Question about Samsung WF419AA Front Load Washer / Dryer
I have a sign SEC at the painel in the washer dryer samsung wdh125n
Samsung Steam Dryer has power but only displays a flashing smiling person. The dial will not turn and will not start cycle??
Maybe you press lock button, simply unlock it again try this one
? What is the "Child Lock" function?
• If you press the "Child Lock" button (Spin+Option button) longer than 2 sec during operation, this
function is selected.
• If once this function is selected, no change can be done until the end of laundry.
• Press the "Child Lock" button (Spin+Option button) longer than 2 sec to cancel the function
Jan 19, 2015 | Samsung DV419AEW 7.4 Cu. Ft. Electric...
How do you fix a EE Error code?
If the error is tE (instead of EE), then your Samsung washer has a problem with the temperature sensor. This is a thermistor on most of their models. If the machine is under warranty, contact Samsung for the repair. Otherwise, please add a comment with the full model number of the washer or dryer with the error. Assuming the part hasn't come loose (it's held by some clips), it needs to be replaced.
To check out the part, you need to unplug the appliance and get behind it. Then take off the back panel. The thermistor on the washer is mounted near the bottom of the back of the washer tub.
For Samsung dryers, the code could be Et. Then the EEPROM is faulty and again needs to be replaced.
I hope this helps.
Dec 15, 2014 | Samsung 4.2 Cu. Ft. FrontLoad Washer And...
After trying to update the firmware from 2.13 to 2.15, the Blu-ray player finished the process with no problem, it turn itself off automatically... but when I tryed to turn it on again, it turns on, but...
1. Unplug the player from the wall
2. Press and hold the power button on the player for 10 sec.
3. Plug the player back into the wall
See if this works for you. If not they have live chat support at the samsung website. They will walk you through downgrading your firmware.
http://www.samsung.com/us/support/supportOwnersProduct.do?prd_mdl_name=BD-P1600
Mar 04, 2011 | Samsung BD-P1600 Blu-ray Disc Player
Pedestal for Samsung washer & dryer, will other brands fit too?
Just bought a red Samsung washer/dryer, looking for pedestals, but don't want to buy $200.00 ea., any suggestions
May 07, 2010 | Samsung WE356A5W Washer/Dryer Laundry...
AEG Lavamat 16820 turbo Washer/dryer won't start - makes noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dgmj
Apr 18, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
Samsung dryer gets a to code
The thermistor or thermal fuse is about an inch long and is inside the rear of the dryer and is usually attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a blown thermal fuse. Hope this helped and best wishes.
Sep 03, 2009 | Dryers
Frigidaire gleq2152es dryer
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Check lint filter is cleaned every load.
And that the outside animal guard where the vent opens outside is clear. If it's even half way clogged it will not dry or get hot!
Otherwise
for this is a situation that you will need service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 11, 2008 | Frigidaire GLEQ2152ES Electric Dryer
LG WD-1290RD FRONT LOAD WASHER/DRYER chimes with blank front panel
Unplug the unit to reset the computer.  Wait 5 minutes.  If the problem still occurs, you will need to have the control board replaced.
May 18, 2008 | LG WM-2277HW Front Load Washer
Samsung WF419AA Front Load Washer / Dryer Logo
26 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
