Question about Acer TravelMate 2300 Notebook
Switching monitors connecting an external monitor
I have an acer travel mate 2300 and i'm trying to connect it to another monitor. I have physically connected them but the second monitor doesn't seem to be recieving a signal. Do i have to change any settings? There doesn;t appear to be a button to switch between the two but i might just be being stupid
  • gavincurran1 May 21, 2009
    Triedthis and doest seem to work any other ideas?
For my Acer 2300.. found in Control Panel an icon for the actuall display card and within there discover Ctrl, Alt -F1 for external, Ctrl Alt -F3 to go back to the notebook monitor. Hope that can help someone.
Posted on Oct 13, 2011
  • Acer Master
  • 4,806 Answers
Hi there.
Hold down Fn and look across the F keys for 2 TV icons, when you find that key keep tapping it until it switches monitors.
Please post back with the results and thanks for using FixYa!!
Posted on May 21, 2009
  • Lee Hodgson
    Lee Hodgson May 21, 2009
    Hi again.
    The keyboard toggle is Fn-F5, if this is not working open a txt document and check the keys to make sure they work.
    Good luck
Is it possible to connect the Acer travelmate 2300 series to the monitor after connecting what can I do is there any functions key to works the monitor
If you connect the monitor, power on the monitor then boot the laptop, it should default to the external monitor.
Jan 04, 2016 | Acer Computers & Internet
My acer travel mate 2000 powers up fine but the monitor is black any solutions?
You can try this:
-Turn off
-Remove battery and remove ac power cable
-Hold down power button without cable and battery for 60 seconds
-Connect your power cable and push power button
Try with another monitor if possible. It may be motherboard issue or bad connectors.
Jun 04, 2015 | Acer Computers & Internet
I have taken the hard drive from my laptop, a acer travell mate 2300 and I am trying to find a connection on it so I can access some of the information. Help
Connect your laptop's hard drive to an USB hard drive adapter then plug this adapter into the USB port of a working computer.
The computer will see this USB adapter/hard drive as an external storage device. You can then open the various folders and files on this hard disk and copy and or backup your data.
Dec 15, 2011 | Acer Computers & Internet
Cannot get the Fn-F5 to work on Acer AspireOne
You can switch to anexternal monitor by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
Nov 10, 2011 | Acer Aspire One PC Notebook
My notebook is acer travelmate 4000. I connected the external monitor with vga port but the result is blue on external lcd TV. I did the step for display setting but I could not find the dual monitor in...
Please try to configure to the graphic Properties.
found at the task bar or at the control panel.
Enter to the device and set use Multiple Display.
This feature available to the Inter (R) Extreme Graphic.
Jul 13, 2011 | Acer TravelMate 2300 Notebook
I have got acer aspire net book size is 8.9 inch. Ca i connect it to external monitor
Hi.
Sure you can with a standard VGA video cable.
Maybe you will have to change your screen resolution to get the best display layout.
Hope it helps!
Feb 10, 2011 | Acer Aspire One AOA150-1784 Netbook
How do i use external monitor with acer aspire 5516-5474
look for the 9 pin plug similar shape to that on the monitor but female.. check the rear of the laptop (plugs) and match the plug to the socket. The laptop will automatically connect and display once the plug is mated.
Please rate my help++++Thanks for usimg FIXYA
Nov 16, 2009 | Televison & Video
Power On / No Boot
Is it POSTing? Do parts make noise and then theres a Beep? The beep means it finished the Power On Self Test. Once it posts then it will show splash screen or black screen with it testing hard drives disk drives etc.. If no post is the led lit that says A/C is connected? before you attempt to turn on? If no post and good ac to rear connector then you probably need a new motherboard.
James Mac
Aug 31, 2008 | Acer TravelMate 2300 Notebook
White screen
This could be caused for a number of reasons. First thing to determine is if the computer is bad or just the screen. Hook up a external monitor to the laptop and turn it on and use the FN key to turn on the external monitor port. If the computer is running fine with the external monitor then you have a bad LCD or LCD inverter. which is replacable but expensive.. you would want to look at getting a new laptop or using it with the external monitor.
Jan 18, 2008 | Acer TravelMate 2300 Notebook
Acer travelmate 4500 screen problem
if u have two memmory stick.try to boot with one..if it not ok try it with other one...
Nov 30, 2007 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
535 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
