Question about Singer Inspiration 4206
Needle is not moving
Hello, I am experiencing a rather debilitating problem with my machine. When the foot peddle is pushed down, the needle does not move. I have replaced the belt thinking that it was stretched but it's doing the same thing as before. The piece jutting out of the motor will not spin unless it is on the bobbin winding setting- at which point the cog on the motor seems to become engaged. I can turn the hand crank and move the needle that way... Help!
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Singer Expert
  • 631 Answers
Of course I have to guess here--not seeing the machine, but it appears that your motor is working fine. That would leave two possibilities, I think. The first is a defective foot pedal. The second is, when you push the bobbin winder, it engages a clutch that diverts power from the needle shaft to the winder. It is possible that the clutch is stuck. To find out, disengage the bobbin winder and press the foot pedal, and see if the bobbin winder spindle is still spinning.
Posted on Jan 18, 2014
akylas
  • 26 Answers
SOURCE: How do you change the belt on a Singer 7462?
By removing the top cover, or the turning wheel cover,
you will be able to see the belt.
If the belt is not broken, then try to adjust the belt tension,
by adjusting either the height of the motor, or the tension wheel.
Posted on May 28, 2008
  • 2976 Answers
SOURCE: needle is moving when bobbin is winding & lights are flashing
Check the clutch at the knob on the right side of the machine, where you tighten it to sew & loosen it to wind a bobbin. It could be very loose and when you start to wind a bobbin, it tightens itself up.
Posted on Apr 06, 2009
louislevel_2
  • 374 Answers
SOURCE: my needle keeps moving while I try to wind my bobbin
hi there,
the hand wheel and clutch should be disengage so that needle will not move also w/ the bobbins,doing this is hold the hand wheel then grip hold also at the center hand wheel.rotate center counter clockwise to release clutch.other type is push and pull hand wheel.any of them,try to run machine if needle is move again.cheers have a nice day don't forget to rate me.
Posted on Apr 07, 2009
bargainbox
  • 1388 Answers
SOURCE: my 8280 modle singer: I sewed a zipper for a
If you are not able to free this easily, you really should consider taking it to a service technician to look at it in case you do more damage to the needle bar and elsewhere trying to fix it yourself.
Posted on Sep 08, 2009
  • 1788 Answers
SOURCE: My very old manual singer
When was the last time that you oiled your machine? Sometimes, they just need a good oiling. Another thing to check is your belt. I don't know what Singer you have, but you probably can download a free manual at www.singerco.com and see if there is a solution there. Good luck, I hope that you don't have to take it in for service because that can be expensive. I ended up ditching my old one for a new one because it would have been too costly to fix. I ended up buying a Singer at JoAnn's for $199 on sale (model 7258) and it sews like a dream, way better than my old one ever did. And I find excuses to use the new one because it is so darn easy. There are cheaper models out there too. You really have to make a decision yourself, if it is worth it.
Posted on Oct 23, 2010
Motor is running but the needle doesn't move up and down..
gears not engaging. It should have a peddle for the foot from what I remember. Bad switch
Just a guess to be honest because both hands should be needed to move the cloths
Sep 28, 2015 | Singer 3321 Talent Sewing Machine
I have a empisal celebrity 550 masjien its 2 months old as you put your foot on the peddle the motor runs but the needle doesn't go up and down but it goes up and down if you turn it by hand
check to make sure the foot pedal plug is securely pushed into the machine, sounds like a wiring problem between the foot pedal and the machine, if it keep happening the machine needs to be checked
Jun 08, 2015 | Sewing Machines
Nothing happens when I push the foot pedal
Please check the Stitch regulator & Presser foot lifter.
Jan 03, 2014 | Singer 7442 Mechanical Sewing Machine
Singer prelude manual
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number
Click search
Jan 15, 2012 | Singer 8280 Mechanical Sewing Machine
My machine beeps and will not sew when the foot peddle is pushed. i checked the BH lever inside the light cover and the small black switch appears to be in the up position. any other ideas?
make sure the foot pedal cord is pushed in correctly
rethread the machine top & bobbin
clean under the needle plate where the feed dogs are for lint
also clean the bobbin are for lint or loose threads
change needles
but also the foot pedal could have gone out
Nov 19, 2010 | Singer 7422
When I turn my machine on the presser foot does
This does not sound good, you may have a failure in the eletronics. However it could be a loose connection inside the machine too. I think you need to see a service tech.
May 24, 2010 | Husqvarna Designer I
My machine has power, but foot pedal only makes needle go slowly
sounds like the contact in the foot peddle has failed try a new peddle
Jan 02, 2009 | Necchi 3101 Mechanical Sewing Machine
Needle doesn't move the problem isn't the foot pedal
I have a Husqvarna #1 that I also love. My needle stopped moving too. I was convinced it was the foot peddle but a repair person sais it was not. I discovered on my own that indeed it is the cord on the foot peddle. I suspect it has a loose wire because when I wiggle it where it connects to the machine it starts working again. Right now this is what I have to do because I can't find a replacement peddle. Can anybody help me find one?
Jul 06, 2008 | Husqvarna Viking 1
Singer Inspiration 4206 Logo
166 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
