Question about Curtis International Curtis Proscan 39" Led 1080p 60hz 8ms PLDED3996A
TV is asking for a password - i never had a password
TV is asking for a password when I turn it on - i never used a password for the tv
How do I find the password for my AOC TV?
You might need to do a hardware reset if somebody programmed a password into your TV. This will erase all settings and set it back to the factory defaults.
Try this:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
May 19, 2014 | AOC Televison & Video
Password reset TV LG 60LA620S
You say it doesn't ask for code whats that mean, is the tv still locked? If You can get into the menu, do a factory reset!
Jul 07, 2017 | LG Televison & Video
Turned on parental lock do not have password
check tv manual for factory setting password
Jan 17, 2013 | Televison & Video
My ELCOT TV ask password, TV screen showing Limit Set, Limit Lock ON ask Password.
May 10, 2011 | Televison & Video
Model 232-S12 The screen is stuck on parental control. It is asking for a four digit password which we do not know. It also will not allow us to enter a password.
The default password on this TV is 9 9 9 9.
To get to the screen to enter this and deactivate parental control do the following;
1) Turn on your TV and press the "Menu" button.
2) Use the arrow keys on your remote control to navigate to the "Parental" header, then press the "Enter" button
3) Enter "9999" at the password prompt. That will lift the password lock.
Thanks for using FixYa.
Nov 13, 2010 | Olevia LT32HVM 32 in. LCD Television
60 inchMitsubishi medallion TV with locked v-chip
it should be in the instruction manual.if you do not have it you can look for a copy on the net
or try this when the screen asks for the password on the tv remote push (at the same time) the buttons "QV" and "9" then go into the menu and change the password or just turn it off - some models ask for the password a second time, QV & 9 again
Oct 02, 2008 | Televison & Video
Deactivate child lock on Onida TV
Try with 1147 (This one worked on my ONIDA TV) OR 5963 OR PRESS ZOOM BUTON AND VOL- KEY BOTH.
Aug 04, 2008 | Televison & Video
Child lock on tv
All you have to do is turn the TV on and turn to a channel that doesn't prompt the V-chip password (even if it's snowy) and hold down the volume (down -) button on the main unit while holding down the number "0" on the remote control. It might take a few tries, and you might need to change the TV channel for some reason but if done correctly, either the TV will turn off, or the menu screen will pop up and ask if you want to set the vchip password, either way you should be able to watch your TV now! :)
May 24, 2008 | Televison & Video
RCA 27V550T 27" TV
Problem fixed. I unplugged the TV for 20+ seconds, then before plugging it back in, I shorted ac plug prongs together with a metal key to ensure complete discharge. Plugged TV back in and used procedure to reset password WITH ONE CHANGE TO THE PROCEDURE.
With TV turned OFF press and hold <CLEAR> button on the remote while pressing <VOLUME DOWN> button on the TV, hold until TV turns on. When the menu appears DO NOT RESET THE PARENTAL CONTROL CODE as the user guide instructs. When my menu appeared it was in the SETUP screen on the LANGUAGE setting. It was set to SPANISH, using the remote I navigated to ENGLISH. Then using the remote I navigated up to GO BACK. Then I navigated to EXIT and hit <OK> button on the remote. All was back to normal.
Jan 10, 2008 | RCA 27V550T 27" TV
How to erase parental control code
I finally found out how to reset the V-chip password on this princess DT1350-P Tv. All you have to do is turn the TV on and turn to a channel that doesn't prompt the V-chip password (even if it's snowy) and hold down the volume (down -) button on the main unit while holding down the number "0" on the remote control. It might take a few tries, and you might need to change the TV channel for some reason but if done correctly, either the TV will turn off, or the menu screen will pop up and ask if you want to set the vchip password, either way you should be able to watch your TV now! :)
Nov 12, 2007 | Disney DT1350-P 13" TV
Curtis International Curtis Proscan 39" Led 1080p 60hz 8ms PLDED3996A Logo
20 people viewed this question
Top Curtis International Televison & Video Experts
Are you a Curtis International Televison and Video Expert? Answer questions, earn points and help others
