Question about Panasonic KX-TG9344T and 2 KX-TGA931T Handsets Refurbished
How to unblock calls
Caller hears a couple of rings then a busy signal. Our phone rings once then stops.
    New Friend:
    Problem Solver:
  • 8 Answers
Go to area that you block them and choose the unblock button
Posted on Jan 06, 2014
Caller says my phone rings 2 x's and then the busy signal. I don't know how to fix this.
For purposes of discussion, lets say you are the caller. The "busy" signal may be a "reorder" signal. A reorder signal indicates that that the network inbetween your network and the recipient's network (or just the recipient's network) can not "find" a route back to your network. If you had received a busy signal, you reached the recipient's network but the recipient was on another call. If the problem is a "trunk" failure, the solution is beyond your reach. If it is a line failure, a call to the phone compan
Aug 07, 2017 | Lands Phones
Why can't I rec or make calls?
What is happening when a call comes in are they getting a busy signal? If so your line is shorted out.. unplug all phones and see if caller hears a ring.. Then 1 at a time plug phones in. Check for a dial tone and press a digit, hang up and check and see if dial tone returns, repeat this on all phones, until you get to the phone that does not give you dial tone back after dialing a digit. That will be your bad phone... If the line was ring busy after all phones unplugged, call repair service..
Aug 10, 2015 | Lands Phones
Why made phone early now cant just get busy signals?
Sounds like your phone or line is now short circuit and is holding the line so it appears busy to incoming callers. Try disconnecting the pnone and line right up to the incoming point of your house to find the problem.
Jul 30, 2014 | AT&T CRL82312 3 Handset Answering System...
Phone rings once, but then stops ringing and I can't answer the call
If you have a landline, most likely you have a short in it. Not enough to kill line, but, when the 90 volts a.c. comes in to ring it jumps short. The short answers the phone.. It doesn't stop out going but can cause static. Check the line at the box outside. if bad there call your phone company, if good there, trouble is in house
Oct 03, 2017 | Uniden DECT 6.0 Cordless Telephone...
Nokia 6085 drops incoming calls
in profile management under caller settings you should find an option there to set the number of rings before timing out. Set it to whatever your preference is and it should solve your problem. otherwise it may be a provider issue, try calling AT&T and explaining what's going on.
Dec 02, 2013 | Nokia Cell Phones
Our phone system rings three times (on the caller's end) before the standard greeting connects. We use Avaya and Caller ID and it seems it is standard with that program and calling feature that the...
Is this an IP Office?
This is how it works. For some reason the IP Office waits for teh first 2 rings to get caller ID, and then lets the call ring in.
Sep 07, 2011 | NorStar M7324 Telephone
On occasions a caller cannot get through and they state that phones only ring and ring and no one picks up or that they get a busy signal. This is happening when we are at the office and phones are turned...
I have an idea on how to determine better what is going on with your phone system but first i need a couple of answers please.Are there 8 phone numbers assigned to your business or 5 numbers assigned with an extra capability of 3 being put on hold?What are your hours of operation and is it M-F only or also partially open weekends?At the end of the day do you turn on a switch for auto answer system pickup?I already have the idea ready but this information will help me describing it.I look forward to hearing back from you.
Aug 06, 2010 | Panasonic KX-T7433B Corded Phone
Phone rings once, no caller on caller id... is it a phone glitch?
it an alarm go into your alarm settings and switch it off
Sep 02, 2009 | Lands Phones
Message problem
In your case there is no problem regarding your cordless phone. The problem might be in your network only. So please contact your network officer immediately.
Mar 18, 2009 | Panasonic KX-TG6700 Phone
Fax problem
unplug the fax from the phone line. call it from you cell.if you hear your phones ringing in the house, plug the fax machine back into the jack. [you should still be on your cell phone] if the line goes dead or stops ringing, there is a short with the fax machine or wire to the jack.if you hear a busy signal without the fax plugged in, unplug everything you have plugged into phone jacks thruout the house. call your # again.if you hear ringing on your cell phone, plug everything back in one at a time.[again while still on your cell phone] if it was one of the phones plugged into a jack, when you plug the shorted phone back into the jack, the line will go dead again. that phone or cord is the problem.
if still rings busy when everything is unplugged, then call your phone company. it can be an inside wire or jack problem, or the problem is outside your home.
hope this helps
wg
Feb 05, 2008 | HP Officejet 5610 All-In-One InkJet...
Panasonic KX-TG9344T and 2 KX-TGA931T Handsets Refurbished Logo
195 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
