Question about Hardline Products Ez Adjuster Fender Hangers
How does the line attach - Hardline Products Ez Adjuster Fender Hangers
Replace a fuel line on a craftsman weedeater model#358-798271
Get foot of fuel line and insert into tank - bring it out and attach the filter - then draw it back it in with filter attached - cut off excess line and attach to carb input .
Sep 10, 2016 | Craftsman Garden
Craftsman model 358.797342 leaf blower has two lines going into the fuel tank, one is attached to a filter that lays within the tank, the other line I'm not sure what to do with?
The second line you are asking about is a pressure line that just goes inside the take and when you prime the bulb it puts pressure in the tank it is not attached to anything in the tank only to the primer bulb.
Jan 13, 2013 | Craftsman Garden
Internal line in gas tank came loose
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Jan 23, 2012 | Homelite Mighty Lite Lawn Trimmer
Hi i need to conect the water feed for ice machine and have no instruction book any help cheers jez
Instructions Things You'll Need
  • 1/4 inch water line kit .
  • wrench
  • pipe dope for threads
    • 1 Locate the cold water line as close to the appliance as possible
      attach the water valve to the cold water line and tighten screws.
      turn the valve all the way in so it pierces the pipe.
    • 2 Attach the water line to the new valve.
    • 3 Bring the water line up to the appliance and attach the water line to the back fitting on the water valve on the refrigerator.
      After lines are attached turn water on and test for leaks
      Purge line by extracting at least 1 gal of water through dispenser.
Aug 26, 2011 | Refrigerators
I have a Talon electric line trimmer AT2307A. When I press the start button, the bottom attachment with the nylon line does not spin even though the motor is running.
Halfway down the shaft of the line trimmer, you can detach the line trimmer attachment ( this in so you can fit a lawn edger attachment if need be). Unclip the line trimmer at that halfway point and the start the motor and see if that rod inside the shaft is spining, if so, reattach the line trimmer attachment and see if the nylon line spins, if so, it wasnt attached correctly, if not, then there a break in the flexible rod going to the trimmer head, most likely at the bend.
Dec 29, 2010 | Garden
1975 Ford Granado Rough idling because vacuum lines are off. Need to know where vacuum lines attach to carburetor.
The vacuum lines attach to the intake manifold NOT the carbuerator, look for the attachment nozzle on the intake manifold, that which the Carb sits on...
Nov 17, 2010 | Ford Granada Cars & Trucks
I have a ryobi 31cc straight shaft with all the attachments. I am replacing the fuel line and need a schematic of what goes where. There are two holes under the tank reservoir and one has nothing attached...
The second hole is for the carburator return line(& primer line). Your correct their is nothing to attach it to. The line itself self seals the hole. If you inspect the old line you will see that where the line fits the hole the upper part & lower part were slightly larger in diameter. This enabled the line to seal itself in the hole when installed. If you have to replace the line, purchase a rubber washer and plastic cement and cement the line to the outside, leave about 1/4 of inch of line inside the tank. Try to buy tubing that is slightly larger then the whole which I belive is 1/8"OD. The other line is fuel supply it will have small white ring to attach the tubing to on the fuel tank.
May 07, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
What are the steps to re-attach throttle to trigger and fuel line to tank on Mac 110? If the fuel line is attached first, the trigger seems impossible to reach and if the trigger is attached first, can't...
Did you remove the rear case first? That allows direct access to the fuel tank and line. I have found the throttle trigger connection to be the worst offender when the front case is removed to access the carburetor and ignition system. Hope this helps!
May 05, 2010 | Garden
Replace fuel line
You can cut the line, push the fuel filter and fuel line attached to it out where you fill it with gas. When you are ready to put new line in, cut the fuel line at an angle so you can push it in the hole. Keep pushing in until it comes out the fuel tank fill hole. Attach your new fuel filter to the line and pull it back until the fuel filter lays in the bottom of the tank. Then cut the line to length and put it on the carburetor. Take the other piece hook on the carburetor and put it back in the tank.
Sep 28, 2009 | Echo Garden
Homelite trimmer - tubes into tank came out. One is split
Actually the fuel is pumped in by the carburetor. The carburetor work both vacuum and pressure when operating the pump. There is one line in the tank with a fuel filter normally attached; the other line is a return line is normally just inserted a short distance in the tank. To access the filter use piece of wire with a small hook on the end and carefully fish out the line.
If installing new lines change them one at a time as not to reverse their attachment to carb, When inserting the lines into tank cut them on an angle to help get them started then cut the supply line square before installing the fuel filter.
Aug 03, 2009 | Homelite Mighty Lite Lawn Trimmer
Hardline Products Ez Adjuster Fender Hangers Logo
80 people viewed this question
Top Hardline Products Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Hardline Products Boating Expert? Answer questions, earn points and help others
