Question about Brother printerall-in-onelaser mfc8710dw
MFC-8710DW has no power
Printer will not turn on.
  • Brother Master
  • 783 Answers
If your Brother machine does not appear to have power,then check whether or not the date and time appear on your Brother machine's LCD. If anything is displayed on your Brother machine's LCD, then it is most likely receiving power.If your Brother machine's LCD is blank, continue to Step 2.
Verify the Brother machine's power cord is connected securely to the power outlet. If you are using a surge protector, extension cord, or power switch, disconnect it and plug the Brother machine directly into the wall outlet.
Please note Brother strongly recommends that you connect your machine to a surge protector.Because To protect your investment against power surges and lightning,
In particular, we suggest that you use a surge protector that is compatible with both standard A.C. power cords and telephone line cords. Surge protectors equipped with telephone jacks will assist in insulating your machine from any power surge that might travel through a telephone line.
If the Brother machine is turned OFF, its LCD will be blank. Please make sure the Brother machine is powered ON by pressing and holding the On/Off or Power Save key. This key is located in the upper-right corner of the control panel.
If your Brother machine's LCD is still blank, connect it to a completely different, known working power outlet. If the Brother machine powers up, then the problem is related to the original outlet.
-OR-
Confirm the power outlet is working by plugging another known working device (a lamp, radio, etc.) directly into the same outlet. If the other device does not work, the problem is related to that power outlet. If a wall switch controls the outlet, verify that the switch is ON.
If your Brother machine still will not power on, please contact Brother Customer Service.
Or
Please Follow Us On Brother Printer Support
Posted on Jan 08, 2014
  • Printer Help & Support
    Printer Help & Support Jan 08, 2014
    -OR-
    Or
    Check Below Link
    http://welcome.solutions.brother.com/BSC...
  • M CARDONA
    M CARDONA Nov 13, 2017
    CANT FIND WHICH IS THE POWER SAVE KEY
Brother mfc-8710dw prints with image drop out down left of page
Seems like the laser unit needs cleaning. It is located in the area where the toner and drum. Remove drum and toner and shine some light to the ceiling of that area. You will see a glass line. Wipe it with avdamp cloth. Reinsert drum and toner and print something to see the difference. Hopefully that's all it is. Also may be a problem with fuser. If first solution didn't help, wipe over a printed page with bare hand. If your hand gets toner on it, fuser is not baking properly
Jun 08, 2017 | Brother Office Equipment & Supplies
How can I download control center 4
one might think at brothers.com support /downloads
Mar 15, 2015 | Brother MFC-8710DW
How to eleminate the line on the edge of the paper
There are many types of lines. Each one requires different approach to solve. Please be very specific and describe it
Oct 14, 2014 | Brother MFC 8710DW
Error code e1 showing at xerox pro 420? solution..
rror codes If the printer's front panel displays a message Error XX, find the error code in this table and follow the instructions for resolving the problem. If problems persist, check the Xerox web site www2.tek.com/TekSMART/ or contact service.
Error User Corrective Action Error 01
  • Remove and re-install the black Toner Cartridge, then turn the printer off and on.
  • Replace the black Toner Cartridge, then turn the printer off and on.
Error 02
  • Remove and re-install the cyan Toner Cartridge, then turn the printer off and on.
  • Replace the cyan Toner Cartridge, then turn the printer off and on.
Error 03
  • Remove and re-install the magenta Toner Cartridge, then turn the printer off and on.
  • Replace the magenta Toner Cartridge, then turn the printer off and on.
Error 04
  • Remove and re-install the yellow Toner Cartridge, then turn the printer off and on.
  • Replace the yellow Toner Cartridge, then turn the printer off and on.
Error 05, 10, 11,12, and 13
  • Turn the printer power off, then on.
Error 20
  • Remove and re-install the Imaging Unit (make sure that Imaging Unit is locked in place). Turn the printer off, then on.
  • Remove and re-install the Main Charge Grid. Turn the printer off, then on.
  • Remove and re-install the Transfer Kit. Turn the printer off, then on.
  • Remove and re-install each of the Toner Cartridges. Turn the printer off, then on.
  • Replace the Main Charge Grid. Turn the printer off, then on.
  • Replace the Imaging Unit (make sure that Imaging Unit is locked in place). Turn the printer off, then on.
  • Replace the Transfer Kit. Turn the printer off, then on.
  • Replace the Toner Cartridges. Turn the printer off, then on.
Error 21, 22, 30,and 32
  • If a problem persists for Error 30, clean the sensor. See Cleaning Phaser 750 Printers.
Error 33
  • Check for jammed paper throughout the paper path (especially in paper feeder).
  • Remove and re-install the paper feeder and Transfer Kit. Turn the printer off, then on.
Error 40, 41, 42,and 43
  • Check for jammed paper in the Fuser. Re-install the Fuser. Turn the printer off, then on.
  • Make sure that you have the correct Fuser for your local printer power supply:
    110-Volt Fuser Part Number 016-1839-00
    220-Volt Fuser Part Number 016-1840-00
  • Replace the Fuser. Turn the printer off, then on.
Error 50, 51
  • Turn the printer off, then on.
Error 52
  • Remove the Duplex Unit (if installed).
  • Check for paper under the Upper Tray.
  • Turn power off, then on.
Error 53
  • Open left door and remove any jammed media.
  • Tun the printer off, then on.
Error 60
  • Remove the media from the Multi-Purpose Tray. Turn the printer off, then on.
  • Reinstall the media. Make sure you do not overfill the tray.
Error 61
  • Remove and re-install each Toner Cartridge. Turn the printer off, then on.
  • Replace each Toner Cartridge. Turn the printer off, then on.
Error 62
  • Check for jammed paper throughout the paper path (especially in the paper feeder and Fuser).
  • Remove and re-install the Fuser. Turn the printer off, then on.
  • Slide out and re-insert the paper feeder. Turn the printer off, then on.
Error 63
  • Remove and re-install the Imaging Unit. Turn the printer off, then on.
  • Replace the Imaging Unit. Turn the printer off, then on.
Error 70, 71, and72
Error 73
Error 74
Error 80, 81, 82,83, and 84
  • Make sure that all four toner cartridges are installed in the printer.
Error 01p through
Error 47p
  • Make sure that installed memory DIMM(s) are compatible with printer's image processor board and that they are installed in the proper slot(s).
  • you can helpful
Oct 09, 2014 | Xerox Phaser Office Equipment & Supplies
How do you install power supply?
Go To Below official Brother Printer Page For Your problem, http://www.printertechs.com/other-instructions/replacing-the-swing-plate-assembly-long-method/325-step-3-removing-the-power-supply
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Jun 10, 2014 | Brother MFC Series MFC-8710dw MFC /...
How do i reset the usage counters for fuser, laser and pf kit 1?
Hi Ron, to reset counters all you have to do is press the 3 and 9 buttons simultaniously when unit is in the ready state. Then scroll down to the unit you wish to reset and follow directions on the screen. After resetting, turn machine off/on. Very easy to do.
Apr 29, 2014 | Brother MFC-8710DW Multifunction Laser...
Brother mfc 8710dw
Please mention the exact problem
Nov 19, 2013 | Brother MFC Office Equipment & Supplies
Brother printerall-in-onelaser mfc8710dw Logo
1,123 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
