Have voltage on primary side of transformer but nothing on secondary
    Brigadier General:
  • 3,917 Answers
Is the audio coming from the TV's internal speakers, or from an external sound system? In the 169 series chassis, if the power supply caps or secondary rectifier are bad, or if the high voltage splitter has shorted inside, the set will not run and there will be no picture or sound from the TV. If the picture is completely black but the TV still has audio, press the menu button and see if the menu comes up on the screen. If the menu is there, check your cables on the back of the TV. If you are using a cable or satellite box, the box could be bad or the video wire could be bad or loose. If you do not get the on-screen menu, then I would guess that the solder joint next to the flyback transformer that sends filament (heater) voltage up to the picture tubes has cracked, or the low value resistor in the heater circuit has opened up. If that is the case, have the set serviced by a qualified tech familiar with the 169 series chassis.
Thank You
Posted on May 21, 2009
Conventional power pack
A primary and secondary usually refers to a transformer. The primary side being the input side 110 AC Volt or 220 Volt AC side. Also called Source.
The Secondary being the "output to load" side 12 Volts "for example". And also called Tap (Secondary Tap)
The voltage is changed by conduction, magnetic flux, neither side touching one another. And the number of turns of wire, per side, determine the voltage. The voltage may either be a step-down or Step-up depending on its use.
An unconventional method is to have both the primary & secondary combined into a single tapped winding - which arrangement is called an autotransformer. The autotransformer does not provide isolation between primary and secondary circuits but its simplicity makes it economical and space-saving.
Imagine a single wire wrapped from the top to the bottom being the primary, and tapping in. in the middle and bottom for the secondary, so the output becomes 1/2. That would be a step-down transformer.
The actual measurement of a transformer is measured by its efficiency (Faraday Law) which is defined as a ratio of power. I hope that's sufficient, but if you want more I would buy for $2 bucks an Electricity Made Simple Book, because there are pages after pages to write about transformers, and to understand electricity in general it is helpful to understand the difference between alternating current and direct current and its magnetic field of induction and magnitude of emf.
May 10, 2014 | Cars & Trucks
Schematic malibu 8100-9120-01
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
I don't think they post schematic for the transformer
But generally, the primary coil receives 120Volt AC input from household electrical outlet
And the secondary coil produces 12Volt AC output for the low voltage lights.
The 'coil' is a coil of insulated wire wrapped around a metal core. Two coils set side by side create a transformer... when primary is energized, the secondary responds to the magnetic field caused by primary core... resulting in a current that flows on the secondary coil.
Output voltage on secondary coil is determined by the number of wraps and diameter of wire.
Some transformers offer a choice of secondary output... Kichler for example... you can select 12-13-14-15 Volt AC output
This is achieved by the way the secondary coil is wrapped.... for less voltage a wire is tapped at one point on the coil... for more voltage, a wire is tapped at another point on coil. This gives the user several wire choices to connect the lights.
Gene
May 09, 2014 | Intermatic Malibu 300W Power Pack...
Djx 750 - no power - transformer dead?
Actually, you may be in luck. A burned cap means that it has done exactly what it's supposed to do. So...you might stick an identical one in there -- it's a 0.1 uF cap, and you can find these at Radio Shack (0.1 uF 50V) or online. They are cheap, so give it a shot.
Feb 16, 2014 | Behringer DJx700 5-Channel Pro DJ Mixer...
Transformer replacement
primary side = voltage being supplied to transformer......secondary side = voltage output on transformer. hot line to hot line, neutral to neutral...........rtfm......read the manual
Dec 05, 2013 | KitchenAid Refrigerators
How to test for bad transformer
  1. To test a transformer you need to know what type of transformer it is first. There is a step up transformer which steps the voltage up and a step down transformer which steps the voltage down.
  2. You will still test the transformers the same way for step up and step down transformers. If it is a step up transformer apply the incoming power to the transformer or plug it up. Now take your multimeter and place it on the AC volt scale and test the voltage if the voltage on the data plate says the transformer should step up to 220 volts and it doesn't then your transformer is bad.
  3. Now repeat the same steps for a step down transformer. Plug up the incoming or primary power and test voltage on the outcoming or secondary side the voltage should step down to the proper value. If you don't read any voltage on the secondary or outgoing side then the transformer is bad.
  4. To read the voltage place the two meter leads on the secondary side, or the side you will plug your equipment into. If the secondary side is an outlet then place the two meter leads into the top two slots in the plug and read voltage. You also want to make sure the incoming power is working as well. Otherwise you will be reading a bad reading every time.
Dec 16, 2011 | Emerson LC320EM8 32 in. LCD TV
How to identify the matching transformer terminal by means of terminal resistance? and which terminals is for input or output?
Doing a resistance test on a transformer will not give the information you require as you will read very little, if any resistance. What you need to do is an impedance check and that gets involved. If it is a normally wound transformer, not an auto transformer, you can isolate which is the primary and the secondary windings. Unless the transformer is a multi voltage input unit, the primary side will have continuity through only two terminals. The secondary could be more than two if it is a multi output voltage one. If the transformer is a step down, the primary windings will be the thinner wired windings and vice-versa. To actually test the transformer, get hold of a transformer with about a 20 vac output and try it across the two terminals you have identified as the primary windings, you should ge a proportional voltage of the actual output. eg. with 20 vac input and a 2 vac reading at the secondary, the actual output would be 11 vac if your mains voltage is 110 volts. Take care that you are using the transformer at the voltage it is designed for, otherwise it will overheat and burn out.
May 11, 2011 | Kitchen Ranges
I'm not getting any low voltage at the t-stat.
Make sure that the transformer has power on the primary side then check the secondary side for low voltage. If you have power on the primary and none on the secondary then replace the transformer.
Sep 05, 2010 | Dometic Rooftop RV Air Conditioner
Transformer died, got a Packard Universal PF42440 for Heil furnac
Look at the tranformer. It should tell you which wires are the primary side and which are the secondary side. It may have more than 2 wires on the primary so it can be used for more than 1 voltage. Now depending on what voltage the a/c uses find the wires in the a/c with that voltage on them (110v or 220v) and connect one of those 2 to the lead for that voltage on the primary and the other to the common on the primary. Next the secondary side should have 2 wires, probably yellow and blue but maybe not. I don't know the color of the wires in your a/c but one leg of the primary usually connects to a red wire and the other to a blue wire that probably come from a ciruit board or thermostat. Make sure you do not connect 110/220 to the wires for the low voltage side. If this doesn't help let me know what color the wires in your unit are and we can go from there.
Jun 03, 2010 | Haier Heating & Cooling
Transformers primary winding broken. What the ratio? 230 VAC to ? VAC (10 VAC ??)
For transformers, the voltage to turns raio is calculated by formula:
V1 / N1 = V2 / N2 where,
V1 >> Voltage at primary
N1 >> number of turns at primary winding
V2 >> Output voltage at secondary
N2 >> No. of turns at secondary winding
So in your case:
V1 = 230 and V2 = 10. If you know the no of turns of winding at one side, you can calculate the turns on the other side.
Aug 12, 2009 | JVC RC-ST3 Cassette/CD Boombox
No control power
PRIMARY means INPUT(from supply side)
SECONDARY means output( to load side)
Sep 23, 2007 | Maytag M6D24E7A Air Conditioner
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
