Question about Motorola Mobility Flipside Mb508 Smartphone
How hard reset mb508 motorola
Cell phone freezes. i tried removing battery and replacing it, then i hold down the x key and power button at the same time. a triangle with exclamation mark appears, when i try to press fn key and t key at the same time i am not getting any further than the triangle with the exclamation mark
  • Official Brand Answer
  • 3,100 Answers
You can follow directions here: http://www.att.com/esupport/article.jsp?sid=KB112585&cv=821#fbid=YJHQ8v-Uo8r
Mark
Motorola Support
Posted on Aug 28, 2014
Reset a motorola bp6x
Hi Anonymous
please follow the next steps to make a hard Reset your device : 1. remove the battery cover remove the battery and put it back again
2. press and Hold the R & M key and press and press and hold the power button until you see the android image with the exclamation mark, then release the buttons
3. Press and hold in the middle of the he volume up and volume down key,
4.it will show up a menu then you need to select the 3 option wipe cache and factory Reset selected with the volume down, confirm with the power button, scroll all down until you see the option yes , then press the power where is reboot system now, and that will reset your device.
Regards
Maya
Motorola Support
Apr 15, 2014 | Motorola Mobility CLIQ XT (2 GB) Cell...
Tip
How to reset Kyocera Zio m6000
Soft reset
Dial: ##4357*
Select view
Scroll down to select reset.
6 digit code: 000000
Click Ok
Should reboot.
Dial *228
Hard reset
1. Power down the phone
2. Hold down the volume up, end key, trackball and send key simultaneously.
3. Phone boots. After it vibrates you let go.
To reset Kyocera Zio try the following:
1. Remove battery and put it back after two minutes
2. Press and hold down the home button key while turning on the phone.
3. If by chance the phone starts , do Menu Button > Settings > SD Card USB MASS > Factory Data Reset
If it does not work, try:
Hard reset 2.
1. Power off the phone.
a. Press and hold red END key for 2 seconds >> Phone Options >> select Power Off >> Phone will shut down >> Ok
a)
2. Remove battery for 15 seconds & replace battery.
3. Power up the phone.
a. Press and hold red END key for 2 seconds and wait until the device powers up completely.
b)
4. Power off the phone.
Procedure, cont.
5. Press and continue to hold the Volume Up button using your left thumb.
6. While still holding the Volume Up key, use your right hand to depress the green Send key, the white Track ball and the red End key (sequential order).
7. Continue to hold all 4 until keys completely down until the handset vibrates twice then let go of the keys & track ball.
a. Formatting Data and Cache appears
1. If you do not see the above (Formatting Data and Cache) redo steps 1 through 7.
2. If you get a Fast Boot, Self Test or Blue screen redo steps 1 through 7.
3. Allow the phone to completely reboot. This may take a few moments.
4. The phone has now been re-set to factory default settings. Please proceed through standard set up and activation procedures.
If still no luck, call Kyocera directlyand report the problem.
on Sep 03, 2010 | Cell Phones
How to reset an adr6350 phone
Preferred Method
  1. From a home screen, select the applications tab (located in the lower left).
  2. Select Settings.
  3. Select SD & phone storage.
  4. Select Factory data reset.
  5. Select Reset phone.
  6. Select Erase Everything.
  7. Perform Initial Activation/Setup.
Alternate Method
  1. Press the Power button for 3 - 5 seconds.
  2. Select Power off.
    linote.gif If the device isn't responding proceed with step 3.
  3. Remove/replace the battery.
  4. Press and hold the Volume down key then press and hold the Power button for 3 to 5 seconds.
  5. When the HBOOT screen appears, release the Volume down key and Power button.
  6. Press the Volume key to select FACTORY RESET then press the Power button.
    linote.gif This boot process takes several moments. If the device hangs or freezes, remove/replace the battery.
Mar 08, 2014 | HTC Incredible 2 II / ADR6350 ADR-6350 Hot...
Too many pattern attemps on motorola xoom
hi ,
try to hard reset your phone to back it in its original factory setrting...
  1. With the device powered off, press the Power button to power the device on.
  2. When the Motorola logo appears press and hold the volume down key.
  3. When the Android recovery text appears (in the upper left), release the Volume down key then press the Volume up key.
  4. When the Android recovery screen (Android with exclamation point in a yellow triangle) appears, press and hold the Power button.
