Question about Estate 24 in. TUD6700KQ / TUD6700KT / TUD6700KB Built-in Dishwasher
Estate Dishwasher drains poorly
Seems to have about 1/3 draining capacity, as it takes three drain cycles to get rid of the crud water in the bottem of the tub. The hose is not kinked... the hose is not plugged, Is there a way to get to a filter or something to see if it is clogged?
TUD6700KQO
280-1
Estate by Whirlpool
  • 10,865 Answers
Here are the reasons why a dishwasher won't drain. Perhaps you will be able to read through my lesson here and determine what needs to be done. get back if I can help you further.
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
Pump
Drain valve and/or solenoid
Belt
Motor
Timer
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Posted on May 21, 2009
  • Joe Hogan May 21, 2009
    Drain line/air gap
    Pump
    Belt
    Motor
    Timer
    Drain line/air gap
    Pump
    Belt
    Motor
    Timer
WHIRLPOOL ADG 6340 ix - At start and during the cycle water drains in pulses and for long time and water intake is in pulses and for long time. The cycle finishes OK but it takes long time, 30 min cycle...
since the water drain is on a float be sure there is no blockage of the screen drain area in the bottem of the dishwasher under the lower rack.the make some cleaner rinses to clean out the screen.
Feb 21, 2014 | Bosch SHX5AL02UC Dishwasher
My questions relate to GE Triton DW Model GSD 6660 G00SS My problems are multiple. I have run the diagnostics and all functions seem to be working but two conditions during operation remain a...
After you the drain to discharge the remain water and the tub is visibly dry of water,then you open and load it do you see standing water after you have drained and know it was gone??
If that is the case what i believe your trouble is that where the dishwasher drain connects to disposer under the sink the drain hose is only leading from that nozzle downward,if that is so what is happening is the dishwasher is draining ok but backfilling whenever water runs through the sink. To fix that use a string on plastic zip tie and attach a portio of the drain hose so at one point the drain hose under the sink is higher that the nozzle and water in the sink will longer run into the hose and run upward since water is only going to drain down and wont ever rise on its own.The drain pump is powerful enough to push the drain water up that "HIGHLOOP" very easily.
Good luck i hope this has helped you to fix your dishwasher,
Gene
Aug 08, 2011 | Dishwashers
MY FRIGIDAIRE DISHWASHER WILL NOT DRAIN. MOTOR ONLY HUMS DURING DRAIN CYCLE. OTHER THAN DRAINING IT SEEMS TO WORK FINE. DAY IT QUITE WORKING SINK BACKED UP AND WOULD NOT DRAIN
if there is still water in the dishwasher take the drain hose off from under the sink and use a large pot or mop bucket and but the unit into a drain mode usually by cancelling the wash cycle if the unit still does not drain.Then use a wet dry shop vac and attach it to the end of the drain hose to remove the water
after the water is gone check the drain pump for any kind of obstructions you may need to replace the drain pump
Jun 06, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Maytag dishwasher not draining fully
Try cleaning out the air gap.  The air gap is not part of the machine, and is located on your sink. If this becomes clogged, it may cause the machine to not drain properly.  Also, I know you said you checked the drain hose and cleaned as far as the filter and chopper blade, but have you checked the lower filter?  There is a filter located underneath the machine that should periodically be cleaned.  To check this, you need to access the machine from underneath by removing the bottom vanity cover. Hope that one of these helps!
Aug 01, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher not draining after a power cut
I would run the heated dry cycle a few times to try and get rid of that residual water, then restart the cycle and see if it work now. If it still is a problem try cleaning out the drain line behind the dishwasher, this is a very common problem with draining. If not that then might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
Jul 14, 2009 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher does not drain in normal cycle. on
Thoroughly clean drain screen and drain. Add small amount of drain cleaner to drain, flush after five minutes. Do not add hot water with drain cleaner.
Jul 07, 2009 | Dishwashers
SHU9922UC doesn't get rid of water
HI, check the following areas to address this poor draining issue.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Jun 19, 2009 | Bosch SHU9922UC Built-in Dishwasher
Siemans dishwasher not draining
the water in the bottem of the machine under the mesh filter is normal. it acts as a lubricant for both motor impeller and drain propeller. if its greasy then try using only 1 tablespoon of powder soap from now on. now if the water level is ever above the mesh filter after a complete cycle, then you have a drain problem
May 25, 2009 | Dishwashers
MY DISHWASHER WORKS BUT THE WATER DOES NO WANT TO
Is this a new install? If it is you must make sure the plug is punched out of your disposal. If this is not a new install you have 1 of three problems:1 your drain hose is plugged with crud and debris and needs to be removed and flushud out.2 you have a problem with your control unit.3 ypur pump is not working. the first issue may be delt with buy yourself but the other two are going to take a service call. best of luck
Apr 25, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Water leaks from inside of machine
TAWS850PQ0 WITH SAME ISSUE...found it to be the water pump located bottom front of machine...looking for replacement now...
Nov 13, 2006 | Estate TAWS850PQ
Estate 24 in. TUD6700KQ / TUD6700KT / TUD6700KB Built-in Dishwasher Logo
1,843 people viewed this question
Top Estate Dishwashers Experts
jdthefixer
ray gallant
Bogdan Odwazny
Bogdan Odwazny
Are you an Estate Dishwasher Expert? Answer questions, earn points and help others
