Question about Tanita BC550 Innerscan Body Composition Monitor Digital Scale
8888 and error - Tanita BC550 Innerscan Body Composition Monitor Digital Scale
How i fixed error 000732-8888
Dear
E732-8888 can be displayed when a different scanner is connected to this machine.(its due to the SCANTYPE value was not set in service mode)
Change the setting values of the following service mode items.
- Service mode > COPIER > Option > BODY > W/SCNR: from 0 (zero) to 1.
- Service mode > COPIER > Option > BODY > SCANTYPE: from 1 to 0(zero).
{(Reference: For the Color Image Reader-E1/F1, this mode has to be set to 0. On the other hand, it has to be set to 1 for the Duplex.
Thanks.
Feb 14, 2015 | Canon irc5185i
Error :8888 in bajaj induction cooktop
Error code: 8888 on my new induction stove please what is the solution.
Nov 18, 2012 | Cooktops
Error code E000732 8888
i have irc5185i it show e000732-8888 pls help me
Oct 06, 2012 | Canon imageRUNNER C3200 Copier
Progress: -------------------------------------------------------------------------- Checking Http URL: http://87.56.179.75:8888 ... Error! Checking Stream URL: http://87.56.179.75:8081 ... Error!...
Hi friend,
We have to open the port numbers in your router for the above eroor check sum,follow the below mentioened steps,
1.Type 192.168.2.1 in the Internet explorer,You will get a belkin router setup page
2.On your left hand side,click on Firewall,it will ask for password,leave it blank and click submit
3.Change it to disabled and click on Apply changes
4.On your left hand side click on Virtual servers
5.Put a "Check mark in 1st box",in "description type as Streaming" in "Inbound port put the numbers 8888" and in the "type select as TCP and UDP" and in "the Private IP address type the ip address of your particular computer in which you are getting this error message" and the Last Outbound port,type the number 8888"
6.The same for the second one but the Type is TCP and the Inbound and outbound port is 8081
If u have any clarification feel free to provide th reply
Regards,
Ayyasam
Feb 27, 2010 | Computers & Internet
I have Canon IR-C5185i. Just assembled out of the box. Powered on. Message displays with error E0000732-8888 and I am instructed to "turn switch off and on". What could be wrong?
When this machine was started after connecting the Color Image Reader-E1/F1, the screen for the shutdown sequence appeared (and E732-9999 was recorded as an error history in service mode). When the main power switch was turned OFF/ON by following the instruction on the screen, the error code "E732-8888" was displayed. When connecting the Color Image Reader-E1/F1, follow the field remedy below.
- E732-9999 is recorded when a printer model detects a scanner for the first time. (This is not an error code but an alert.)
- E732-8888 can be displayed when a different scanner is connected to this machine.
Nov 17, 2009 | Canon ImageRunner 2220N Copier
What is the pairing code for a pama visor mounted
Hello Give this a go
Sunvisor range
PNG8......8888
PNG9......8888
PNG10....8888
PNG11....8888
All The Best Jon Bodley.
Sep 21, 2009 | Cell Phones
Tanita BC550 Innerscan Body Composition Monitor Digital Scale Logo
Top Tanita Health & Beauty Experts
Tre Elkins
Ankit Chandel
Ankit Chandel
Tom Chichester
Are you a Tanita Health and Beauty Expert? Answer questions, earn points and help others
