Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Saw was running and quit checked gas and oil both are full
Chain saw has gas and oil but it does not want to start
  • Jim Parker
    Jim Parker May 11, 2010
    Need more information. How did it run when it was working? How old is it?
    Jim
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 120 Answers
Check to see if you are getting spark. If you are getting spark then it is not getting fuel. Try sparying starter fliud in the carb. If is starts then stops. Take the fuel line off to see if something is obstructing the line. Also the fuel filter can be changed.
If you are not getting spark with the spark plu relace the plug. Also to check the spark, remove the plug and put a screw driver in the plug wire and ground the screwdriver. a spark should come off the screwdriver
Posted on May 30, 2009
What is the oil to gas ratio for homelite model 360?
I cannot find the full details for the model 360 chain saw but a typical Homelite chain saw uses the 50/1 gas/oil ratio.
1 gallon (US) 2,6 oz
1 litre 20 cc (20 ml)
If you want to download the user manual for your chain saw then please check the full model number . for example UTxxx and select this in the Homelite site.
Product Owner Manuals
Aug 21, 2014 | Homelite Garden
Chainsaw rattles when it stops
personally too much hassle prefer Stihl Chainsaw more reliable Seizing is caused by lack of lubrication, First check all level has oil pump seized or is it sump type when running oil circulates all way round, Still there has to be a oil reservoir if this is bone dry theres your problem the rattling is metal on metal with no protection and the damage is seizing caused by lack of oil I have two chainsaws both have oil sumps and are kept full, please check hope this helps
Feb 15, 2014 | Poulan Pro PP5020AV 50 cc Gas Powered...
How do i set air on husky 435 saw to fix boggy runnin
Mitch:
Adjust the fuel and air mixture screws while the saw is running... you'll find that "sweet spot"... it just takes a little patience! Small adjustments... If you over adjust and the saw quits running or starting, GENTLY turn both screws in all the way (don't damage the needle valves or seats) and turn both out one and a quarter (1 1/4) turns out. The saw should start, then adjust from there.
Jan 01, 2013 | Husqvarna GAS CHAIN SAW 435 16"
My saw is two weeks old it uses 3 tanks of bar&chain oil to 1 tank of gas is there a adjustment for setting?
Take the bar and chain off and clean both thourghly. Use a small blade screwdriver to scrape built up saw dust,dirt woodchips or whatever from bar track and make sure both are in good shape. The oil port should be located by bar alignment pin.Brush it clean and if you have access to compressed air then blow out to help clear port. Turn your saw upside down and locate screw that has directional arrow to + or - to add or subtract amount of oil flow.
I would start and run saw with bar and chain installed and properly tensioned. Let saw warm up then hold saw about one inch above clean piece of wood and run at full throttle for 30 seconds.There should be a light coating of oil on board. If you have too much oil then turn screw in direction on - until you get it set where you want it. There should be a light coating of oil on chain and bar at all times.
I mostly use stihl saws and run about 1 1/2 tanks of gas per tank of oil and this works great for me. Hope this helps you. Thanks.
Feb 07, 2011 | Poulan Garden
My saw runs a few minutes then gets hot and wont start
What is the ratio of the oil/gas mix?
Sounds like it is not getting sufficient lubrication.
Add 1/2 oz (about 1/2 shot glass) of 2-cycle oil to the gas tank and try again......
Check to be sure that you have LOTS of chain oil in the chain oil tank!!
\Keep us informed, please! -Jim
Oct 22, 2009 | Homelite ZR10926 16 Chain Saw
4 y/o oulan chain saw hard to start and quit running, no spark.
TRY RUNNING AT HALF OR FULL WHEN IT DOES POSSLBY BAD GAS/MIX IF YOU CHANGED THAT ALREADY CARB PROBALY NEED TO BE CLEAN
May 02, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 18' model 2000 chain saw, quit running , will not start.
If you have a compression gauge, check the compression. Anything under 90psi is too low.
Check your flywheel key. If it is broken the flywheel will move and not fire at the correct time.
Note: if it does not sputter with carb cleaner then it's not your carb.
Next:
Remove your exhaust manifold. Look into the cylinder with a flash light. You are looking for scratches. Anything larger then a light fingernail is definite proof you need a new cylinder/piston assy.
If it passes that test do the following:
Pour mixed fuel straight into your cylinder until 1/4 full. Slowly pull your saw over while looking into the cylinder. If you see bubbles after the ring/rings go by then you need a new cylinder/piston assy. On rare occasions if no scratches are present on the cylinder wall or piston, you may be able to change just the rings.
Mar 31, 2009 | Poulan Pro Chain Saw 46cc 20"
Ryobi 40cc chain saw oiler not working correctly
Hi
Check and clean the oil filter from oil tank.Check the worm gear wich engages with the oil piston pump(under the clutch).Near the hole where the oil comes out from oil tank there is an oil tank valve(see if it is clogged),it equalises the presure between interior and exterior of the oil tank.
best reagards savumihai71
Dec 23, 2008 | Husqvarna Chain Saw 20" Bar
Chain saw emitted sparks and now does not start.
Hi
When the engine get warm and die(I suppose)check the spark at the sparkplug.You can let the saw run until it ran out of gas and you will not distroy the engine.Change the sparkplug.
best regards savumihai71
Dec 16, 2008 | Garden
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
226 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
