might be the cause of the problem, plus you might want to run defrag command
Apr 18, 2017 | ASUS Computers & Internet
Very low disc space
In order for your laptop to properly operate you should keep at least 10% of your hard disk drive free, as this space is needed for your computer to properly operate. Move some of your current files to the external hard drive and remove them from the mail drive, then defraf drive and you should have smooth sailing.
Mar 02, 2008 | Computers & Internet
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
