Question about SewShop.com Singer Model 9022 Instruction Manual
Bobbin casing bobbin is not catching and correct positioning for bobbin case housing
2 Suggested Answers
SOURCE: bobbin case jumps out of position when sewing on Singer 6412
Bobbin might be too low on thread, needs more weight to hold it down.
Posted on Aug 30, 2014
I bought a singer lockstitch 2000 at a yard sale. it came without an instruction manual and i cannot figure out how to load the bobbin correctly
Hi. I'm not familiar with your model, but in most cases, one would set the bobbin into the bobbin case, pulling the tail through the tension and letting a couple of inches of thread hang out. Insert bobbin case and bobbin together as one unit, with the bobbin on the inner side towards the hook. It should snap into place only one way and should require very little effort.
Sep 14, 2011 | Vacuums
Hi I have a Janome 419S or 423S, the problem seems to be my hook race unit keeps getting loose and then the thread jams up. What can be done? Please
A jammed machine is caused by thread being caught in thehook. Remove the upper thread and the bobbin case, turn the hand wheel towardsyou (counterclockwise) by hand and remove any thread in the bobbin case area. Alwaysturn the hand wheel towards you. Turning the hand wheel away from you(clockwise) can cause the machines timing to become unaligned and jam yourmachine. Also, always make sure the presser foot is in the down position beforeyou start sewing. Sewing with the presser foot in the up position will jam yourmachine in the bobbin case. If youhave an older model sewing machine with a shuttle hook, then you can alsofollow these: 1. Disconnect the sewing machine from any power source.Loosen the thumb screw on the left side of the sewing machine body and removethe cover to expose the needle bar. This is the shaft that extends down andthat you attach a needle to for sewing. Open the shuttle race and remove the bobbinand bobbin case. 2. Turn the hand wheel toward you until the needle hasreached the lowest point of the stroke. The hook should be at the top of itsstroke inside the shuttle race. Loosen the set screw for the needle bar on theupper part of the machine, this is located on the needle bar bushing (thecollar that the needle bar slides through when making a stitch). The needle barshould slide easily up and down. 3. Turning the wheel again, adjust the position of the tipof the needle so that the upper part of the needle eye is just below the bottomedge of the hook inside the shuttle race. Once in position, re-tighten the setscrew on the needle bar bushing. Do not allow the needle bar to slip whiledoing this. 4. Replace the bobbin and bobbin case and close the shuttlerace. Thread and plug in your machine. Using a sizable scrap of cloth, sew aseam to check to see if there are any skips in the stitching. If there arestill skips re-adjust the timing again until you can sew without any skipped stitches. 5. When proper timing has been achieved replaces the coveron the needle bar and tighten the thumb screw. Hope this will help you. Good Luck.
Sep 13, 2011 | Vacuums
Royal Series, Necchi, Model # 80331763 bobbin does not take up thread properly. No manual unsure if i am threading it correctly.
You can get Necchi instruction manual from Necchi website: http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Sewing_Machines.htm". Makesure the needle is in the machine correctly- all the way up into the needlebar, make sure that it is threaded correctly, etc. If this all checks out ok,take the bobbin case out of the machine. There are two ears on either side ofthe bobbin case- turn the left one to the left and the right one to the right.Remove the silver ring, and inspect the piece of metal that the ring came off of(looks like a circle with the top cut off). You have to locate the hook whichis the piece that looks like a half moon inside the big round metal piece.Locate the tip of it, turn the hand wheel toward you until the needle is in thelowest position, at this point the tip of the hook should be flush with top ofthe left side of the cut off circle. Checkwhether underneath thread is looping on the fabric. If so then you've mis-threadedthe top, probably haven't raised the presser foot when threading so you can getthe upper thread into the tension. You need to thread the upper part with thepresser foot up. (You can put it down to thread the needle.)
Not picking up thread can be several issues, like bobbin is miswound, bobbincase isn't snapped in properly, you're using the wrong type bobbin, machine isout of time, needle is bent or burred, machine is dirty and in need of dustbunny eviction and a little oil but most of the time the issue is once againmisthreading: sewing machine needles have a front and a back and they have tobe placed in the needle holder correctly. In that case your manual is needed, take all the thread offthe machine (yes, spool off the spool pin, bobbin out of the bobbin case), pullthe needle plate and clean your machine thoroughly, using brush and vacuum (notcompressed air) and oiling per the instruction manual. Put it all backtogether, putting in a 80/12 needle, correctly oriented. Hang on to theneedle thread when you fetch up the bobbin thread.
Each and every seam you start is going to be done this way:
1) Pull the tail of the top and bobbin thread behind the presser foot
2) Put the work under the needle and use the hand wheel to lower the needleinto the work
3) Drop the presser foot
4) Holding the thread tails behind the foot, take a couple of stitches.
5) Drop the thread tails and sew normally. Hope this will help you. Good Luck.
Sep 12, 2011 | Vacuums
Mmy bobbin case fell out of the casing spot and then the bobbin fell out. I don\t have a manual, used to know how to fix the problem simply but have forgotten. thanks for your help.
Hi. Find the end of the thread and pull it out, off of the bobbin a couple of inches. Hold the bobbin with the thread coming off of the top so that if you rotated the bobbin counter clockwise it would wind the thread onto the bobbin. Now take the bobbin case in your left hand with the stem in the center of the case facing toward you. Stick the bobbin into the bobbin case and, taking the end of the thread, pull it to your left while pushing back on it somewhat until the thread enters the slot in the bobbin case. Pull the thread so that it slips under the thread tension spring, pull a little more out, then reinsert the bobbin case until it is seated all the way in the hook. It will probably have a catch that snaps in place.
