Question about Kitchen Ranges
I was using the oven when it made a real loud bang. I thought I had put metal in the microwave it was so loud. After the bang the oven died. I have checked the element and it looks fine...no white dust or cracks....any ideas
  • 1,543 Answers
This was most likely the oven liner "oil canning" due to thermal expansion. If the liner remained in this position, you will probably not experience the noise again. If it returned to it's original position when it cooled down, you may experience the noise again. Although alarming, it is by no means dangerous.
Posted on May 21, 2009
Arcing and bang noise
The arching is probably to the cabinet where paint is missing. This usually occurs at the edge where the microwaves travel into the cabinet. You can get microwave paint from your local appliance parts supplier. It's special paint that is non - conductive.
May 17, 2014 | Sharp R959SLMA 900 Watts Convection /...
My samsung microwave oven is pouring out smoke when in use it made loud pop or bang the other night when using it and when i open the door gray smoke came poring out
Sounds like some metallic object was in the microwave oven when it made a loud bang. Was there a piece of aluminum foil or any metallic object inside when it happened? or the container you used, does it have some metallic linings or decorations?
Nov 05, 2012 | Samsung Stainless Steel 1.7 Cu Ft Over The...
My JVM1350 has metal rack inside. How do I use it. I thought you couldn't have any metal inside.
on the inside of micro.. the rack is supported with plastic clips.. this allows stock part metal rack work
May 26, 2012 | GE JVM1350BW/WW/AW/SY Microwave Oven
Loud bang on startup
From the description it is the magnetron, "heart of the microwave" on the verge of failure.
Mar 31, 2012 | Microwave Ovens
Heard a loud bang from the microwave and now it wont work ??
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 24, 2010 | LG LMA2111ST 1150 Watts Microwave Oven
Went to heat something up hit 30 seconds and microwave just went off..no power..won't turn on..
this is the normal way they die,,they some times go with a bang and some times go with a wimper,,this one went with a wimper,
its most likly to be a fuse blown but why did it blow??? they just dont do that unless there is a fult in them
however the fuses are not normal type fuses and trying to get to them your putting yourself in grate danger,, there is a very big capasitor inside the microwave its a real killer too, holding 1000,s of volts,,,,,,,,, tuch it,,,,,,, and your dead!,,,,,, be warned,,,
Mar 14, 2010 | Sanyo EM-P672W Microwave Oven
The oven sparks and gives a loud hum during use with plastic food containers. This scares my wife and mom terribly. I have an Emerson 900W microwave oven (model:MW8999SB).
It seems as though the container has a small amount of metal embedded in it ... don't assume just because it is plastic you can put it in the microwave.
Tip ... put just the plastic container in empty and try it. If the plastic get hot then it's the wrong type plastic for a microwave
Oct 02, 2009 | Microwave Ovens
Microwave leak
Cell phone frequencies (380-1900 MHz) are far lower than a microwave's output frequency (2450 MHz), so all cell phone frequencies will pass through the metal RF mesh in a microwave's door glass.
Your microwave is fine.
Somebody's pulling your leg with this "test".
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Aug 03, 2009 | LG MV-1444Y Microwave Oven
Loud Bang, then Light Stays On, Can't Cook
Something has failed in the high voltage supply to the magnetron. There are no user serviceable parts inside, but there are INSTANTLY LETHAL voltages present. Scrap the oven & get a new one, they are generally not worth reparing.
Jul 15, 2007 | Roper MHE14XKB Microwave Oven
Kitchen Ranges Logo
154 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
