Question about RCA L32WD12 32 in. LCD HDTV
I have a RCA tv model L26WD12YX1. It is older... My remote stopped working and I believe it is the infrared part in the television. I have taken the back off the tv and removed and reinserted the cable ribbon for that infrared part. It worked so I replaced back of tv. In the move back to the tv stand, it stopped working again. I believe I can fix it, but I need to know the exact part that I need to be looking for.. Any expert answers??? Thanks guys, I have goggled this to death :-)
Remote not working to change from tv to movie mod what is wrong
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
http://electro-medical.blogspot.com/
http://schematicscom.blogspot.com
Apr 14, 2016 | RCA Replacement for 276045/RC246...
My remote control for Haier tv stopped working, despite good batteries
Nov 19, 2014 | Haier HL32R 32 in. LCD TV
I have Dick Smith LCD TV DVD?TV combination. Model number GE6607. The remote control has stopped working. When you change functions you must press the OK button to get the DVD to play. Given that the DVD...
Nov 03, 2014 | Televison & Video
Why wont a universal remote or regular remote work to my rca television
Check the remote control for its infra-red emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
If remote control is working OK, the fault should be with the infrared sensor inside the TV. Contact any service technician to replace it. If you're trying to use a universal remote control, it should be synchronized with the TV, with set-up code said for TV. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 21, 2014 | RCA Televison & Video
Why would my remote stop working?
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Sep 08, 2014 | Hisense TA42P40M 42 in. Plasma Television
Rca rc1113123 00
If you look at the remote through a video recorder likable maybe a smartphone. You will be able to see the infrared light up. Infrared only shows up on photo or video.
Dec 06, 2013 | RCA Televison & Video
Remote & Buttons on TV not working
There are three chances for this fault. [1]. There is no infrared emission from the remote control. [2] Infrared sensor inside the TV is faulty. [3]. Front panel controls have been locked, using remote control, prior to this fault, and the set was switched OFF by remote control. Check the remote control, for its infrared emission. Try it with fresh batteries. You can see all these faults and related help how to follow. Try this link, and select the site named Electro-help. Pull up older posts there.
Jul 06, 2012 | Televison & Video
Toshiba 32a14 does not respond to remote control
Hello
There is a infrared light sensor inside the TV which detects the infrared rays emitted from the remote control, when we press each button on the remote control. If this sensor has got damaged, the set won't respond to any remote control handset. The sensor can be located just behind the infrared sensor window at the front panel of the TV. To access it, you have to open the TV. It is a three terminal component, will be soldered diretily to front panel circuit board, of with the main baord itslef. Will look somewhat brownish black in colour. There are so many types can be seen . Just look what type if fitted with your TV.
2_4_2012_6_58_45_am.jpg2_4_2012_6_59_07_am.jpg2_4_2012_6_59_34_am.jpgSee some models infrared sensors. Check out which type your TV has.2_4_2012_7_00_45_am.jpg
Feb 04, 2012 | RCA Televison & Video
Code set problem
make sure your tv is and Infrared tv.. if it is there is a chance that the remote just doesn't have the capability to program to it. you should first try getting your original remote control as http://www.replacementremotes.com has many older and hard to find remote controls for RCA TVs.
Aug 19, 2008 | RCA 3-Device Universal Remote with...
RCA L32WD12 32 in. LCD HDTV Logo
21 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
