Msi vr320x driver - Computers & Internet
How to repair msi vr320x with no display?
Does both the port not giving you display did you check the memories is it all fine set also the power you have connected it properly try it in different machine check the PCIE Volts which slot is suitable for your Card on your motherboard.
try the display cables and cooling all ok than i am afraid you need to send it to a workshop or you can fix if you know chip level work so there is An IC if fails or leak it does not give any out put so you need to change that.
Jul 02, 2014 | XFX Computers & Internet
Chippset driver
Windows XP 64-bits : http://msi.mydriversdownload.com/msi-driver/Msi-K9N6SGM-V-K9N6PGM-FI-K9N6PGM-F-NVIDIA-MCP61-Chipset-Drivers-for-Windows-XP-64bit_2225.html
Windows Vista 32/64-bits : http://msi.mydriversdownload.com/msi-driver/Msi-K9N6SGM-V-K9N6PGM-FI-K9N6PGM-F-NVIDIA-MCP61-Chipset-Drivers-for-Windows-Vista-32-64bit_2226.html
Windows 2000 : http://msi.mydriversdownload.com/msi-driver/Msi-K9N6SGM-V-K9N6PGM-FI-K9N6PGM-F-NVIDIA-MCP61-Chipset-Drivers-for-Windows-2000-XP_2227.html
Windows 7 : http://drivers.softpedia.com/get/MOTHERBOARD/Nvidia/MSI-K9N6SGM-V-K9N6PGM-FI-K9N6PGM-F-Nvidia-Chipset-Driver-1556-for-Win7.shtml
Feb 28, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
Motherboard drivers msi ms-7309
Hi, every driver for that motherboard can be downloaded from this: Driver Update Software. Wish you best of luck. Brian
Jan 15, 2010 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
My laptop monitor starts to pop up. i own an MSI VR320x . by popping, i mean that the screw just jumped off, hence, opening the monitor on its side. at first, i just noticed that the part of the monitor...
Hi Kristine,
This could be caused by heat coming from the inside of laptop, which could possibly be a larger problem than just the screw coming off.
I would recommend taking it to a technician at this point because the inside of a laptop can be very confusing. It has so many small parts and is very sensitive to static electricity.
This will allow the technician to run it thru a few test and make sure the laptop itself is not overheating. If it is, then they will recommend a fix for the problem. Most times, this is caused by a bad fan or clogged vent in the laptop, dust, debris, etc.
Hope this helps!
Jennifer
Dec 21, 2009 | Tablets & eReaders
Need a msi ms-7312 ver 1.0 vga driver
Hi, Your driver can be downloading easily by using this: Driver Update Software. take a look, and wish you best of luck. Hans
Oct 02, 2009 | MSI K9MM-V Motherboard
No power
I was watching a dvd and during the movie the screen went black and shut down. Now it won't start at all
Jun 13, 2009 | Computers & Internet
I need MSI-ms-7142 ver:1 audio driver
i have no sound. So i need audio driver. Please send ms-7142 VER:1 audio driver
Jun 12, 2009 | MSI K8MM-V Motherboard
I need msi drivers for an n1996 motherboard
Hello I have provided a direct link to the drivers for your motherboard. The drivers are free to download. Hope this helps.
Click on link below:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=173
Please rate my solution. Thanks
May 21, 2009 | MSI K8MM-V Motherboard
Computers & Internet Logo
David Payne
David Payne
