Question about Brother GX-6750 Typewriter
How to remove the carriage stop on a brother gx750 typewriter
3 Suggested Answers
SOURCE: Brother GX 8250: my problem is with the carriage.
Brother GX8250 typewriter; my problem is with the carriage. The return key returns the carriage to the original left-side position, but fails to advance to the next line.
Posted on Oct 03, 2009
  • 61 Answers
SOURCE: Broken Brothers SX-4000 electronic typewriters..I need a spring
If what you require really is a spring then you can buy springstock (long pieces of varying strengths of spring) and make one yourself. However, I thought that the carriage on these machines was pulled by a cable on a drum that is driven by a motor.
Posted on Apr 24, 2010
Attach carriage cable Brother EM 530 typewriter
Has anyone any info on re-attaching the return cable?
Apr 09, 2014 | Brother EM-530 Typewriter
Beeping
If it beeps when you turn it on, most likely it is failing the post routine. The number of beeps will tell you what is wrong (if you have the error codes). Sometimes that will happen if the carriage is not all the way to the left at power on. Turn it off, and see if you can gently move the carriage all the way to the left and try it again.
Dec 12, 2013 | Brother EM-430 Typewriter
Display Screen reads "4check printer". Carriage
Check the printwheel to be sure it is properly installed. Remove the ribbon and L/O tape and try it, you are looking for anything in the way of the P/W or carroer.
DickyO
Feb 22, 2011 | Brother EM-630 Typewriter
Sadly my brother AX-100 is stck at the left hand side of the carriage. I cannot do anything. The machine tries to get itself warmed up but then a bell rings repeatedly. I canno move the daisywheel housing...
With the machine turned OFF, you can move the carrier to the right by hand fairly easily - DO NOT TRY TO FORCE IT- if it doesn't move, look inside the machine to see if some forein object is stopping it.
If the printwheel is not in the machine, it would normally go to the left, stop and start beeping. Its not really necessary to remove the ribbon and printwheel for transport, but it is a good idea to put something inside the machine to stop the carrier from slamming back and forth as it's moved.
Dec 30, 2010 | Brother Office Equipment & Supplies
I have a Brother ML300 typewriter. I do not know how to get out of the tabs which are already set up in the typewriter. Could you help me?
Move the carriage (print head) to the margin you would like to clear. When you hear the beep, hold down the [ALT] key and press [3]. Now use the backspace or the space bar to move the carriage to where you want the margin set. Now hold down [ALT] and press [4] to set the left or [5] to set the right margin.
Dec 13, 2010 | Brother Office Equipment & Supplies
Mar 26, 2010 | Brother Office Equipment & Supplies
Sep 08, 2009 | Brother Office Equipment & Supplies
SX 4000 Brother Electric Typewriter
With power off, remove the ribbon and look down inside the carriage assembly on the right hand side. Look close and you will see a white gear, you rotate that gear, either way about 1/2 a revolution. Power on and try typing, if it works you can put in the ribbon and go, if not, rotate the gear somr more.
Aug 27, 2009 | Brother SX-4000 Typewriter
Carriage stopper
The printhead is the part that moves back and forth. It is stopped electronically. There are no "stops" per se. What does the part look like? If everything works properly, it could be a forien object, that is, something that was not actually part of the machine.
Sep 10, 2008 | Brother SX-4000 Typewriter
DAISY WHEEL
typing "code" and "reset" sets it right to type
Mar 20, 2007 | Brother SX-4000 Typewriter
Brother GX-6750 Typewriter Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
