Question about Philips Zenia Voice Cordless Phone
Cannot go to Standby mode
All a sudden my cordless phone does not work, cannot get "standby" mode on the handset. Error messge "Failed !" appeared when trying to make a call. The base station is not functioning at all. Tried unplugged everything but didn't work. Please help!!
SOURCE: philips dect 521/525 - 3 year old phone - No dialling tone on one handset
I had the same problem and my hubby managed to reset the phone by simply unplugging it from the electical network. Just wait for few minutes (the date goes back to 1 Jan 2005), then plug it again and try to dial a number. It should work.
Posted on Oct 18, 2008
richa33
  • 71 Answers
SOURCE: Base station and units all say 'searching'
You may need to register your handset to the base.
Normally ,there is a advanced setting ,register handset. At the same time, press and hold "page" key on your base 4 to 5 second , there is be a registation success tone from handset. You can register all of your handset ,one by one. Some model need to input register code, normally ,it is 1234 , or 0000.
Posted on Jan 21, 2009
richa33
  • 71 Answers
SOURCE: Philips CD125 Twin Cordless Phone "Searching" problem
Maybe, RF amplifier chip die or antenna broken.
SOURCE: Philips CD6451B/37 Cordless phone w/Answering machine-NO BASE FOUND-SEARCHING
Try changing the battery. Try using a new AAA rechargeable battries.
Posted on Apr 02, 2009
najah
  • 180 Answers
SOURCE: PHILIPS Zenia 200 6626, handset has stopped charging
Replace the batteries.
Posted on May 24, 2009
Dect phone manual
Standby mode is when the phone is not on a call, you're not dialing one, and you're not doing anything with the menus. It's standing by, waiting for you to call or for someone to call you.
Aug 09, 2014 | Panasonic KX-TG4022N DECT 6.0 Single-line...
How do I get the ringer back on?
You may download a copy of the manual at http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1680om.pdf
If the phone is in silent mode, see "Silent Mode" beginning on page 10. If the handset volume is turned down, press up-arrow while in standby mode. If the base volume is turned down, press "+" while in standby mode.
Jun 13, 2014 | Uniden DECT 6.0 Cordless Phone ID
D1680-2C How do I shut off the ringer?
On the handset, press down-arrow while in standby mode. On the base, press - while in standby mode. See pages 4 and 6 of the manual.
Apr 08, 2014 | Uniden D1680-2 Expandable DECT 6.0...
How to take my phone off of silent mode
In standby mode, press up-arrow on the handset or the VOLUME+ button on the base to raise the ringer volume. The base and each handset has its own individual ringer setting.
Nov 07, 2012 | Uniden DECT15802 Twin Cordless Phone
How do I turn Silent mode off
Handset: With the phone in standby, use [^] to make the ringer volume louder
or [v] to make it softer or turn it completely off. (where v and ^ are the up down arrows on the phone)
Base: While the phone is ringing or in standby, use [volume +] to make the ringer
volume louder or [volume -] to make it softer or turn it completely off.
Oct 22, 2012 | Uniden DECT 6.0 Cordless Telephone...
How do I silence just one handset uniden d1780
With the handset in standby mode, press down-arrow repeatedly until the bell with a slash through it appears on the display. To restore the ringer, press up-arrow repeatedly to the desired volume.
If you need a manual, you may download a copy here.
Oct 08, 2012 | Uniden DECT 6.0 Cordless Telephone...
Increase number of rings
You can select the desired ringer patterns of the base unit and cordless
handsets. 4 patterns are available for each line. Your phone comes from
the factory set to pattern 1. Programming must be carried out
separately for the base unit and cordless handset(s).
Make sure that the base unit/cordless handset is in the standby mode.
Base Unit Handset
4 Enter the desired pattern using
the dialing buttons ((1) to (4)) for
each line. To move to another
line, press H or I.
• Each time you select a pattern, it
rings.
5 Press (ENTER).
• A beep sounds.
• To return to the standby mode,
press (EXIT).
1 Press (FUNCTION).
2 Press or until the arrow
points to "Ringer setting",
and press H.
3 Press or until the arrow
points to "Ringer pattern",
and press H.
• The current settings are displayed.
Ringer pattern
L1 L2 L3 L4
1 1 1 1
Feb 20, 2011 | Panasonic KX-TG4000B 4-LIne Multi-Handset...
My cordless phone says "to register see owners manual for help" How do I get the phone working, it is a uniden DECT 6.0 Model DECT 1588-2
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Dec 21, 2009 | Uniden DECT 6.0 Cordless Telephone...
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Doesn't anyone have an answer or some help? Please!!!!
Uniden TRU8885-2 Cordless Phone > User Guide E X P A N D I N G Y O U R P H O N E w w w . u n i d e n . c o m Register the Handset to the Base If you purchase an extra handset, you need to register the handset to the base before use. Only one handset can be registered at a time. The handset ID for the supplied handset(s) was assigned at the factory, which has #1 or #2 in the display (#2 for models that have two handsets in packaging). When you register additional handset to the base, the handset ID will be assigned. 1) Before registering the extra handset, the battery pack must be charged for 15-20 hours. 2) Place the extra handset in the main base unit to begin registration. 3) While the handset is registering, Handset Registering will appear in the LCD. When Registration Complete is displayed, the handset has been registered to the base. If Registration Failed appears, please try these steps again. Extra Handset Extra Handset Charger Charger Main Base Extra Handset + Main Base Charge the handset for 15-20 hours. Place the extra handset in the main base to register. 1 2 3 4 ?An extra handset can be registered when the main base is in standby mode. ?Standby Mode - The handset is not in use and talk/flash has not been pressed.
Jun 26, 2006 | Uniden TRU8885-2 Cordless Phone
Philips Zenia Voice Cordless Phone Logo
160 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
