Question about Husqvarna 124L 28cc Straight Shaft Trimmer
No spark , but does have spark if you hold the kill switch down
I have a1980 gs 850. i have no spark at the plugs. someone said i should start at the CDI box? How can you test this?
  • Start with new spark plugs. Do you see spark? If not, check the side stand kill switch. It kills the engine so that you don’t start out with the side stand down. If broken or out of adjustment, it would kill the spark. Check for a broken wire at the side stand switch and coupler. Try moving the kill switch by hand. If that doesn’t work then wire a jumper around the switch to bypass it.
  • Check the fuses. How good is the battery? Is the handlebar kill switch on?
  • Check the operation of the ignition switch and all kill switches with a volt ohmmeter. Check the wiring harness. Did a wire come unplugged? Are all wires clean and with solid connections? Any abraded or pinched wires? Is the bike in neutral and the neutral light is lit up? If no neutral light, check the neutral switch and neutral switch wire on center casing.
  • Then, If still no spark, get CDI system and coils checked at the dealers shop.
Aug 15, 2009 | Suzuki GS 400 E Motorcycles
Cant get my 50cc scooter to fire up-no spark. any
  • Do you see spark? If not, check the side stand kill switch. It kills the engine so that you don’t start out with the side stand down. If broken or out of adjustment, it would kill the spark. Check for a broken wire at the side stand switch and coupler. Try moving the side stand kill switch by hand. If that doesn’t work then wire a jumper around the switch to bypass it.
  • Is the handlebar kill switch on? Is it shorted out?
  • Check the fuses.
  • Is the bike in neutral and the neutral light is lit up? If no neutral light, check the neutral switch and neutral switch wire on center or side casing.
  • If still no spark, get CDI system and coils checked at the dealers shop.
Aug 14, 2009 | 2005 Suzuki RM-Z 250
1983 yamaha xj 650 no spark already changed the cdi coil plugs wires and mag pick up what next?
  • Are you getting power to the coils?
  • Check the fuses. How good is the battery? Try a jump start from your car battery.
  • Check the operation of the ignition switch and all kill switches with a volt ohmmeter. Check the wiring harness. Did a wire come unplugged? Are all wires clean and with solid connections? Any abraded or pinched wires? Is the bike in neutral and the neutral light is lit up? If no neutral light, check the neutral switch and neutral switch wire on center or side casing. If still no spark, get CDI system and coils checked at the dealers shop.
Aug 06, 2009 | 1983 Yamaha XJ 650
No spark
Start with a new spark plug. Check the side stand kill switch. It kills the engine so that you don’t start out with the side stand down. If broken or out of adjustment, it would kill the spark. Check for a broken wire at the side stand switch and coupler. Try moving the kill switch by hand. If that doesn’t work then wire a jumper around the switch to bypass it. Check the fuses. How good is the battery? Try a jump start from your car battery. Is the handlebar kill switch on?
Check the operation of the ignition switch and all kill switches with a volt ohmmeter. Check the wiring harness. Did a wire come unplugged? Are all wires clean and with solid connections? Any abraded or pinched wires? Is the bike in neutral and the neutral light is lit up? If no neutral light, check the neutral switch and neutral switch wire on center casing. If still no spark, get CDI system and coils checked at the dealers shop.
Jul 29, 2009 | 1995 Honda XR 250 R
No sparking on a 1979 YZ 125
Check the side stand kill switch. It kills the engine so that you don’t start out with the side stand down. If broken or out of adjustment, it would kill the spark. Check for a broken wire at the side stand switch and coupler. Try moving the kill switch by hand. If that doesn’t work then wire a jumper around the switch to bypass it. Check the fuses. How good is the battery? Try a jump start from your car battery. Is the handlebar kill switch on? Check the operation of the ignition switch and all kill switches with a volt ohmmeter. Also check the wiring harness for loose and/or dirty connections. Look for bad plastic connecton blocks and abraided wires.
Jul 26, 2009 | 2003 Yamaha YZ 125
92 Cb250 Nighthawk won't start
Check the side stand kill switch. It kills the engine so that you don’t start out with the side stand down. If broken or out of adjustment, it would kill the spark. Check for a broken wire at the side stand switch and coupler. Try moving the kill switch by hand. If that doesn’t work then wire a jumper around the switch to bypass it. Check the fuses. Is the handlebar kill switch on? Check the operation of the ignition switch and all kill switches with a volt ohmmeter.
A “very helpful” rating for this answer? Thanks!
Jun 17, 2009 | 1992 Honda CB 250 Nighthawk
My gilera runner has nt got a spark i have changed the magneto flywheel spark plug but still no spark what could it be?
Jun 11, 2009 | 2005 Gilera Nexus 500
Sometimes fires sometimes doesnt
The side stand kill switch can go bad and do this. Check the switch with an Ohm meter. Also, check the wiring harness connections. Fix any loose connections. Check the handlebar kill switch. It can go bad also.
Please rate this answer. Thanks hd87lovetori!
Apr 02, 2009 | 2005 kawasaki KDX 200
Replaced stop switch and it still won't shut off!
While attending college, I worked at a tool rental center and learned many tips and tricks from the mechanics. The problem that we heard the most from customers was that the machine would not start. Your your machine at least starts and runs fine, however will not shut down with the factory kill switch. Many times when replacing the mag. (spark coil) the kill wire would rub against the flywheel and break or over time the conductor wire will break inside the insulation. If you kill switch only has one wire, then all the kill switch does is short the mag to ground. Simple test is to remove spark plug, re-connect wire to plug, touch plug to engine and pull rope to observe spark, then short the tab on the magnito to ground, should be no spark. If you still have spark, coil is defective however good enough to run engine. Kill with choke or pull wire. If no spark with test, make new wire from tab of coil to kill switch or any switch that will short tab to ground. Good Luck
Jan 03, 2009 | Briggs Garden
Husqvarna 124L 28cc Straight Shaft Trimmer Logo
20 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