  5. While holding the Power button, press the Volume up key.
  6. Press the Volume down key to select wipe date / factory reset.
  7. Press the Power button.
  8. Press the Volume down key to select Yes -- delete all user data.
  9. Press the Power button.
  10. Ensure reboot system now is selected then press the Power button.
Sep 28, 2012 | HTC Touch Pro Smartphone
My Motorola Blur Wont Turn On
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 26, 2012 | Motorola Cell Phones
How to reset a Motorola Smartphone screen lock passcode
Typically, with android there will be an option to click forgot passcode and the ability to ender your gmail account and password to resolve the issue.
The next step is to hard reset the phone if the first option is N/A.
  1. Press and hold the Power button for approximately 3 seconds.
    If the device is nonresponse remove / replace the battery.
  3. Press and hold the Volume Up / Down keys then press and hold the Power button (simultaneously).
  4. Release all keys when the Android Notification Screen is displayed.
  5. Press the End key.
  6. Press the Volume down key to select wipe data / factory reset.
  7. Press and hold the Camera key then press the Volume Down key to select Yes.
  8. Release the Camera key.
  9. Select reboot system now is selected.
  10. Press the Camera key.
    Note: If you hard reset the phone, it will be back to factory settings, meaning you will lose any applications installed and all information saved. Logging into your gmail again will return your contacts but beyond that everything will be erased.
Oct 05, 2011 | Motorola Mobility CITRUS Smartphone
Hardreset motorola mb508
To reset your phone,Please follow this procedure
1. Open the Application tray
2. Touch settings
3. Scroll down and touch policy
4. Scroll down and touch Factory Data reset
5. Touch Reset phone
If you can not access the menu,Here's the Hard Reset method
1. Power of your mobile
2. On the hardware keyboard,Hold the "X" key and the "Power" button.
3. When Moto symbols comes out,you may now release the "Power on" key but keep holding the X key until you see a triangle and an exclamation point.
4. Now press the "Fn" key and "T" key at the same time.
5.You will now see a menu on screen
6. use keyboard cursor key to move the blue highlighted selections
7. To proceed, select "Wipe data/Factory reset
8. press the return key to select the option that is highlighted.
9. Use the cursor key to highlight YES from the next menu.
10. Press the return key to complete the selection.
11. reset is on progress then wait until it's DONE.
12. After the process,you will see a message "Reboot System Now",select it using the cursor.
13. Press the return key to reboot the device.
Thank you for visiting Fixya...
Jul 14, 2011 | Cell Phones
Phone freezes when i open the the camera app.
TRY DOING A MASTER RESET, IT MIGHT WORK.
Hard Reset
  • Shut down the device
  • Press and hold the End key, tap Power Off, and then tap OK
  • Remove SIM card
  • Remove the battery cover, the battery, and then remove the SIM card. Replace the battery and battery cover.
  • Three-key combination
  • Press and hold the Volume Down key, Send Key, and then End Key in succession. Make sure that all three are being pressed simultaneously and that the End Key is pressed last
  • When the graphic is displayed, press the Menu key to begin factory reset
  • Sep 15, 2010 | Samsung Behold II SGH-t939 Smartphone
    Motorola Q9m frozen how can I get my contacts
    I can't tell you how many times this phone has frozen, and unless you've been using a sync program, you're out of luck.
    You can do a hard reset, which resets the phone to factory settings by removing the battery to shut down, then put the battery back in. Hold down the middle key on the silver directional pad while powering on. It takes 5-10 seconds but you will see the "Master Reset" option on your screen, follow the directions.
    This happened all the time until I went to the Motorola site and did full phone update ( http://direct.motorola.com/hellomoto/Motosupport/source/SoftwareUpdateSelect.asp?country=USA&language=ENS ) Now my Q9m which used to freeze 1-2 times per month hasn't frozen in 6 months - good luck!
    Oct 17, 2008 | Motorola Mobility Q9m Smartphone
    Motorola
    Trya hard reset, you may lose data
    try holding down the power
    remove the back cover and battery
    (at this point briefly let up on the power)
    remove the sim card
    wait for "insert sim card" message
    remove battery
    reinsert sim card and battery
    release power key when the splash screen comes up
    Feb 13, 2008 | Motorola Mobility RAZR V3i Cellular Phone
    Motorola Mobility Flipside Mb508 Smartphone Logo
    85 people viewed this question
    Top Motorola Mobility Computers & Internet Experts
    AJMAL KHAN
    Tom Chichester
    Abby Carter
    Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
