Question about Evenflo PortAbout 5 Infant
Removal of Pad for Washing
I am so frustrated.  I know that the harness straps need to be removed in order to remove the pad.  However, the harness straps are weaved into a box that do not fix through the slots in the seat.  I tried to remove the straps from this box in order to have the straps fit through the slots but was unsuccessful.  Please help.
You need to remove the straps from the bottom of the seat.
Posted on Mar 24, 2008
How to remove maxi cosi cabrio harness straps
Hi
The harness of a carseat should never be removed or replaced by anyone other than a trained engineer due to the safety implications of it being incorrectly replaced.
The carseat fabric should be removed from this carseat and they can be washed - the harness itself should be cleaned in place in the carseat using a solution of stain remover and water and a small scrubbing brush or hard scourering pad to clean the harness. Excess water in the carseat should be dried immediately and thoroughly to prevent any parts rusting. Loose crumbs can be removed using a vacuum cleaner.
Alternatively the carseat can be sent in for the engineers to replace with a new one. Inspection and single repair (replacement of the harness) plus safety checks and courier collection and repair can be booked for 39.99GBP if you're in the UK by calling 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays)
Mar 22, 2013 | Maxi-Cosi CabrioFix (Black Reflection)...
How do i move the straps to a higher/ lower **** ??
Hi
Undo the popper on the shoulder harness pads and slide pad down length of harness. You will reveal a metal D ring which is where the harness is attached to the anchor point. Unhook this ring. Remove the top of the seat fabric from the sub seat (seat frame) and you will find further sets of anchor points behind the fabric. Post required anchor point through the hole it lines up with and re-attach harness, then put harness pad back into position and do up popper.
Mar 24, 2012 | Quinny Buzz 3 - Rocking Black Stroller
How do you move the straps for a bigger child
Hi
Undo the popper on the shoulder harness pad. Slide the pad down the length of the shoulder harness strap.
Unhook the metal D ring.
Feed the short length, low down anchor point back in behind the seat fabric. Bring the longer length, higher up anchor point out at the desired height.
Re-attach the D ring. Adjust the harness straps accordingly.
Slide harness pad back up shoulder harness and re-attach popper.
Sep 11, 2011 | Quinny Buzz Three Wheel Stroller
Need to remove the cover from a britax eclipse si..how
Press and hold down the harness release button. With your other hand below the chest pads, pull the shoulder straps forward as far as possible. With the Eclipse Si fully reclined, open the seat-belt guard at the back of the shell. Pull the yoke out from behind the seat and unhook both shoulder straps. Pull the cover from the top of the seat so that you can see the slots in the seat shell. Pull each shoulder strap and chest pad strap forward and towards the centre of the shell, easing the metal tab and straps through the slot. Then thread them through to the front of the cover. Unfasten the buckle and remove the comfort pad. Gently pull the cover off the seat, easing the shoulder straps, chest pads, harness buckle and adjuster strap through the slots in the cover.
By Geraldine Thorne
Feb 24, 2011 | Britax Eclipse Si - Chantilly
1997 cadillac eldorado instrument cluster removal
remove ac vents with flat head screwdriver . thair should be a 7mm bolt in each vent holding tha dash pad on remove them. remove the trim going to head liner from the dash pad. use a 7mm to remove the bolts holding the cluser in place should be one each side and 3 across the back . disconnect the wiring harness and your done. also disconnect the negative batery cable when doing this
Feb 15, 2010 | 1997 Cadillac Eldorado
Need to replace the driver's door interior door opening assembly
Hi there.
The procedure is roughly the same for all mk3 x types.
You need to remove all the screws on the armrest and on the ashtray, then undo all the plastic clips using screwdrivers on the panel.
You find detailed instructions on links below, I quote:
" remove two screws at the bottom of the armrest.
pull out ash tray.
remove screw in the middle of the ash tray holder.
pull up on armrest, it should pop up, then pull it out
start at bottom right of door and start popping out the plastic clips (all the way around the door)
(remove speaker wires)
push up door panel - done"
WikiAnswers - How do you remove a rear door panel in a Jaguar XJ6
Also from manual:
Disconnect vehicle battery ground lead.
Remove the door trim pad veneer panel.
Remove the upper trim pad.
Remove the door armrest.
From inside the door pocket, release the puddle lamp (1 Fig.1) securing quarter turn fastener.
Undo and remove fixing (3 Fig.1), (front door only)
Carefully release lower trim pad fir tree fasteners.
To avoid damage and distortion of the door metal, lift the lower trim pad complete with clip and clip retainer.
Carefully pull the trim pad away from the door panel.
Disconnect the multi-plugs (1 Fig.2) and remove the lamp.
Carefully displace the trim pad (2 Fig.1) from the door retaining clips.
Disconnect the multi-plugs (2 Fig.2) and (3 Fig.2).
Remove the door pocket.
Displace and remove the retaining clips and remove the trim..
Refit in the reverse order of the removal procedure. Check the trim pad retainers for damage before refitting.
Before refitting the lower trim pad, remove the clip retainer from the pad and and reposition retainer to the door.
ndo door handle escutcheon screw and remove escutcheon
Undo and remove the upper trim pad securing screws.
Remove the chrome strip.
Undo and remove the top channel securing nuts.
Displace and remove the top channel assembly.
Place the trim pad aside (Fig. 1).
Thanks Jaguar XJ6 Interior Lights
I will be grateful if you can rate the solution given.
Many thanks.
G.
Feb 25, 2009 | 1995 Jaguar XJ6
1995 Mercury Cougar Door Panel Removal
This nearly drove me crazy on our 1994 Cougar.
First remove the electric switch cover(window and mirror controls). Just pops out with a pry. Remove the harness attachments You will see a single screw into the door holding a bracket between door pad and door frame. Remove it.
Second, remove the door lamp plastic cover at the bottom rear of the door. You will find a second screw in there on the upper right corner. Remove it and you are ready. Pull the whole door pad upward and it comes right off. No popem plastic clips or anything else. Just 3 or 4 quarter circle retainers that pop over into the door when you push the pad back down
Oct 26, 2008 | 1995 Mercury Cougar
Straps back on after washing
turn the metal clip sideways to slide it through the cover and then through the back of the chair. Get the owner's manual and instructions online if you need more help at www.evenflo.com
May 27, 2008 | Evenflo Chase Comfort Touch
Garage Sale Car Seat
If you push down on the top of the handle you should then be able to move it. Also, to remove the straps you have to feed the bottom portion of the straps from underneath the seat up through first and then you should be able to feed through the material to remove the pad.
Aug 18, 2007 | Evenflo PortAbout 5 Infant
Evenflo PortAbout 5 Infant Logo
428 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Rob Sinbad
Rob Sinbad
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
