Question about Panasonic VIERA TC-P42ST30 42-Inch 1080p 3D Plasma HDTV
Tc p42s30 14 blinks, verified, cant find anything in the service manual about it.
    Problem Solver:
  • 6 Answers
Verify that both fans are spinning when you try to power up the unit
Posted on Jan 03, 2014
My Panasonic plasma tv model tc-p50s30 has 14 blinking lights I tested the SU and SD boards and they are good
Are you sure its not 7 blinks then a pause and 7 more as according to the service manual the blink codes for a TV like yours only goes to 12
Feb 26, 2018 | Panasonic Televison & Video
Panasonic TC-P50X1 don't come on, red light blinks 9 times what is the problem
1) try doing a RESET.
2) if that does not work. with most flat TV today. There three circuit boards - an input, a power and a video. Usually, it is the power supply and specifically, the capacitor(s) that goes wrong. It has high voltage (400 volts) but low current.. Replace this capacitor or could be capacitors.
Oct 26, 2017 | Panasonic Televison & Video
Panasonic TV, Model TC-P505U50
Not sure if it is Plasma or LCD/LED model.
Check out the codes below
Panasonic TV Blink Codes for All Panasonic Models Brainchamber Blog
You need to verify the Power board for defective capacitors. You can replace the defective Capacitors yourself if you are a DIY person or replace the entire board if you can obtain the part.
Aug 01, 2016 | Panasonic Television Mainboard, TV Model...
Panasonic TC-P54Z1 flashing image
Please remove all HDMI cables from the TV and test a different power outlet. If the problem persists then we recommend you use the below link to locate an authorized service center.
www.panasonic.com/repair Welcome to Panasonic Online Repair
Apr 21, 2014 | Panasonic VIERA TC-P54Z1 54 in. Plasma TV
9 blinks on panasonic p50X1
9 blinks Panel Config. SOS. Check it. If you wish to get more details, check the site linked here. Pull up older posts.
Dec 02, 2013 | Panasonic Viera TC-P50X1
I have a Panasonic Model TC-P50S1 plasma TV and the red indicator light continuously blinks and the TV never does come on. Can this be fixed?
Panasonic utilizes the blinking light as a form of self-diagnostics, similar to the "check engine" light in your car. If you've ever experienced that, you know that a check engine light could indicate anything from a loose gas cap to a major failure.
Panasonic uses the number of times the light blinks, to aid the technician in trouble-shooting the problem. The blinking light indicates an area of concern and helps the technician to isolate the problem and order the correct parts. This in turn speeds up the repair process, keeps parts cost down, and helps both you and the servicer by allowing the technician to complete a repair in one trip in most cases.
So contact an authorized service center.
May 28, 2011 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
Tv turns on for two seconds, shuts off, begins binking.
The problem is most likely a power supply related problem.
The TV is in protection mode right now. It's keeping the other parts inside the TV from being damaged by automatically turning itself OFF. The 9 blinks should be an error code for the problem with the power supply. I don't have the Service Manual for your TV model number to tell you what the code means and which part to replace. Every brand of TVs have a different meanings of the code.
If you have electronic experience, you can find a factory repair manual over the internet. Normally, it's called a Service Manual. It costs about less than $20.
Jul 31, 2009 | Panasonic TC-26LX70 26 in. LCD Television
Panasonic VIERA TC-P42ST30 42-Inch 1080p 3D Plasma HDTV Logo
188 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
