Question about Keurig Coffee Makers & Espresso Machines
Keurig not sucking - Keurig Coffee Makers & Espresso Machines
Keurig keeps saying add water and ive added water over and over and it wont go away! ive tried all the suggestions and its still not working. What do I do!?
THE WATER RESERVOIR IS NOT SEATED PRO{PERLY. THAT IS ALL IT IS. SLAM THE TANK DOWN A FEW TIMES UNTIL IT STARTS SUCKING IN WATER. THAT IS THE FIX - HENCE THE ALL CAPS RESPONSE !!!
Nov 18, 2012 | Keurig B60 Coffee Maker
My Keurig B60 will not brew. The "ready to brew"
Having same problem with B60 turns off after 1 minute and little circle won't go away.After unit was stored for 5 months, So this is what I did. 1. I took it over to the sink and turned it upside down and shook it. 2. I dried out the whole where the water sucks up and blew through there with a straw. 3. then I sucked water out the rubber tube up top for the over flow. Then I put vinegar in the intake whole and put vinegar in the tank and let it sit overnight. When I got up in the morning i turned it on and after 1 min it shut off again so I restarted it and after a couple minuets it started to heat and my display came back and circle disappeared. Problem solved. Not sure which one worked but it is now working fine and I am now descaling it.
Feb 25, 2011 | Keurig B60 Coffee Maker
I have a B70 Keurig machine and it sucks water fine but only drops of coffee or water come out...what could be causing this?
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Feb 25, 2011 | Keurig B70 Coffee Maker
Keurig Mini Wont Brew Water won't come out
Had that happen just this morning with my mini-keurig, the needle was horribly clogged. Found a solution on another forum that said to stick a straw over the needle that punctures the cup and blow really hard, then suck really hard and it pulled the debris right out! Then do a cleaning cycle (water&vinegar) to clean out any buildup.
Jul 06, 2010 | Keurig B30 Mini Coffee Maker
My Keurig B66 is not pumping or sucking the water to brew. It will brew a cup here and there but not the way it should. There is plenty of water in the reservoir. You can hear it trying to pump the water...
I had the same problem. I called Keurig at 1-866-901-2739 and they are sending a replacement machine to me as they said this problem is not repairable.
Apr 09, 2010 | Keurig B60 Coffee Maker
Coffee Makers & Espresso Machines Logo
60 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
