Setup proscan tv
I bought a proscan 37" plcd3717A. Please keep in mind that I am a 6o yr. old woman with very little knowledge of electronics. My problem is I can't get it hooked up! There are 14 "holes" and I have 5 plugs! All I want is to hook it up to my PVR! All I get is a "no signal" on a blue screen! HELP!!
  • 468 Answers
Newer tvs have a lot of input connections ( holes) and can be very confusing. With out knowing what kind of plugs you have I will try to help as best I can. First ,if you have a coax cable hook it to the corresponding connector. The coax is a pencil sized cable that has a center wire and a threaded nut. It will screw onto the threaded connector on the back of the tv. If you have RCA cables these will be color coded yellow for video red and white for audio plug these into the corresponding connectors. There may be more than one set of these connectors and may be marked input1 or input2 etc.make sure to write down which input you plug these into.you may also have colorstream cables there are three green red and blue. Some of the newer tvs don't have inputs for these but if yours does plug them into the corresponding colors. Another cable you may have is a s-video cable this is a single cable that has a multi pin connector on each end. Again find the corresponding connector and plug this cable in. The newer cable is called a hdmi cable and is a cable with a rectangular end. This one cable takes the place of the multi-pin s- video cable or the RCA cables. It also replaces the colorstream cables. If you were able to connect all your cables up. Turn on the tv. You may get a blue screen that says no signal. Don't panic take the remote and find the input button. Pressing the input button changes the tv to the various sets of inputs on the back on the tv. Press the input button several times waiting in between each press of the button for several seconds untill you find the input you connected your cables to. If your connecting a vcr make sure you have a video playing so there will be a signal for the tv to find. I'm not sure what a PVR is, but make sure it is playing some thing when you scroll through the inputs on the tv with the remote. Hope this helps.
Posted on Jan 03, 2014
Testimonial: "Thank you from the bottom of my (signal receiving!) heart! I copied what you wrote and followed it step by step and guess what??? Voila! My television works!! Thanks again!"
SOURCE: olevia tv repair
CHANGE TO A ROOMSHOW
Posted on Mar 09, 2008
SOURCE: hooking up the dvd player
how do i hook up dvd where do i put the wires in what input
Posted on Nov 10, 2008
  • 32 Answers
SOURCE: Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Posted on Apr 02, 2009
SOURCE: tv says no signal after hooking up computer to it
I had same problem, adjust settings on your computer desktop resolution to 800x600 solved my problem right away, computer resolution is probably too high. Hope this helps!
Posted on Jun 09, 2009
SOURCE: Proscan 32'' VGA port; TV says not supported on VGA input
Sounds like your resolution on your computer is set too high for your tv to accept. Try putting your computer resolution down to 1024x768 or lower and see if that works.
Posted on Aug 05, 2009
Replaced the main board for dead tv she works now but picture looks solarized thought i could go intp factory mode an swotch panel types but cant get into factory mode any ideas???
Check your lvds, connections or the flat cable that goes to your main and tcon that's connected to the panel as well. Take out and clean the cables connections
Feb 07, 2016 | Proscan LCD LED TV REMOTE CONTROL For...
I have a proscan plcd3717a. The tv keeps turning itself off. It stays on for 2 to 3 minutes then it shuts off. The sleep timer is turned off. Do you know what is wrong with the tv?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Aug 16, 2014 | Televison & Video
Tvs not even a yr old won turn on , when it does its for a few secs n back off ! bought it from a company called A & E factory online n they were suppose to have a tech out twice now n re sch the...
Take it to a local repair shop and have fixed and send A & E the bill. Or have local repair shop get authorization from A & E to repair it for you.
Jan 06, 2011 | Proscan 40LD45Q TV
My 26 in. LCD Proscan tv will not stay on, any suggestions as to what my be causing the issue. The TV is only a year and a half old. I can turn it on and within five mins it will shut off. I have tried...
It can be caused by many things such as cold solder joints, loose connections, failing components such as capacitors. Unplug it for about an hour tolet it reset itself to see if it will help, if not, you will have to open it and inpsect he inside, take the voltage reading before and after the problem.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 27, 2010 | Proscan 26LA30Q 26 in. LCD Television
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
I lost the sound on my 2 month old 37" ProScan TV.
If it is only 2 month's old it should still be in warranty call the manufacturer they should be able to help you.
Sep 10, 2009 | Proscan 42LA30H 42 in. LCD Television
Where do the yellow,red, and white cords connect to on my Proscan 37'' DVD/HDTV
it depends on what signal your sending to the tv.
red and white are usually sound and yellow is picture or AV.
you may need to select the input on your TV to recive a picture. Does this help?
May 07, 2009 | Televison & Video
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
