Question about HP Photosmart C5180 All-In-One InkJet Printer
C5180 0xc18a0307 can any help me with this error?
  • vlad_robas May 21, 2009
    doesen't work to press those 4 buttons and then restart printer
  • vlad_robas May 22, 2009
    Solved!
    turn on then press left arrow and settings (wrench)
    on screen apears ''enter special key combo''
    press''ok''
    on screen apears:
    uiaux
    Support
    go to system config menu and press ok
    on screen: hardware failure status and press OK twice
    that's it
    g luck
I tried many things to solve my same issue. Found a little more details on Solution #1 and it worked. More info also at http://www.fixyourownprinter.com/forums/printer/54155#15
1. be sure to press "OK" and "HELP" buttons down while you unplug the printer.
2. KEEP the buttons pressed (just to be safe) while you plug the printer back in. You may also need to press the POWER key to turn the printer on. The printer will then power on and do some mystery stuff ... and then it will automatically power down. DON'T release the buttons until the printer's powered down.
3. Release the buttons and power it up
Note: I got a message then about "illegal shut down" but after I pressed "OK" all was fine and I can print again =) I have the C5180.
Posted on May 21, 2009
Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in. follow instructions on the printer display
2 Suggested Answers
Basti
  • 1447 Answers
SOURCE: Error with Photosmart C5180
where are you getting the message from the computer or from the printer? pls do a self test and if self test works, trash and reinstall the driver:
selftest- just copy something using the copy option
Posted on May 02, 2008
How do i fix error code 42 on my cellphone? Help! Ive tried everything!
How to Repair Error Code 42 ' Windows Error Support - Error Tools
errortools.com/en/drivers/how-to-repair-error-code-42/
  1. Cached
  2. Similar
Code 42 Error is referred to as a Device Manager Error code. Before we explain what this code indicates, it is important to understand what 'Device Manager' is and its functions. Device Manager is basically a Windows tool that helps manage devices attached to the system such as the Printer, Scanner and the USB Device.
Error codes in Device Manager in Windows - Microsoft Support
https://support.microsoft.com/en-ca/help/.../error-codes-in-device-manager-in-windo...
  1. Cached
Lists the error codes that may be reported by Device Manager and the possible resolutions in Windows. ... Manager. If you are getting an error code that isn't listed here, you can contact the hardware device vendor's technical support or Microsoft Support for help. ..... Code 42 "Windows cannot load the device driver... (Code ...
ERROR CODE 42 - Boost Mobile Community
https://community.boost.com.au/t5/Setup-Phone-Support/ERROR-CODE-42/.../20989
  1. Cached
Sep 3, 2017 - 1 post Help! I can't send or receive text messages! It keeps saying: Error code 42 I can't call or receive calls either and I know that my bill isn't due.
Instructions To Fix Windows Error Code 42 - Error.info
https://www.error.info/windows/bus-driver-42.html
  1. Cached
  2. Similar
About the Error. The Windows error code 42 indicates the fact that the operating system has detected a duplicate device. This is usually caused by a sub-process that the system accidentally named incorrectly. Windows code 42 - Read what really helps. Though Windows error code can sound quite intimidating, fixing the ...
Dec 14, 2017 | Cell Phones
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
    LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
    Select
    Use our model number finder
    Choose your product type
    Common model number plates
    Close
    LG Refrigerator Error Codes
    These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
    Er FS Error Code
    Er rS Error Code
    F dS Error Code
    r dS Error Code
    Er HS Error Code
    Er IS Error Code
    Er SS Error Code
    Er rt Error Code
    Er It Error Code
    Er gF Error Code Error Code
    r dH Error Code
    Er IF Error Code
    Er FF Error Code
    Er CF Condition
    Condenser fan motor is defective Check/Repair
    Condenser fan motor, wiring or the control board Shop Parts
    Condenser fan motor, Power control board, Wiring harness Error Code
    Er CO Condition
    Communication error Check/Repair
    Communication error between main board and display board Shop Parts
    Display control board, Power control board, Wiring harness
    Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
    Ricoh mpc 6000 sc 670
    Engine startup error - sudden communication reset between controller and VBCU 7/29/2008 Helpful SC 670 Engine startup error - VBCU defective 7/29/2008 Helpful SC 670 Engine startup error - VBCU installation incorrect 7/29/2008 Helpful SC 670 Engine startup error - LCT lift tray sensor was shorted 9/2/2008 Helpful SC 670 Engine start up error. Check main power supply, cn 409 for 5volts 7/20/2009 Helpful SC 670 Engine startup error - Replace laser unit and follow SP adjustments after laser unit replacement 4/5/2010 Helpful SC 670 Engine startup error - IOB board defective 6/8/2010 Helpful SC 670 Blown fuse 2 on VBCU due to shorted harness in registration motor harness 6/8/2010 Helpful SC 670 Engine start up error - Check wiring for df feed in cover.. 8/6/2010 Helpful SC 670 Engine startup error - Replace finisher main board 10/26/2010 Helpful SC 671 Controller mis-match error - Install correct controller b
    THIS UNIT IS VERY HARD TO WORK ON YOU NEED A SERVICE CALL, GOOD LUCK! -Carl
    Mar 31, 2015 | Ricoh Office Equipment & Supplies
    Error 0078 775vm800
    if you want to know what this is the error code is related to
    click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
    extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
    you might be able work your way through the problem
    hope it helps
    im not sure if this is free
  • Fix Error Is
    How To Fix Error Is In 2 Min, Follow These 3 Steps Now!
    ErrorIs.EasyFix.org
  • if you need more help with this post a reply with the error message details
    hope this helps
    Jul 12, 2012 | Asrock 775VM800 Motherboard
    Sir, there is an error i.e system error e225 in my canon mf 4350d machine please help me shut out this problem
    Sir, there is an error i.e system error e225 in display my canon mf 4350d machine please help me shut out this problem
    Apr 11, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
    Cannon ir 3530 all error code and solution
    Code Error name/description
    E000 fixing overheating
    E001 fixing assembly overheating
    E002 fixing assembly low temperature
    E003 post-standby fixing low temperature
    E007 fixing film rotation error
    E010 main motor rotation error
    E014 fixing motor rotation error
    E019 waste toner case full, waste toner case full sensor error
    E020 toner clogging between sub hopper and developing assembly
    E024 developing assembly connector disconnection
    E025 hopper motor, bottle motor error
    E032 NE controller counter error
    E064 power supply voltage error (high-voltage)
    E100 BD interval error
    E110 scanner motor error
    E191 communication error for high voltage power supply
    E202 CIS home position detection error
    E225 CIS light intensity error
    E227 reader unit power supply error
    E248 backup memory error
    E261 zero-cross signal error
    E315 image data error
    E400 feeder communication error
    Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
    SYSTEM ERROR
    error 610 machine kyocera km-3035 ????
    Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
    Please help me to fix below mentioned errors
    More info needed. What are you scanning and scanning with what? What OS?
    Feb 14, 2008 | Computers & Internet
    HP Photosmart C5180 All-In-One InkJet Printer Logo
    407 people viewed this question
    Seeker5211
    Seeker5211
