Question about Toshiba Satellite A105-S4004 Notebook
LCD display problem
I have Toshiba Satellite A105, when i turn on my notebook while booting it display me grey screen and system is booted it display me dark orange screen.
Do i need to replace my LCD or this is some other problem.
I tried to fix it out by changing graphics properties but it doesn't work
  • Anonymous Nov 07, 2007
    My toshiba screen will start to flash after about 15 minutes of use. It flashes on and off then turns into a black screen with thin grey lines.
My Toshiba Satellite does a similar thing, It goes gray while I am working on it. The only way to continue to work on it is to complete shut it down manually and reboot. I took it to Toshiba they said nothing was wrong.
Posted on Oct 19, 2007
My Toshiba Satellite A105 was accidentally dropped on the floor. When I turned it on and after choosing "HDD" from the Boot Menu, the screen would display this: PXE-E61: Media Test Failure,...
Sorry but Unfortunately Hard drives (HDD) are very susceptible to physical shocks and can be damaged that way. It may be possible to take it to a repair center to see if they can salvage some of you data but their are no guarantees.
If you found the information helpful please rate my response.
Aug 07, 2011 | Toshiba Satellite A105 Notebook
My Toshiba satlelite A105 will not boot up , comes up on screen black says pxe-e61: media test failure, check cable pxe-mof: exiting intel boot agent operating system not found
Go into SETUP (F2, DEL, Cntl-S or somesuch at boot time - or hold F1 key down and force and error and then change your BOOT order to CDROM, HDD. It is Currently NETWORK, CDROM, HDD or the like.
PXE is Network directed bootup, and your LAN connection is waiting or the proper code or instruction or server. You need to turn that off, and BIOS SETUP is where to do it ;-)
Hope that helps
Apr 08, 2009 | Toshiba Satellite A105 Notebook
Toshiba Satellite Laptop refuses to allow Dual Monitors
I have an A105 set up on dual screens, and it works great. As I recall, you have to do the dual screen setup in the control panel, display, settings.
Mar 17, 2009 | Toshiba Satellite A105-S4074 Notebook
Toshiba Satellite A50
When the system boots hit the BIOS key F2 and in the setup select boot from CDROM and press F10 and exit, Insert the bootable CD and boot the system
Jan 06, 2009 | Toshiba Sattelite A105-S2071 Notebook
Display
If you've got exacttly the same each time you're start, then the VGA card has issue, or even the motherboard and CPU.
If not then try to chock the base of the screen with two fingers when starting, if nothing happen try to chock the middle of the keyboard and several spot around it. (it's a little bit brutal but the easiest way to find a bad contact or dead components)
If you feel like open it then this website will help you:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
and for the screen:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
good luck
Dec 16, 2008 | Toshiba Satellite A105 Notebook
Toshiba satellite A105-S361
the inverter maybe going bad. go to ebay get a cheap toshiba satellite a105 lcd inverter.bam the problem fix oh you would need a screw drivercause this is a diy project no need tosend it out link me if anything bakerandre2000@yahoo.com
Apr 14, 2008 | Toshiba Satellite A105-S4004 Notebook
Toshiba satellite A100 Monitor problem
LCD issue it needs repair..call tosh if your laptop is still in warranty
Feb 01, 2008 | Toshiba Satellite A100-ST3211 Notebook
Toshiba Satellite A105 grey screen
just replace screen pop top off unscrew it out and unplug it put new one in and do u have latest video card drivers installed make sure u do that also
Jan 05, 2008 | Toshiba Satellite A105 Notebook
LCD Display problem
THE WIRING OF UR SCREEN IS DAMAGED GET IT REPAIRED BY A PRO
Nov 24, 2007 | Toshiba Satellite A105-S4004 Notebook
Blanck Display
Don't forget that there is a switch that toggles the display from internal to external display (possibly Fn+F5).
Sep 05, 2007 | Toshiba Satellite A105-S4004 Notebook
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
247 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