Aug 20, 2011 | Vacuums
Wife has Kenmore 385.12314. Regular use. Normally cleaned and oiled. Needle goes down, but bobbin thread doesn't catch. Needle at bottom of stroke and "half moon" is on top, needle...
Make sure the needle is in the machine correctly- all theway up into the needle bar, make sure that it is threaded correctly, etc. Ifthis all checks out ok, take the bobbin case out of the machine. There are twoears on either side of the bobbin case- turn the left one to the left and theright one to the right. Remove the silver ring, and inspect the piece of metalthat the ring came off of (looks like a circle with the top cut off). You haveto locate the hook which is the piece that looks like a half moon inside thebig round metal piece. Locate the tip of it, turn the hand wheel toward youuntil the needle is in the lowest position, at this point the tip of the hookshould be flush with top of the left side of the cut off circle. If this is notso, your machine needs to be re-timed. If that is the case, I would need to seea picture of the bottom of the machine so that I am able to determine whatneeds adjusting. Make sure you're turning the hand wheel in the proper direction-- the proper direction isthe one that will feed fabric forward under the presser foot.
Make sure the needle is facing in the correct direction -- stitches don't form,or skip badly when the needle is turned around.
Put the bobbin in the bobbin case (right way around) leaving a 2-3" tail.
Thread the top of the machine correctly, leaving a 3-4" tail afterthreading the needle.
Hang on to the end of the upper thread, and use the hand wheel to drop theneedle... continue to turn the hand wheel to raise the needle. Pull on the endof the needle thread and a loop of bobbin thread should come up.
Hold BOTH threads behind the presser foot when starting a seam to preventthread jams.
Aug 17, 2011 | Vacuums
In my Singer Sewing Machine model 1014 the Needle Won't Pick Up Bobbin Thread. Could you please help. Thanks
There could be several things causing this.
First, be sure the bobbin is in the bobbin case correctly. There is usually a line diagram showing the correct placement or you can check the owner's manual.
Second, make sure your needle is inserted correctly. If it is not completely set in the housing, this can prevent the bobbin thread from being caught by the hook. The groove in the needle should be ffacing toward you to assure that the thread interacts with the hook.
Third, be certain the upper threading is correct...passing through all thread guides and correctly through tension and take up lever.
Finally, make sure the bobbin case is free of lint. The machine brush that came with the machine will clean this area well.
I hope one of these suggestions helps you solve your problem. If so, please come back to Fixya and rate my advice!
Jul 24, 2011 | Vacuums
My Singer portable (#6202/62120) keeps stitching nicely on top, but the bottom stitching is all knotted up! It's driving me crazy! I have tried everything. Any help would be greatly appreciated....
The bottom side is effected by the TOP tension. First make sure the top is threaded correctly. Best thing to do is completely unthread it and then thread it again. Then check the tension and make sure it is not too loose. Check the needle to make sure it is inserted correctly and not bent.
Once you've done that then you can take a look at the bobbin tension and make sure it isn't too loose too. Make sure the bobbin is in the case correctly, wound correctly and that the bobbin case is completely inserted right. You will hear and or feel a slight "click" when it goes in correctly,
May 24, 2011 | Singer Vacuums
My Kenmore sewing machine timing has gotten off. I am sewing a big upholstery project and it starting bunching thread from the bobbin. The thread is so heavy that I had to put some pressure just to get...
Hello
Disassemble your bobbin case which is realy quite easy, clean thoroughly with a brush and air, paying particular attention to any rust that may have formed, and any thread that may have weazeled it's way into small but very incremental areas of your case.
Make sure your needle is not in backwards.The rounded side should be on the outside
. If threading is correct and your tension is properly adjusted , then check the hook for scratches. If you have ever hit the hook with a needle, it will be scarred and will catch the thread every time the upper thread passes around the bobbin case. the hook is the sharp point on the shuttle that holds the bobbin case. If it is scratched, polish it smooth with VERY fine sand paper
Make sure that your thread arm that rises and falls, constantly having tension running through it and that it is in fact staying in place.
Alternate between the metal and plastic bobbins - sometimes the plastic bobbins tend to chip
Dec 04, 2010 | Kenmore Vacuums
Stiches are loose in the bottom side of the cloth,if i change the bobbin case....will it help? I can understand that tension of thread is the problem.....but don't know what to do
the case the bobbin goes into has a little spring on its side .. the spring has one or two screws. one screw adjusts tension on the spring .. the bobbin thread goes under that spring when it is properly threaded .. if the screw is loose or missing then replace the screw or tighten it a little so that thread pulled thru the bobbin case spring has a bit of drag .. if its too loose then you can tighten the screw a bit more ... if you tighten it too much then it will pull the top thread thru to the bottom .. if your adjustment screw or spring is missing then you can replace the bobbin holder .. the new one should have the spring in place and be properly tightened .. . often the adjustment screw is just loose or the thread is not positioned correctly in the bobbin case slot. .
Jun 21, 2010 | Vacuums
SewShop.com Singer Model 9022 Instruction Manual Logo
56 people viewed this question
Top SewShop.com Vacuums Experts
Ron Lake
Andrew Taylor
Andrew Taylor
Are you a SewShop.com Vacuum Expert? Answer questions, earn points and help others
