Question about ViewSonic N3235w 32" LCD TV
Tv signal cannot detect - ViewSonic N3235w 32" LCD TV
2 Suggested Answers
  • 332 Answers
SOURCE: the 19 inch model no
Usually when you get that message it can be one of two things.
1st Check the cable that hooks to the monitor side. Then check it at the computer side. By check I mean to disconnect it an rehook it up again so you no it is seated correctly. On some monitors its hard wired so you cant check the monitor side.
2nd if you have access to a second monitor (after checking the cables on your monitor first). Disconnect your current monitor and hook up the test monitor. If you continue to get the no signal message then you have a defective video (graphics) card and you will need to replace it.
I hope this helps you out, if it does please give me a YES that I did assist you. Thank you.
Posted on Apr 09, 2011
The Netflix screen tells me I am not connected to the internet. What can I do to get reconnected.?
Go to your TV settings.... see if the TV detects the wifi signal.... if not try entering you wifi password to connect.
THE TV NEEDS TO DETECT THE SIGNAL FIRST. If not, try raising your modem to a window sill or a shelf, it may not be getting the signal. If it is getting the signal, call Netflix 800.585.7265....and explain your problem.
Good luck.
Oct 20, 2014 | My Local TV iPhone Apps
Hi, my name is Milan. I have a sony Bravia 55 w950b TV that has lost antenna signal
Sounds like defect is with its tuner itself, as you suspected. Contact any service technician.
Electro help
Sep 07, 2014 | Televison & Video
Hitachi 2006 42HDS69 will not detect signal from dvd or xbox, how do I fix this?
Check the error codes on the digital board, which is visible through the grill in the back where the AC power entry is located. A trouble shooting guide, including the error codes, can be found in the service manual here: http://elektrotanya.com/hitachi_42hdx99_42hdt79_42hds69_chassis_dw2-u.pdf/download.html
In the case of my TV, I had to replace the main digital board. I was able to find one online for about $80 and replace it myself. Once you get the rear cover off the TV the digital board is easily accessible and took maybe 20 minutes to replace. Good luck!
Jun 27, 2014 | Hitachi 42HDS69 42 in. Plasma Television
How do I detect signal strength?
You need a signal strength meter. I remember the ones we used when I was in the TV repair business 30 years ago. I think you are going to have to find someone who installs antennas. The ones that Cable TV installers use have a very high minimum signal indicator and most antennas won't register a signal on that type.
Oct 30, 2013 | Proscan Televison & Video
Windows Media Center can't detect a TV signal from a Sabrent card
If you have hd card, it might be your cable company not providing hd signal. If you have analog card, and have HD signal that will cause it too.
Nov 30, 2009 | Sabrent TV-PCIRC (TVPCIRC) Video Capture
I cant get my tv 2 switch from mono 2 stereo
If it doesn't have a strong enough signal the TV won't detect the stereo signal in the first place. If that happens the stereo option wont be highlighted.
Sep 10, 2009 | LG 42LG50 42 in. LCD HDTV
My TV says NO SIGNAL on tuner...
yes, you may be lucky to just to burnt one of the source/input mode try switching them.
for example use a video cable instead a coax if you still dont get a signal that means the picture uotput board is damage by the storm.
Aug 15, 2009 | Olevia 227-S11 27 in. LCD TV
No signal
do you have another tv ?? so you can test the cable.
sometimes the cable gets corroted by the distribution box and will obstruct any signal or if you do have signal " on another tv " the cable input on your akai is probably broken, if you have the skills try to open it up as see around the cable input box, most common they get un-solder or loose and won't detect any signal
Jan 08, 2009 | Akai LCT2715 27 in. LCD Television
Connecting pc to tv
What you need to do is right click on your deskdop, and select your videocard settings ,,, for example miune is Nivida Display,,,
any way you have to select your, It should automatically detect the tv you have connected and all you will need to do is set it up... if it doesnt detect the tv, there should be an option to detect it for you mine is in tools...
Sorry i couldnt give you a step[ by step procedure, as it varys for different adapters..
Jan 11, 2008 | Televison & Video
AUTO SIGNAL DETECTING NO SIGNAL
Yes, I seem to have fixed the problem on my Akai using some creative google finds. One of two things worked - not sure which:
1. Leave the set unplugged overnight - it must let the electronics reset when the residual charges clear
2. For my Akai (remotes and models vary), hit in remote's sequence quickly - brightness, freeze, menu, enter - this places you in some screen that offers a hard reset option. That didn't work right away, but i did it before the option above and then the set worked again.
My problem was really odd because it worked for the component inputs and you could see the video and TV signals inside the PIP windows, but not full screen as primary input. Why the TV could 'see' the signals in a PIP windows but not detect them as primary I have no idea.
Oct 13, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
ViewSonic N3235w 32" LCD TV Logo
15 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
