Question about Toshiba Satellite Pro L300 Notebook
Function Buttons are not working in conjunction with (FN) Key for Screen light adjustment and other features.
Toshiba Laptop Satellite Pro - Model- M 200. Issue -Function Buttons are not working in conjunction with (FN) Key for Screen light adjustment and other features.
  • 4 Answers
As far I know FN keys are related with specific motherboard drivers.
Thoshiba recovery cd/dvd during restore/re-install, loads all toshiba drivers and utilities for operating fn keys.
If the operative system loaded in the laptop is no OEM then you will have this problem, and in order to fix it you must:
First install the operative system (clean install)
Second install: chipset drivers. This drivers instructs the operative system how to detect specific hardware. Must be installed in first order.
Third: install drivers (ethernet card, audio, video controller, toshiba utilities, etc). At this point verify all FN keys ( check display settings, stand by/ hybernation, etc).
four: Load all software needed (microsoft office, etc).
I hope this help to solve your problem
Posted by MCampos
Posted on May 31, 2009
I would like to boot a toshiba satellite m105-s30401 with an external monitor as the laptop screen is busted and i would like to use an external monitor until i get a replacement screen, how do i get
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Mar 03, 2013 | Toshiba Satellite M105-S3041Notebook
My function keys doesn't work in my laptop toshiba satellite c660-a047
The function key, labeled "Fn" and located in the lower-left corner of your keyboard, is a useful feature. By pressing "Fn" along with one of the numbered function keys at the top of the keyboard (F1 through F12), you can adjust your screen brightness, enable and disable your touchpad or wireless modem, lock your computer and complete a variety of other tasks. These keys will not work if the "Fn" key is not pressed along with them. While the "Fn" key itself does not turn on and off, there are settings that can make it behave differently, or seem to be disabled.
Click "Start," then "All programs" or "Programs," then "Toshiba." Select "Utilities," then "Accessibility." Place a checkmark in the box to make sure the "Fn" key will work whether you press it simultaneously with the F1 through F12 keys or immediately before pressing those keys. Customize the other options on the screen, then click "OK." Test your "Fn" key. One of the easiest ways to do this is by pressing "Fn" and "Esc" at the same time. This toggles the sound on your computer on and off, and will show a speaker icon on your screen if it works. Press "Fn" and "Num lock" at the same time if the "Fn" key still does not work. Use the "F11" key if your laptop has no "Num Lock" key. Test the "Fn" key again, using the same method as in Step 4. Locate a licensed repair technician if the key still is not working. A hardware issue may be at fault. Hope this helps.
Jan 09, 2013 | Toshiba satellite c660
I connected RGB from toshiba m45-s169 to tv. Had a signal but now cant get it back. Tried updating video driver. Help?
You can switch to an external monitor, TV or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Oct 23, 2012 | Toshiba Satellite M45-S169 Notebook
I use TOSHIBA Satellite M200 notebook and have problems : 1. FN key did not work I can use only FN+F10 and FN+F11, other FN+key didn't work. 2. All hotkey buttons (locate next...
Hi
There is software utility missing from your laptop
you can download it from TOSHIBA Satellite M200 website under ( keyboard utility )
Please tell us your results
Good Luck
May 13, 2011 | Toshiba Satellite P105-S921 Notebook
The brightness of my laptop is very high
There should be a function key (usually labeled "FN") on the keyboard. There will probably also be buttons with brightness adjustment labels on them. Usually the arrow up/down keys adjust your brightness while the FN key is pressed. The adjustment keys are usually labeled with a picture of the sun with an up or down arrow beside it - almost always in a different color than the letters on your keys [maybe light blue?]. Otherwise you may have to adjust it via software in the control panel. Good luck.
Apr 05, 2011 | Computers & Internet
How to increase the brightness on my Toshiba serial #472011022k?
Every laptop is different, so adjusting the brightness or contrast on your laptop may vary from the steps provided on this page. However, understanding the process of how to adjust the brightness or contrast will help you change your settings.
Most laptops adjust their brightness and other settings using the function key in conjunction with another key. For example, pressing and holding the function keyjhay_torida_0.jpg (abbreviated as "Fn") and pressing the up or down arrow key as shown in the picture below, increases and decreases the brightness.
Mar 02, 2011 | Computers & Internet
I cannot adjust brightness in my Toshiba satellite pro laptop by pressing fn key and brightness keys(f6 or f7)
hello
in the lower right side of your screen you can see the battery sign cick on it and adjust the brightness.
thank you
Dec 23, 2010 | Toshiba Computers & Internet
When i hit fn then f7 the f11 lights up and the screen stays the same. What can i do? thanks toshiba satellite m35-s456
"fn" key used to activate some function keys which are gave by your laptop producers. you can do some jobs 'fn' press with function key. try it.........
Feb 10, 2010 | Computers & Internet
My laptop won't recognize a projector
You need to push the function key FN and hold it down then press F5
Aug 20, 2009 | Toshiba Satellite Pro S300M-S2403 Laptop
Toshiba Satellite Pro L300 Notebook Logo
792 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
