Question about Sewing Machines
How to install a bobbin case - Sewing Machines
The bobbin thread will not raise. The bobbin and holder falls out every time
Difficult to help without knowing the make & model.
If the bobbin case falls out, then it is not latched into place. Most bobbin cases have a spring loaded latch that needs to be held open until the bobbin case is firmly seated in the machine. Then the latch is released which locks it in place.
Installing Sewing Machine Bobbin
Aug 08, 2017 | Sewing Machines
I need a schematic for a Brother 6700 embroidery machine. I cleaned the bobbin case and around it and now the machine is making lots of noise.
It is probably one of two things,
1st..always put the needle plate on before you install the bobbin case. You can lock the bobbin case down by putting the needle plate on after putting the bobbin case in. Take off the plate and remove the bobbin case, install the needle plate, then install the bobbin case.
2nd...your bobbin case may be damaged now, if it is scratatched or chipped get a new case.
Good Luck
Jun 30, 2017 | Brother Sewing Machines
My brother vx-1120 needle wont pick up bobbin thread to make a continuous stitch
Install a brand new needle. Make sure it is installed correctly.
Remove the bobbin/bobbin case from the machine. Check that the bobbin is turning the correct direction and the bobbin tension is threaded correctly. Reinstall the bobbin case and confirm that it is latched into place.
Retest your machine. Slowly turn the handwheel and watch the needle descend and see if it picks up the bobbin thread. If not, then there is probably a sewing machine timing issue. Take it for service.
Nov 01, 2016 | Brother Sewing Machines
Singer 4622 installing bobbin case
The owner's manual should have instructions.
Also search for some videos on YouTube:
Bobbin case seating 2
Inserting Bobbin Top Drop In
Fixing Top Load Bobbin
Jan 22, 2016 | Singer Sewing Machines
What can i do when the top thread is caught on the bobbin race and loops there?
1. There are many bobbin cases. Make sure the right one is installed. Also, once you have it installed check the handle of the bobbin case to make sure it is going flat with the bobbin case.
2. Check the bobbin you are using. If it is too long it will protrude the length of the bobbin case. It must be able to spin freely.
3. Check the bobbin case on the outside for any rough edges that could hang up on thread.
4. The bobbin tension should be checked. I've attached a guide for this. Your's is the older style.
5. Make sure the top is threaded properly. Especially make sure the thread is going through the thread in the right direction.
Jun 08, 2015 | Brother LX3125 Sewing Machine
How to fix the tangling of top thread on bobbin race.?
Jun 07, 2015 | Brother LX3125 Sewing Machine
Install bobbin case
Watch in utube for 'singer front loading bobbin case' and other links that can be helpful to you.
Nov 07, 2013 | Singer 8280 Mechanical Sewing Machine
Singer 4562 t bobbin case won't fit properly, what am I doing wro
Make sure the bobbin case sets sort of on top and not under the ridge of the metal ring. There is a small latch on the upper left of the bobbin case. It is metal. rotate the latch to cover the bobbin case and this should stabilize the case without making it immobile
Jan 27, 2010 | Singer 7442 Mechanical Sewing Machine
Bobbin Case cannot be replaced properly
Make sure there is no thread wrapped around the bobbin case retaining pin in the locking groove. This pin is part of the shuttle hook. I am assuming this is an oscillating machine and the bobbin case is removed to install the bobbin.
Jan 24, 2010 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
