Question about Honeywell VS820A1088 PowerPile Millivolt Gas Valve NEW
Pilot light not being lit - Honeywell VS820A1088 PowerPile Millivolt Gas Valve NEW
    Sergeant:
  • 406 Answers
Might have clogged orifice in the ignitor assembly a quick check would be to remove the pilot line depress gas valve if u hear or smell gas it's the orifice remove and clear obstruction
Posted on Jan 04, 2014
The pilot light will only stay lit when you hold the pilot reset button in, as soon as you let the button out the pilot light goes out and the actual burners never come on. Any ideas?
Gas line is clogged if your pilot lite goes out - They got rid of pilot stoves because the pilot was always lit and using gas.
And without a lit pilot no way you can get the burner to ignite unless you use a match, assuming you have gas going to the burner!
Nov 08, 2015 | Heating & Cooling
I changed the thermo coupler and the pilot light does stay lit but the burners won't light
If you are referring to a gas fireplace:
  • Make sure the pilot knob is turned from "pilot" to "ON" or it will never run.
  • If the pilot knob is "ON", and the pilot is lit, but the burner won't light, it could be a bad Thermopile. The thermopile is the other safety mechanism in the pilot assembly that controls the burner.
Dec 19, 2012 | Heating & Cooling
I want to light the pilot but do not know how what is the red button for and do you turn on the gas to light pilot?
nope - don't turn on gas at the Range's front control panel to light the pilot lite.
but you do need to turn on the gas to the kitchen range at the plumbers black pipe valve to the Range.
To light the pilot light:
(1) depress the red button (that feeds the gas to the pilot light orifice)
(2) using lighter/match/lit rolled-up newspaper, etc, light the tiny amount of gas coming from orifice
(3) continue to hold dow red button for 1 or 1.5 minutes (this allows heat to bend the bi-metal contact)
(4) after 1-1.5 minutes with a lit pilot light, release the red button - the pilot should remain lit
(5) you're done lighting the pilot lite - turn on the oven (or broiler).
Dec 27, 2010 | Kitchen Ranges
I have a readyheater model 65-85 the flame will not stay lit im thinking thermal couple is there a way to test this part? or could it be another problem?
If your pilot light will not stay lit when you release pilot light button then chances are that your thermocouple is bad. Make sure that the tip of thermocouple is directly in line with pilot light. Tip of thermocouple should be cherry red if it is properly placed. If pilot will not stay lit then replace it. If you aren't sure about placement of thermocouple you can heat thermocouple with a seperate heat source. If you do this and pilot light stays lit then reposition thermocouple in pilot flame. If it still won't keep pilot burning then replace thermocouple. Hope this helps. Thanks.
Nov 19, 2010 | Reddy Heater-30-55,000 BTU Variable
Im calling for heat from the thermastat and control panel, the boiler light and and the fan is running, but no matter how many times i keep re trying the pilot and burner will not commence, is there...
I would check to make sure control on gas valve is in on position and pilot is lit if you have a standing pilot. If you have a spark or hot surface ignitor make sure they are trying to lit pilot. If you have standing pilot model and pilot lit is not on. Turn control on gas valve to off,wait five mins. then turn to pilot. Depress botton and try to light pilot. If it lights hold down for a couple of mins. then release.. If pilot stays lit turn control to on. If thermostat is calling for heat this should bring main burner on. If pilot does not stay lit then replace thermocouple. Hope this helps. Thanks
Nov 16, 2010 | Heating & Cooling
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
WE can get the pilot light lit but it will not stay on
You will need to check the pressure regulator for the gas.
It sounds like the gas pressure is to low to keep the pilot lit.
John
Oct 01, 2009 | Desa International Blower Glow Warm Wall...
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Jul 12, 2009 | Bosch & Tankless LP Hot Water Heater
Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey switch...in case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
May 30, 2008 | Coleman (5040B750) Patio Heater
Honeywell VS820A1088 PowerPile Millivolt Gas Valve NEW Logo
Top Honeywell Electrical Supplies Experts
Dennis Boxerman
obsteiner
ray012965
Are you a Honeywell Electrical Supply Expert? Answer questions, earn points and help others
