Question about Brother Office Equipment & Supplies
Grinding/popping noise when paper tries to feed. seems like the paper feed is catching. Noise comes from the left side of the machine
2 Suggested Answers
SOURCE: Loud grinding noise when paper is feeding through machine
Mine was indeed a gear problem. Took off the top cover and poked around. Found two areas that may have caused the grinding.
1. The lower roller shaft had slid to the left out of it's groove. By removing the handset cradle (3 release tabs are accessed underneath the toner hatch.) I could loosen the "gear box" (a black contraption with all the gears inside) and then snug the bottom roller into proper position.
2. I removed the "gear box" to look around. Don't know if I dislodged one of the gears while doing so, but noticed one was dislodged ;-)
This required opening up the gear box by removing 2 screws and lifting off the motor. Then i could get at a gear that had come loose from a claw sort of piece. Note: the teeth of the loose gear needed to be on the motor side when sliding it back into the claw thingy. It seems to use a metal clip for friction control and perhaps proper spacing.
I noticed "some" wearing of gears, but doubt this is an issue. This machine has been used VERY hard for years and now, just by re-aligning things, it works once again.
My googling barely found any mention of troubleshooting this machine, so I shudder to think what finding parts would be like.
Posted on Jan 21, 2009
Hp t1100 grinding noise after print
I suggest you run the diagnostics for the printer which allows you to isolate and run individual components. That way you can see which item is causing the noise. If it is coming from the left side, you might have a problem with the cutter.
Dec 17, 2016 | HP Designjet T1100 Photo Printer
HP 1315v Printer Makes grinding noise and won't feed paper anymore
It sounds as though a sheet of paper or an envelope bunched up and has jammed inside. Until that is removed from the feed roller, you will continue to hear the 'grinding' sound, and won't be able to print anything. Remove the cover from the backside of the machine, then locate and remove the obstruction. If you don't have any such obstruction then you have a mechanical defect which is not user repairable.
Oct 20, 2014 | HP PSC 1315 All-In-One InkJet Printer
1600n grinding and jamming
hi....take it to a tech to check about the system control chip... the control chip would have gone bad... and they will replace u with a new chip..or else Try manually moving the head carriage back and forth a few times!
Also check, if there isn't some piece of paper lodged inside, if yes try to remove it carefully!..
these are the possible solutions u can try out...
thank u
rate me
Jun 11, 2009 | Dell 1600n All-In-One Laser Printer
PAPER JAM
If you pull the drum out of the machine. Close front cover. is the noise still there. If it is then you have a broken fuser gear. If noise is not there remove the toner cart. from drum reinstall the drum unit in machine see if noise is there. if noise is there then it will be the drum. If not reinstall the toner try that if noise comes back then it is your toner cart.
Apr 11, 2009 | Brother IntelliFAX 4100 Laser Fax
Jan 19, 2009 | Brother IntelliFAX 2800 Laser Fax
We are getting a grinding noise when feeding paper
Hi Chezicke:
You have gears on the left side of the printer that drive the tractor assembly, they may be worn or loose and not messhing as they should to drive form feed. Remove left side cover to check gears.
pdouglasss
Jan 08, 2009 | Epson DFX-9000 Matrix Printer
Major problems when trying to print, Jamming alot & grinding noise
If the paper is an accordion type jam, you should replace the 4 small rollers, the upper feed roller, the upper feed guide, and the lower rollers. all of these are listed on hp's part surfer website.
RF5-0425-040cn, RF5-0434-000cn, RF5-0432-000cn, and RF5-0438-000cn respectively. Basically, get a new exit output assembly part number RG5-0456-180cn.
Does this help?
Jul 09, 2008 | HP LaserJet 4 plus Printer
Paper Jam...grinding noise
The print head lock is probably not retracting. Look for the white plastic block that pokes through from the paper feed side just in front of the head. Push it in with your finger and move the head to the middle by hand. Now turn the machine on. Then turn it off using the correct method. Then turn it on once more. If it starts grinding again, you screwed the feed mechanism when tugged out the jammed paper (probably pulled it backward through the feed instead of making it go forward and out the correct exit). If this is the case, you may as well bin it. If it in warranty, you can try to get a claim for repair.
Jun 15, 2008 | Epson Stylus CX3200 All-In-One InkJet...
GRINDING NOISE or PAPER JAM
If you are not a technical person best thing to do is to show it to an expert. grinding noise means some part in the machine is running with the friction. and might brake something or scratch something. Find out persons who work on photocopiers in your area either samsung or Xerox. as this model comes with both the companies and Xerox people are generly better than samsung people.
Apr 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Gears grinding with Brother Intellifax 4100
Does it only make the noise when printing. Do you hear the noise when sending out faxes? I have heard grinding noises onlt when using poor quality toner refills, or the fuser gear and or drive gear asm is stripped. First try a known good OEM toner.
Mar 22, 2007 | Brother IntelliFAX 4100 Laser Fax
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
