Question about Canon PIXMA MP470 All-in-One Printer
False paper jam error message Canon MP470 - Canon PIXMA MP470 All-in-One Printer
thumu
  • 69 Answers
SOURCE: False Paper Jam
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to Paper Jam error messages even though there is no paper jam in printer . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
This issue could happen if there is an issue with any small paper jam in the Printer, or due to the communicational issue .
To isolate the issue, I recommend you to perform below steps.
Steps are:
1. Power OFF printer and then please Disconnect the Printer from Computer and then disconnect the Power cable of Printer from wall outlet.
2. Check thoroughly in Printer that there is no small piece of paper in the Printer.
3. Let the Printer be disconnected and idle for 5 minutes.
Meanwhile please perform further steps on Computer.
  Note: The below steps are applicable if you are using WINDOWS 2000/XP/VIsta Operating system in  your PC
  Steps are:
 Perform the below steps to restart the print spooler :
1. Click Start>Run
2. Type services.msc
3. Click OK
4. A Window will pop up with so many services listed.
5. Scroll down to locate "print spooler" in the list, right click on it and click "Restart"
6. Restart the Computer.
Once if you are done with steps, please connect the Printer and then Power ON Printer and check the issue.
This should resolve the issue for you.
 If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I'll be glad to help you.
Bye.
Posted on Oct 20, 2007
TIPS72
  • 369 Answers
SOURCE: Canon MP610 - Paper jam error message
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
Posted on Jan 04, 2009
SOURCE: Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Posted on Feb 01, 2010
pineworks
  • 4041 Answers
SOURCE: how to fix paper jam on canon MP470
Hello there
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 14, 2010
SOURCE: Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Posted on Jan 09, 2011
ERROR 5100
Follow the steps mentioned below:
  • Press ON/OFF switch to reset the multifunction device
  • Remove Packing Material / paper jam MP470
  • Reseat ink cartridge MP470
  • The MP470 may require repair
  • You can get the detailed troubleshooting steps from the link below:
    http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp470#ServiceAndSupport
    Jun 24, 2011 | Canon PIXMA MP470 All-in-One Printer
    My printer keeps giving a false paper jam error message. How do I fix it?
    This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
    Dec 06, 2010 | Canon Office Equipment & Supplies
    I have an error code 5100. It started grabbing the paper wrong and a piece got jammed. I removed it and then it says error 5100. I have turned it off and on a few times and it is still there.
    Nov 04, 2010 | Canon PIXMA MP470 All-in-One Printer
    I have a Canon MP470 that pulls 1/2 sheet paper and then jams
    Paper feed roller
    cleaning
    When paper does not feed
    properly.
    To clean the paper feed
    Machine button
    Oct 07, 2009 | Canon PIXMA MP470 All-in-One Printer
    Error message about a paper jam won't clear. There is no paper jam.
    Unplug the power cord and data cable for a few minutes, then turn it back on. If that doesn't work, open every door, remove all paper and make sure there are no other obstructions (I once found a twist-tie in mine, so you never know).
    Aug 16, 2009 | Canon PIXMA MP470 All-in-One Printer
    Canon MP470 printer jam error
    hi...open the printer then clean..i think theirs a lot of DUST that's why printer said paper jam
    Jun 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
    Paper jam message
    Check to see if you have a door in the back of the printer. Your jam could be there.
    If this helps you, please rate me. Thanks, Patty
    Nov 29, 2007 | Canon PIXMA MP470 All-in-One Printer
    Canon PIXMA MP470 All-in-One Printer Logo
    42 people viewed this question
    old marine
    old marine
