Question about Hoover Dishwashers
Program no reset bottom
How do i get rid of sweet page
To uninstall Sweetpacks Toolbar program from your computer, click the Start button, then select Control Panel, and click on Uninstall a program.
If you are a Windows 8 user, you can right-click on a bottom left hot corner (formerly known as the Start button) and select Control panel from there, then select Uninstall a program.
Seach and uninstall SweetIM for Messenger, SweetPacks Toolbar for Internet Explorer, Update Manager for SweetPacks and any other unknown programs from your computer.
Please note that on some computers these programs might have a different name, search for any program developed by Sweetpacks and uninstall it from your computer.
Because Sweetpacks is installed with other additional programs (DealPly, Free Ride Games Player, Ginger, PriceGong, SweetIM for Messenger, Sweetpacks Bundle Uninstaller, Update Manager for SweetPacks or Video Converter), we recommend that you search and uninstall any other unwanted or unknown programs from your computer.
Remove Sweetpacks Toolbar from Internet Explorer Open Internet Explorer, click on the gear icon icongear.jpg" align="BOTTOM" border="0" height="16" width="16">Tools for Windows XP users) at the top (far right), then click again on Internet Options.
In the Internet Options dialog box, click on the Advanced tab, then click on the Reset button.
In the Reset Internet Explorer settings section, check the Delete personal settings box, then click on Reset.
  1. When Internet Explorer finishes resetting, click Close in the confirmation dialogue box and then click OK.
  2. Close and open Internet Explorer.
Remove Sweetpacks Toolbar from Mozilla Firefox At the top of the Firefox window, click the Firefox button, go over to the Help sub-menu (on Windows XP, click the Help menu at the top of the Firefox window), and select Troubleshooting Information.
Click the Reset Firefox button in the upper-right corner of the Troubleshooting Information page.
  1. To continue, click Reset Firefox in the confirmation window that opens.
  2. Firefox will close and be reset. When it's done, a window will list the information that was imported. Click Finish
Sep 07, 2014 | Computers & Internet
Tip
HTC Touch Soft Reset Soft Reset Occasionally, you may need to reset your...
Soft Reset
Occasionally, you may need to reset your device. A soft (or normal) reset of your device clears all active program memory and shuts down all active programs. This can be useful when your device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
To perform a soft reset
Use the stylus to press the RESET button found at the bottom of your device. Your device restarts and displays the Today screen.
I hope that helps.
____________________
Download the HTC Touch Manual.
HTC Touch Clear Storage.
HTC Touch Hard Reset.
on Apr 18, 2010 | HTC Touch Cellular Phone
Reset billb m000
HOW TO RESET UNIDEN 350c
PROGRAM BOTTOM DON'T WORK IT SHOW CHN +Pr 9 - loc WWHAT WOULD BE THE PROBLEM
Oct 22, 2013 | Uniden BC350 Base Scanner
How to format HTC Touch2 t3333?? need help
Performing a soft reset
Perform a soft (normal) reset to clear all active program memory and shut down all active programs. This is useful when your phone is running slower than normal, or a program is not performing properly. If a soft reset is performed when programs are running, unsaved work is lost.
1. Remove the back cover.
2. Remove the stylus to reveal the RESET button that is located at the bottom of the stylus compartment.
3. Use the stylus tip to press the RESET button.
Your phone restarts and displays the Home screen.
4. Replace the back cover and insert the stylus back into its compartment.
Oct 11, 2013 | Cell Phones
Resetting service indicator for 2005 vz sv6
hold the bottom two buttons and key on
when it beeps release them
press and hold the top right button until it resets.
there are lots of VZ V6 cars with the instruments incorrectly programmed causing the 10k reminder, take it to the dealer to get the instrument cluster re-programmed.
Apr 09, 2012 | Cars & Trucks
Have just got a morphyrichards 48323 when it was turned on for the first time it went into program 1 and i was unable to select program 13 as sugested in instructions can i abort this or do i need to let...
Press and hold-in the start button (bottom one) for 10 seconds. This will abort the program that's been started and reset the machine. This isn't mentioned in the manual.
Jul 09, 2011 | Kitchen Appliances - Others
Touch screen not working. mobile getting automatically restarted time to time.
It needs a reset.
This can be useful when your device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after theinstallation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
Hard reset
You can also perform a hard reset (also known as a full reset). A hard reset should be performed only if a normal reset does not solve a system problem. After a hard reset, the device is restored to its default settings - the way it was when you first purchased it and turned it on. Any programs you installed, data you entered, and settings you customized on your device will be lost.
To perform a hard reset
  1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button at the bottom of your device.
  2. Release the stylus, but continue pressing the TALK and END buttons until you see the following message on the screen:This operation will delete all your personal data, and reset all settings to manufacturer default. Press Action to restore manufacturer default, or press other keys to cancel.
  3. Release the TALK and END buttons, and then press ENTER on your device.
Aug 03, 2010 | HTC Touch P3450 Smartphone
When add a border to a page the bottom is cut off when i print the page. how do i reset the size of the border so it will fit on the page?
Is this in a specific program? Changing sizes on a border can definately vary from program to program.
Apr 02, 2010 | Computers & Internet
Phone is stuck on setup
If it is stuck or frozen:
Do a Soft reset
Or:
Do a Hard Reset
(THIS WILL REMOVE ALL APPS BUT NOT YOUR PICS AND MUSIC!!)
  • Slide open keyboard
  • Press Alt and L at the same time you will get a screen with some options listed
  • Press Alt and W at the same time to wipe device to factory reset
  • Once it is finished press home and back key at the same time
  • Remove the battery
  • Reinsert the battery
This will wipe your device to factory reset. You will need to log in to your gmail account like you initially did.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 16, 2009 | HTC G1
I downloaded a bunch of ringtones and a few wallpapers to my phone. Today the screen went out on me. I can't see the screen to delete the stuff out or to reset it. What do i do
Occasionally you may need to reset your Pocket PC Phone. A normal (or soft) reset of your device clears all active program memory and shuts down all active programs. This can be useful when the device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
To perform a soft reset:
o Use the stylus to lightly press and hold the RESET button on the bottom of your device. The device restarts, and then displays the Today screen.
Warning! Always turn off your device before performing a soft reset or installing/replacing the battery.
You can also perform a hard reset (also known as a full reset). A hard reset should be performed only if a normal reset does not solve a system problem. After a hard reset, the device is restored to its default settings-the way it was when you first purchased it and turned it on. Any programs you installed, data you entered, and settings you customized on the device will be lost. Only Windows Mobile software and other pre-installed programs will remain
To perform a hard reset:
  1. Press and hold both soft keys on the device. Keep these keys pressed, and at the same time, use the stylus to lightly press and hold the RESET button on the bottom of your device.
  2. Release the stylus but keep the soft keys pressed when you see the following message on your device screen. "Do you want to erase all user data and restore to manufacture default?" will appear.
  3. Slide open the hardware keyboard, and press R to restore to factory default or press X to exit the hard reset process.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Mar 03, 2009 | UTStarcom Blitz Cell Phone
Dishwashers Logo
Top Hoover Dishwashers Experts
Owen Barnes
jnissen
Level 1 Expert
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
