Homemaker washing machine
Spin cycle not working
  • 1294 Answers
SOURCE: GE Washing machine won't spin in rinse cycle
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Posted on Sep 12, 2007
wagdom
  • 64 Answers
SOURCE: indesit wg1130t front loader washing machine
maybe the drive belt is off/broken. Take the back off to check
Posted on Oct 31, 2007
  • 686 Answers
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Posted on Apr 04, 2009
BIKER T
  • 909 Answers
SOURCE: spin cycle is off balance washing machine is
i dont believe it is the agitator per say. Assuming this problem has just started and doesnt have transportation bolts still attatched. Two conditions cause the imballance. 1)(if unit is a top loader) Check if all 4 shock absorber springs are well lubricated and not sticking. 2)A more involved problem which often happens, Underneath the washer, is the drive motor. on the motor, is a round pulley. this pulley needs to come off and strip further until you see a long spring. If it is not broken, clean it up using a solvent and a rag. reassemble and test. (if spring is defective, it will slip instead of grip on a spin cycle.
Posted on Sep 17, 2009
SOURCE: frigidaire washing machine no spin cycle
I had the same problem with my Frigidaire Affinity front load washer. It would go through the wash cycle but would not do the final spin cycle that takes the access water out of the clothes. It would actually cut off when it got to be 6 minutes left. I checked the hoses, belt, motor and pump but all were functioning properly. I even cleaned out the filter thats located in front of the water pump. It was full of coins and other debris but it still didnt fix the problem. I called the repairman and he concluded that the control board was bad and would have to be relaced. The board is $200 and labor $140. It will cost you $340 dollars to correct this problem unless you know how to replace the control board yourself. Only had the washer for 3 years. I wouldnt expect something like that to occur within that short period of time.
Posted on Sep 22, 2009
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
Homemaker hmwm 6000 cannot find a replacement belt
The Homemaker machine you have turns up little helpful information when searched. If all you need is a belt, you should bring the broken / worn belt (and all parts if broken in several pieces) so that it can be measured to determine the proper length and width, number of ribs, depth, etc. when you go to an appliance store or even autparts store (I have no idea what your belt looks like so I can't suggest one over the other). Many times, these machines have a spring-loaded pulley that is used to reduce slipping as the belt stretches / wears. This makes it possible to use a belt that is "close" length.
Mar 11, 2014 | Washing Machines
Homemaker 5kg washing machine wont spin
<img src ='http://yoogya.com/ref/i4.jpg'></img>
Oct 24, 2011 | Washing Machines
I am in Perth WA and I need a fan belt for my washing machine as it snapped my washing machine is a Homemaker HMWM8000. I would like to know where I can purchase the belt and the price. Thank you,
Hi, I have the same problem. I rang KMart who advised they don't stock washing machines anymore but gave me the manufacturer's number which is 1300 366 155. I rang them and they said it is probably a generic belt which you could purchase from most repair shops, but you can purchase them through Homemaker. They were going to charge me $20 and it would take 7-10 working days to deliver. I am trying to source locally (Albury, NSW) as it may be cheaper if it's generic.
Hope this helps.
Apr 27, 2011 | Washing Machines
Kenmore washing machine didn't spin @ end of cycle
If you tried a different cycle and it worked this means that the timer is probably bad on the main cycle that you use. If the machine does not spin on all cycles, then please check out the LID SWITCH.
Nov 12, 2009 | Washing Machines
E2 error on homemaker washing machine. I have tried eveything including reducing load down to one item. It goes through the wash cycle OK, but will not drain, then eventually flashes the E2 error on its...
I have an E2 error on the display of a homemaker washing machine model no HMWM8000. It will not pump out. The PCB does not have any visibly damaged components, which part is faulty, and how do i test a water level sensor.
Sep 13, 2009 | Washing Machines
Homemaker 5kg washing machine blocked drain
Could the block be in the wall drain.............
Dec 04, 2007 | Washing Machines
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
