Question about Sega Genesis Console
Sega Genesis not working
I recently got my hands on a Sega Genesis console from a relative. When I hooked it up (all connections were correct and all that) and powered it up, there was a signal going to the TV but just a black screen. Is the console just dead or is there a way to fix it?
It might be dead. I used to have two of them I got from a relative as well and one of them did the same thing. The inside might just be fried (they're old consoles). You could take it to a repair place if you really wanted to but it may cost more money to have it looked at than the system is worth as a whole.
Posted on Jan 08, 2014
  • 20 Answers
SOURCE: no picture for Genesis - RF or console?
The problem is most likely not the console. The first thing you should try is cleaning the contacts on your games. Most of the games have tamper proof fasteners so unless you have the right tools you won't be able to open them. You can take a q-tip with a little alcohol (damp not wet) and clean both sides of the circuit board on the cartridge until the q-tip comes out clean. Let it dry before sticking it into the console. If you do this to a couple of games with no luck try taking an emery board (for fingernails) and gently inserting it into the connector in the console a few times all along the length of it. Make sure to only push it straight in and pull it straight out. If you try pushing it side to side while it is in there you could damage the connector.
Posted on Dec 08, 2007
SOURCE: sega genesis 1993 model broken, no picture, just black
fixed it
Posted on Jul 01, 2008
  • 53 Answers
SOURCE: Problem with the 1st generation sega genesis
If the screen changes (From snow to black or something) when the console is turned on it sound like the console is partially working. Try cleaning the Cardridge pins que tip and some sort of cleaning fluid.
Once this is done insert and eject the cartridge several times then repeat the cleaning process on the cartridge. Hope this helps.
Posted on Jul 11, 2008
jyackle5
  • 8197 Answers
SOURCE: I need hook-up instructions for my 16 Bit Sega Genesis system con
Go to this link.
http://imageevent.com/gamescans/gamemagazines/segagenesismanual
Good Luck
Posted on Jan 23, 2009
DarkWolfBomb
  • 80 Answers
SOURCE: how do i set up my sega genesis
There should be regular av cables and wall adapter for it. Mine came with the wrong cords and that might of happened to you. So if you don't know the av cables go in the back of the tv and plug's in the back of the sega. and the wall adapter goes in the wall. If you don't have the cords than get them off line. Type in:
http://www.amazon.com/s/?ie=UTF8&keywords=sega+genesis+cords&tag=googhydr-20&index=aps&hvadid=2858659671&ref=pd_sl_8zrz6m8bxu_b
cut and paste it online and you can get them.
Posted on Jul 18, 2009
My sega genisis isn't working on my LCD screen
2q== they have videos on Youtube on how to hook Sega genesis version 1 2 and 3 consoles on up to a flat screen tv or any of the newer TV's. I just use a CRT style TV they are much easier to hook up old consoles too. Just buy a CRT tv type then.
Sep 28, 2013 | Sega Genesis 2 Console
Hooking up a sega genesis to a vizio tv
There's a couple ways to hook it to a hdtv...you can use the original one that hooks up with cable wire ..just connect to cable connection on back of tv...switch to channel 3 or 4 on tv...or get the better a/v connecters connect to rca jacks...goodluck
Dec 04, 2012 | Sega Genesis Console
How can I hook my sega genesis console to my Direct tv box?
Don't plug your Genesis into your satellite box. Plug your Sega into the back of your TV set. Get a Sega Genesis composite video cable. Run that cable from the mini-DIN connector on the back of your Sega to the RCA (yellow, red white) connectors on the back of your TV set. If you don't have any spare RCA connectors on your TV set, try a composite video switch.
Aug 20, 2011 | Sega Genesis Console
I cannot figure out how to get my sega genesis to work on my new tv. Is it because it is a new tv or am I just not doing it right.
hey there
regarding with the sega genesis console it only has the audio video cord you just need to connect it to the port and put your TV on the correct video mode because TV's today has multiple video modes like video1, video 2 and video 3
hope this helps
May 18, 2011 | Sega Genesis Console
Sega Genesis Video Problem
Maybe you are supposed to be on Channel 4. There should be a 3-4 switch on your RF adapter. Try wiggling the video connection in the back of your genesis and see if that fixes anything, it might be a lose port, in which case you have to wrap the cable underneath the genesis or something heavy to keep it at a working angle (if you find a working angle).
It is also possible your RF cable is bad. They aren't that much on ebay, but make sure you buy one for your model (there are 2 models of genesis and they use different RF cables)
I hope this helps somewhat.
Jan 07, 2010 | Sega Genesis Console
Need step by step directions to hook up a 16 bit Sega Genesis
There should be two plugs on the back of the sega. One for the power cord, and one for the audio/video cord. The audio/video cord is a coax cord with a little box in line. Hook your cable or antenna cable into the jack on the box and hook the end of the cable from the sega into your tv. There will be a switch on the sega or on the box somewhere that designates channel three or four, this is what channel your tv will need to be on to use the sega.
Sep 23, 2009 | Sega Genesis Console
Sega Genesis Console Logo
111 people viewed this question
Top Sega Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Reggie brown
Frank Zabroski
Frank Zabroski
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
