Question about Pride Health & Beauty
Red light on charger only lights up not yellow light
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 105 Answers
\is battery low? if it isnt the yellow lite will not come on
Posted on Jan 26, 2014
  • ernest a fleming
    ernest a fleming Jan 26, 2014
    also u may need a new charger have it checked at a automotive parts store for free
3 Suggested Answers
wcdoc1953
  • 280 Answers
SOURCE: While charging the red and yellow light is on and
Sounds like you might have bad batteries. It is OK for a battery charger to get warm as it charges batteries, but getting hot indicates the charger is working too hard charging poor/old batteries. Do a load test on the batteries with a load tester or use a DVM at the charging port on the joystick. I can provide more specific information on how to do this. There are other more specific, easier checks looking for disconnected or loose battery connections, disconnected/broken cables, etc. The on board chargers for this model were very problematic with issues including drive inhibit and outright failures with the early black Soneil versions. The new CTE chargers are much more reliable. Hope this helps.
Scott
Posted on Oct 24, 2010
  • 3 Answers
SOURCE: charger does not seem to
How old are your batteries? Have they been charged regularly? (ie: every night) I have a hunch it may be a battery problem rather than the charger. The batteries should be load tested with an automotive load tester, or you could take the batteries to a local service station to have them tested. If they test poorly, both batteries need to be replaced.
Posted on Sep 06, 2011
I have an HP8402B battery charger. Its plugged in but no red or yellow light and no fan. The plug is getting power. Can you help.
I'm sorry to hear that but if no lights are coming on it means the charger is usually dead. You will need to replace it. It will be very difficult to find someone to repair it.
Sep 21, 2014 | Health & Beauty
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
Pronto M6 chair will not work. When the power switch is turned on, the LED light flash Red followed by three Green. I can't find what this error code meas.... Pls Help thanks Phil
Phil the red means battery is low and the green is a speed limit code because of the low battery if you have charged your batteries and you still get the red then you need to check the charger after charging all night does the yellow light on the charger turn green? if when you first plug in the charger if the red light is on and the other light is green then there is a problem with the wiring or connection to the batteries from the charger and you aren't charging the batteries. if when you plug the charger in and you get a red and yellow light then the charger is working but you don't ever ge a green light and the battery level gauge is still showing red then you need to replace the batteries Hope this helps
Apr 12, 2011 | Invacare Supply Group Pronto M61 Standard...
Yellow and green light are on but wont charge battery?
If both lights are on and both are flashing the charger is reading the battery as defective and the charger won't charge the battery. If the Red light (yellow if plastic is faded) is on and the green is flashing the charger is trying to charge the battery. If the battery won't charge replace it.
Dec 21, 2010 | Ryobi Multi-Volt Battery Charger
Battery discharge quickly, I have replaced new batteries and module control and problem still exist.
Don your charger is probably not charging the batteries. When you charge your chair overnite the charger should have a red and green light showing charge complete. When you first plug it in the lights should be red and yellow. If you are getting a red and green light when you first plug it in then there is a problem with the charger or with the charging circuit to the batteries. You should have a charger port on the battery box try plugging the charger into that port and see if you can get the batteries charged. When you do you should have a red and yellow light on the charger changing to red and green when fully charged. Hope this helps
Nov 07, 2010 | Pride Go Chair Travel Power Chair
How do I know when the chair has charged? I see one red, two green, two yellow lights on.
If you have an off-board charger that plugs into the joystick there are two lights on the charger one red(power on) and the other yellow (turns green when fully charged). Plug it into the chair and if the light is green then you have fully charged the batteries. Now if you have the on-board charger the charger meter on the rear of the chair will resd zero when fully charged. Hope this helps ya
Aug 18, 2010 | Electric Jazzy 1115 Power Wheelchair
Green & Yellow light on 14.4V charger
It sounds like your battery is bad.
If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
Nov 24, 2009 | Ryobi Multi-Volt Battery Charger
Health & Beauty Logo
54 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
