Question about Maytag Dryers
MAytag 2300 aww does not heat
THe drum turns and blower blows. I hear one click when turning the heat setting from air fluff to normal. No heat
  • 451 Answers
If this is a gas dryer it may be the ignitor has failed. There should be a panel you can remove to inspect the burner compartment. Turn on the dryer and look for an orange glow if you don't see any glow the ignitor is probably faulty and should be replaced. If it is an electric dryer it may be a bad heating element. Hope this helps.
Posted on Jan 03, 2014
5 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Crosley CDE6500AZW heating, but drum not rolling
OK Here is what I think happened. I have heard of this before. You melted a wheel and that broke the belt. This is a simple dryer to repair and parts are not that much. Well worth fixing. Start by popping the top remove the front then get the drum out and inspect the damage.
Posted on Mar 01, 2009
canbruce75
  • 1776 Answers
SOURCE: my maytag dryer turns on but the heat will not
This is caused by a blown thermal fuse or a faulty heating element. Both components can be tested for continuity using a multimeter. A lack of continuity indicates a faulty component. The thermal fuse is about one inch long and is located just inside the rear of the dryer and is usually attached to the exhaust duct. Hope this helped and best wishes.
Posted on Aug 06, 2009
wfservices
  • 260 Answers
SOURCE: maytag lde410 dryer air blows but is not heated
The heating coil may be broken, or the heat sensors may be malfunctioning.
Posted on Feb 23, 2010
heatman101
  • 43501 Answers
SOURCE: Maytag neptune Model # mdg5500 AWW when i push
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 13, 2010
Neptune dryer turns on and works for about 10 minutes, then shuts off. When the door is opened it is very hot and has a burnt smell. The only setting that does not have a burnt smell is air fluff. All...
remove the front cover and drum and clean out all lint including lint filter blower wheel housing and all exhaust vent piping from inside dryer to outside discharge,if this is done and it persists,replace the cycling switch and high-limit thermostat as these may have welded themselves and can no longer control heat
Aug 23, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My maytag dryer has plenty of heat and the drum is turning, but it is not blowing the hot air and moisture out the vent. I have checked the panel box and everything is fine. My dryer is a Maytag Bravos,...
pull the vent hose off the back of the unit turn it on and make sure it has alot of blowing power if it does blow good you have a clog in your vent hose somewhere,, if not your blower could be bad,, if i remember correcly that one has a belt just for the blower also check that
May 03, 2011 | Dryers
Maytag dryer goes on but clothes are not turning
Can you turn the drum by hand? If not there is something Jammed in the blower housing.Do you hear the motor running? Is there Air blowing out the back? If there is air blowing out & you hear the motor it will be the belt. If you do not hear the motor & no air is blowing out then hold the door switch in & turn it by hand as you push the start switch it might start working, If it does it wont last long. If it does not start it is the motor.
Sep 29, 2010 | Maytag Dryers
Dryer turns on but does not heat up
the first thing to check is the ignitor .how ever there is a thermal fuse located on the exhaust duct inside the dryer that may be bad this woulld cause the unit to run and not get hot.this needs to be checked with an ohm meter for continuity there is more than one thermal fuse so check them all just to be sure.i hope this has helped.please let me now how things turned out.good luck
Jan 22, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag Bravos dryer heats but does not blow air out the vent.
Since you did not provide a model number I picked a similar model for reference using this model number: MDE5721TQO (there are at least 40 different model numbers but the blowers are all the same) You blower is driven directly by the motor so unless the blower itself has come apart or the drive spline in the blower has failed in some way you more than likely have a major build up of lint in your dryer.
You can look here to see the blower location http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133558&diagram_id=1301439#d1301439
You can turn the motor by hand and see if the blower is turning by losening the housing screws for the blower while using a flashlight. If the blower is turning then you need to find out where the blockage of lint has built up and remove it. I would startt around the lint filter. NOTE The drum will also turn.if you rotate the motor pulley. Just make sure the unit is unplugged while you attempt this. If you do locate the blockage I have found that a well bent into a U shaped METAL coat hanger works well. Do NOT poke any sharp objects into the air ducting areas of your dryer while trying to find any blockages and avoid the heating element area with anything metal or sharp. A vacuum crevice tool works great during this task. Good luck and I do hope you are able to locate the problem based on the information here.
Jan 11, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Drier turns on, tumbles, no heat
your heating element is out,. very easy to replace
Jul 18, 2009 | Dryers
No air blowing out of air vents on a saturn L300 no heat or cold
1999 saturn the ac is no longer blowing air at all no heat no cold air you can hear it turn on but nothing. What do I need to look for?
May 08, 2009 | Saturn L300 Cars & Trucks
Mar 01, 2009 | Crosley CDE6000 Electric Dryer
Kenmore gas dryer not heating
GAS DRYER, NO HEAT. CHECK THE HEAT SETTING FIRST.
IS IT ON AIR FLUFF? I'M NOT BEING SMART, BUT YOU WOULD BE SURPRISED HOW MANY CALLS I TAKE THAT ARE ON AIR FLUFF. SECOND, LISTEN FOR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER. IF YOU HEAR IT, LOOK IN THE INSPECTION HOLE ON THE FRONT OF THE DRYER, OR REMOVE THE TOE PLATE TO VIEW THE IGNITOR. IF THE IGNITOR GLOWS AND THEN CLICKS OFF BUT NO FLAME, YOU HAVE A BAD SOLENOID ON THE GAS VALVE. IF THE IGNITOR GLOWS, BUT NEVER CLICKS OFF, THE RADIANT SENSOR ATTACHED TO THE SIDE OF THE BURNER ASSEMBLY IS BAD.
IF YOU DON'T HEAR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER, THE MOST LIKELY CAUSE IS THE THERMAL FUSE LOCATED ON THE BACK OF THE DRYER DOWN NEAR THE EXHAUST DUCT. IT IS A SMALL WHITE ITEM ATTACHED TO THE EXHAUST DUCT WITH TWO WIRES ATTACHED.
Apr 10, 2008 | Dryers
Dryers Logo
46 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
