Question about Philips DVP3020 DVD Player
Eject button - Philips DVP3020 DVD Player
Eject button stuck
Near the eject button (on the same face as the eject button) there should be a pin hole. Use a straigtened paper clip to force the ejection of a stuck disk. It may also work even without a disk stuck. ( I just tried it on the drive of the laptop.)
Oct 14, 2013 | ASUS Computers & Internet
Eject button
Unfortunately there's no eject button. A lot of companies have taken eject buttons off controls and you have got one of them. It's back to walking over to remove it I'm afraid
May 28, 2013 | Samsung AK59-00132A Remote Control...
How do iget the bloody door open tp insert disc
Mac OS 9.2
  • Press the Eject key on Apple Pro Keyboard
  • To open the second optical drive on a Power Mac G4 (Mirrored Drive Doors) computer, press Option-Eject on the Apple Pro Keyboard.
  • Open the Eject application found in the Eject Extras folder. The Eject Extras folder is located in the Apple Extras folder on the CD.
  • Click the iTunes eject button (see Figure 1).
  • Hold down the mouse button when you hear the startup sound as the computer restarts.
  • Start up from Mac OS X and customize the toolbar with an eject button.
Mac OS X
  • In the Finder, Choose View > Customize Toolbar. In the window that appears, drag the Eject button to the toolbar, then click Done. Select the disc you want to eject in the Finder window, then click the Eject button in the toolbar.
  • Press the Eject key on the Apple Pro Keyboard.
  • If you have a keyboard without an eject key, press F12 (under Mac OS X 10.1 and later). Note: You must press the F12 key longer to prevent the tray from accidentally opening.
  • Click the eject button in iTunes (illustrated in Figure 1).
  • Start up from Mac OS 9.2 and follow the options in the section above.
Aug 18, 2010 | Apple eMac G4 Desktop
Cd will not eject from Mac laptop
To eject a CD from a Macintosh, start from power-off. Press the power button, and immediately hold down the trackpad button. Continue to hold the button until you hear the optical drive eject, or try to eject. If the CD does not eject successfully, then it is physically stuck, which is a different issue and requires professional service, which may involve replacement of the optical drive.
Jul 12, 2010 | Apple MacBook Mac Notebook
JVC won't eject my CD!
Turn radio off Push and hold the eject button Turn radio on while holding the eject button.
This is the force eject sequence
Apr 05, 2010 | JVC AM FM CD DET FACE CAR STEREO
Wont eject the game
Unplug it, then press and hold the eject button. While holding the eject button down, re-apply power and turn on the unit. If the unit senses the eject button pressed, it should eject anything in the drive.
Feb 11, 2010 | Nintendo Wii Console
I can't eject a dvd from my mac pro desktop
Try these tips.....usually holding down the touchpad buttton while tapping the eject button during bootup works.
picexporterror Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared.
picexporterror If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar.
picexporterror Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder
picexporterror Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button.
picexporterror Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism.
picexporterror Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray.
picexporterror Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. )
picexporterror If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Oct 24, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I can't get the memory card to stay in the camera. The eject buttom pushes it out.
You haven't said which KM model you have. But on most of them one push on the eject button makes the eject button pop out in order to be ready to use on the second press which ejects the memory card. After pressing the button all the way in to eject the card, the button should latch back into the "parked" postion.
Before re-inserting the memory card make sure that the eject button is already in the parked position. If it isn't then you'll get the problem which you describe.
Oct 12, 2009 | Konica Minolta Cameras
Alpine CDM-9803 Cd Player
You need to visit Alpines' site to download the owner's manual for your unit. In the mean time here is some info from the troubleshooting guide for your error code.
• Mechanism error.
1. Press the "eject" button and eject the CD.
If not ejecting, consult your Alpine dealer.
2. When the error indication remains after ejecting,
press the "eject" button again.
If the error indication still does not turn off after
pressing the "eject" button for a few times, consult your
Alpine dealer.
Note
When the "- - - E" is displayed:
In case that the disc cannot be ejected by pressing the "eject"
button, press the RESET switch (refer to page 4) and
Good luck.
Feb 08, 2008 | Alpine CDM-9803 CD Player
Disc Tray Will Not Eject
Just next to the eject button on the actual recorder there should be a tiny pinhole.  If you use a small paperclip and insert it, then push, you should be able to manually eject the DVD.  Hope this helps!
Oct 16, 2007 | GoVideo Go Video DVD/VCR Combo
Philips DVP3020 DVD Player Logo
21 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
