Question about Fisher and Paykel GWL11 Top Load Washer
Model GWL 11 will not power up after to large of a load was put in. removed sleeping bag from tub and dipped out machine. unplugged waited 60 sec. tried again. will not power up. have 110 at rec. can you help?
The very same thing happened to me just a week ago. The main board was fried. $168.00 worth. Good luck. Mark E.
Posted on May 27, 2009
My GWL 11 board failed, I pull the board out and found two fuses a 2.5 amp and 6.3 amp. The 6.3 failed. Went to Radio Shack and bought fuse and fuse holde and soldered in. Powered it back up found Diverter valve had failed, checked my drain pump ohms it checked ok. Order Diverter Valve when it came in I installed it wash one load and drain pump failed. I have been waiting 2 weeks for new pump. FP still don't have the pump in stock.
Posted on Jun 05, 2009
Not used my netbook for a week it was fine when i turned it off now when i plug adapter in green light comes on but nothing happens if i unplug it then green light turns to orangy colour i plug it straight...
Unplug the charger, remove battery and then keep pressing the power button for 30 sec. Then wait for one minute, load the battery and then try to switch ON.
Apr 26, 2014 | Samsung N150 (36725723009) Netbook
Replace fisher paykel iwl 16 mother board with gwl 11 motherboard
I cannot find your mothers IWL16 model, but I have found various similar machines that are the same phase as your GWL11 machine, the electronics in there although different are compatible, you can swap the drain pumps, there almost universal, avoid the drive shaft machine, fix the other one If you want further help, post a photo of both pcb's (the electronics) After swapping your machine will stil require programming which is simple enough
Sep 14, 2012 | Fisher and Paykel GWL11 Top Load Washer
Can you put a sleeping bag in the tumble dryer?
Mostsleeping bags can be tumble dried but on a low heat. Check out this article forsome more information about drying and generally cleaning sleeping bags http://www.rei.com/expertadvice/articles/caring+sleeping+bag.html
Jul 30, 2012 | Camping, Backpacking & Hiking
Can I put my sleeping bag in the washing machine?
Mostsleeping bags can be cleaned in a washing machine but check the label. Usuallybags should be washed on a warm wash and a gentle cycle.
Fisher & Paykel Washing Machine Model GWL 11
The power supply needs three resistors removed,R129,R130,R131.
and one 1megOhm put in it's place.
Feb 25, 2012 | Fisher and Paykel Washing Machines
The wireless icon is orange. Do you know why??
Hi, 1. Unplug the power from the Modem to the Router 2. Plugin back the power into the Modem and wait 60 sec.. 3. Plugin back the power for the Router wait 60 sec.. 4. Plugin a lan cord from the router to the first wired PC 5. See if you can get on the internet 6. Login to the Router and see if the Connection to the WAN is started? 7. If not started then unplug the wired lan cable and reset the router wait 30 secs to 45 secs before unplug the power then plug the power in again. Then connect the lan cable then connect to the GUI for WEB. Make your See if it connects to the WAN. 8. Test the Network WAN -Internet and LAN - Home Network.
Take care
Jul 17, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
GWL 11 washer. Water does not come in when power
Hi just read your posting.Now what water setting have you selected?Is it warm cold or hot?Does the machine stop and beep with a series of lights that come on?If there are lights that come on when it beeps, they will be in a row of 8 lights.Starting from left to right which ones are lit?Is it the 3rd and 6th or 1st and 7th --etc--?Now if you have an LCD display what error code is it showing?Please reply with additional information and I can help you rectify this fault.
Jun 23, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer won't drain
Could be something in the pump. The pump is on the bottom of the tub.
It has a locking tab which you release and then twist the pump a hair and it will fall out. Warning: Have rags ready! I have the original GWL service manual and the GWL 11 supplimental manual. Let me know if you want them.
Apr 28, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washer will not work!
what type and model is the washer?
Nov 28, 2007 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
316 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
