Question about GE WWSE5200B Top Load Washer
If I do a small load after a large load, on the rinse cycle teh water gushed up through the drain in the floor and floods the floor. The plumber snaked 50 feet twice and poured down acid and it still
Hi - If I do a small load after a large load, on the rinse cycle, the water gushes up through the drain in the floor and floods the floor. The plumber snaked 50 feet and poured acid down the drain but it still happens. What could be causing this backing up?
  • 10,865 Answers
Since the plumber snaked 50 feet, one must conclude that the blockage is beyond the 50 foot mark.
Shame on the plumber who stopped at 50 feet. he should have snaked all the way to the street system if you live in a city or to the septic tank if you live in the country.
I would call him back and tell him that he needs to finish the job.
Posted on May 21, 2009
What is the purpose of the flood hose? we have a ge wjsr2080t2ww washer. when we use the power wash cycle in super capacity mode as a minute after it starts agitating the water comes flooding out from...
the purpose of that tube so it anywater that comes out of it goes through it and directs the water down the back and away from the motor. Now the bigger issue is why is water coming through that tube.What i suspect the reason of that is that the transmission is defective and the break is that internal to the transmission is slipping so the inner tub turns during the wash cycle force water up the side of the tub into that tube.during the agitate cycle the tub is not suppose to move at all and stay locked into place,but instead its moving where the water is forced up by centrifical force too and out the top of the tub cover,if it leaks with only a small water load it will leak worse with a large water load. if this is what is happening and the tub is rotating on agaitate cycle teh fix for that is to replace transmission which in most cases cost as much as replacing the washer would be
Aug 04, 2011 | GE WDSR2080D Top Load Washer
I just purchased an LG Front Load washer (Model WM2140CW). Best buy installed it. When I went to use it today, the floor flooded. Water was gushing out of the drain pipe (backing up). The LG drain hose...
You may have a drain line restriction causing it to back up. Pull the drain hose up about 6 inches and try it again. If it does overflow again, you will need to call a plumber to clear the drain line out in your plumbing.
Jun 16, 2011 | LG WM2140CW Washer
Flooding in both drawers of dishwasher
I suppose "flooding in both drawers of ..." implies water is not draining out. Is that right?
It is a very little information to give you any clear solutions.
Did the water get into the drawers without starting any wash program? Most likely it is the backflow from kitchen sink back through the dishwasher drain hose. Does your kitchen sink plumbing have an air gap sowehere. If so, is it clear?
If the water is the back flow then it is likely to be smelly and you do not want to run it through the dishwasher. I would suggest take the drain hose out from under the sink downpipe and drop into an empty bucket. Then take all the fixtures out from the drawers and empty out water using a small container.
Put the washer arms back and run each drawer on a short rinse cycle collecting the drain water in the bucket. If cycle runs clear, then get plumber to check the kitchen downpipe.
Reconnect drain hose.
Hope this helps.
Dec 28, 2010 | Fisher DD603FCSS Dishwasher
What is the best way to winterize a standard large capacity washing machine?
If the product will be exposed to sub-freezing temperatures, turn off the water supply to washer, disconnect fill hoses, drain them and reconnect. Remove the drain hose from the standpipe in the wall and place it into a shallow pan at floor level untill the water floe stops. Unplug unit and you are good to go.
If no sub-freezing temps are expected, turn off water supply. Turn on washer for a warm wash cycle for a few seconds to relieve the pressure in the hoses. Turn off machine and unplug it.
Nov 04, 2009 | Kenmore 22422 Top Load Washer
Washing Machine Causes Flooding
call the whirpool repair service! if it's still under guarentee they should repair it free of charge!
Oct 16, 2009 | Washing Machines
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
Water drains underneath washer
the load could be to small and all the water whats been left after the wash might be because you only need small pressure on a small wash and the pressure wont make the water evaporate. or you might just need a new drainage pipe i would put less water in next time and see if its better if not get a local self employed plumber.
Dec 01, 2008 | Kenmore 46462 Front Load Washer
Kenmore Series 80 agitate for 10 seconds and pause for several minutes
No, the most is a damaged pump, does it pause in agitation or just spin? I would check the lid switch and timer.
Oct 12, 2008 | Washing Machines
28+ year old- Speed Queen Heavy Duty top loader
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
Aug 31, 2008 | Speed Queen AWS52NW Top Load Washer
GE WWSE5200B Top Load Washer Logo
232 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
