Want spin wah,s ok but when it comes to spin the spin want work
My washer want spin
Posted on May 06, 2014
Dunlop SW95 Slash wah No volume + no blue LED : is it dead ? The distorsion seems to work fine
Why not ask the experts?
https://www.jimdunlop.com/category/gear+support.do
Mar 22, 2017 | Dunlop Music
My Wawa pedal went out on my Digitech RP 500 how could I make it work again
This might work - Hold the bypass switch for five seconds and follow the on screen instructions to calibrate the expression pedal. If that doesn't work you could also try doing a back up and then a factory reset. You may also consider a separate wah pedal. There are many recommendations at:
What Is The Best Wah Pedal For The Money Our Answer For You
Jan 07, 2015 | DIGITECH RP500 Guitar Multi-Effects Pedal
Dunlop crybaby 105q wah effect not working
Sounds like a short in the effects board of the unit causing it to bypass the volume pot.
Feb 19, 2013 | Music
Blue light Slash Wah pedal. After a few weeks the blue light has stopped coming on (I run it on official 18V adapter). Rest of pedal works fine, as before. Would love to have those blue lights working...
First thing to ty is to try it using two 9 volt batteries as a test to see if lights work.
I ASSUME that you are NOT trying to use the pedal in the external effects loop (send and return) as the levels are not compatible. The pedal must be between the guitar and the inout of the amp.
Beyond this I would open the unit and look for something loose or broken where the blue LED is located.
Sep 18, 2011 | Dunlop Manufacturing Dunlop SW-95 Crybaby...
Hello i bought a Fulltone Clyde Standard Wah and it worked without any problems so far, but lately it started giving some kind of static noise when i turned it on and moved the pedal up and down. I had my...
The pot is generating noise. Some noise is unavoidable from pots. Using excess gain in the amp that that follows it will worsen the problem. If ypu can get to the pot and it has a way to squirt some CRC226 in it would help. You would have to use the spout on the can to squirt into the slot where the leads go into the pot. You can get CRC226 at Home Depot in the electrical dept.
Jul 20, 2011 | Fulltone Clyde Deluxe Wah Effect Pedal NEW
Hi there, i got a 5150 half stack amp and the evh wah pedal, my problem is when i engage the pedal comes a terrible hum, i already change the cables, 9v battery and the ac adapter and the big noise...
WHY are you using a battery AND a 9 Volt adapter? This is an either/or thing. Chances are you have a defective ground someplace. Use just the battery and try it... If the hum is gone, the adapter is NOT compatible with the pedal. A lot of hum problems occur because the guitar is near a source of magnetic fields, such as an amp. An embarassing thing is for a musician to reverse the in and out connections to the pedal... it will have the symptoms you have mentioned.
Apr 24, 2011 | Dunlop EVH Wah Wah Pedal Wah
Machine won/t spin, on second try wah cycle nothing worked although motor was running
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,</span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"> </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Problems with a washing machine not spinning or not draining are often inter related..</span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><br />If you are having a problem with your top load washer then check out this tip...<br /><br />Washing Machine does not Pump or Spin<br /><a href="http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin" target="_blank">http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin</a><br /><br />If you are having problems with your front load washing machine then checkout this tip...<br /><br />Front Load Washing machine not draining and or not spinning<br /><a href="http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining" target="_blank">http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining</a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span><br />
Aug 27, 2010 | Washing Machines
When i select the wah pedal funtion, it does not make the wah
You are apparently talking about an FX pedal with a built in wah function. Which pedal and model number? The Digitech RP350 for instance has a special procedure for initializing and recalibrating the pedal. Is that the problem or is it maybe the opto isolator ?
Jan 21, 2010 | Music
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
