Question about GE X5 Digital Camera
Shutter won't open - GE X5 Digital Camera
Won't stay on
i could be that the rechargeable batter is weak. try replaceing the battery for a new one. also check that the connections for the battery are clearn.
I hope this was useful.
Feb 15, 2013 | Sony Cyber-Shot DSC-P52 Digital Camera
Shutters on the lens won't fully open
Stuck automatic lens covers are fairly. But usually it's very easy to fix, without even opening the camera. See this link for troubleshooting steps for this problem.
Dec 14, 2012 | Kodak EasyShare C633 Digital Camera
In anything but full automatic, the shutter opens but won't close unless I press the shudder release button again
is sounds like you have the shutter set on bulb.. try changing the shutter speed and see if this helps....
Nov 10, 2012 | Canon Cameras
Sony dsc-w190 won't turn on
The system control board has shut the camera down to prevent damage, the lens housing will need to be replaced because you have two problems, one the lens is jammed and second the shutter is open, the cost to repair will be equal if not more than a new one.
Mar 31, 2012 | Sony Cyber-shot DSC-W190 Digital Camera
I have anhp deskjet 3050all-in-one j610seriesi purchased to day my tower won;t open to put soft ware in is there any way to conect to my computer
You mean to say CD reader not opening? Use needle to release shutter lock, insert driver cd in and drivr it for software loading.. check fig for easy understand..any difficulty getback to me..thanks
Feb 04, 2012 | HP Office Equipment & Supplies
My canon powershot SD 1000 will take outdoor pictures but wont take any with low light and the flash won't work. I see that someone else asked the same question but I can see what advice was offered
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Recommend trying the pencil tapping fix listed in the link. It worked on my SD1000 with the same problem.
Jun 04, 2011 | Canon PowerShot SD1000 Digital Camera
Shutter won;t open
Are you talking about the shutter, or do you really mean the automatic lens cover ? Take a look at this first to see if this is what you meant. Make sure you read the comments also for additional tips. I don't think it will be necessary to open it up to fix it. Stick with the easy tips, they should work, especially if this is happening occassionally:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jun 05, 2009 | Canon PowerShot A570 IS Digital Camera
GE X5 Digital Camera Logo
14 people viewed this question
Top GE Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a GE Camera Expert? Answer questions, earn points and help others
