Question about Peg Perego Elegante Stroller
Seat belt I lost 5-point estrant belt with adjustable shoulder straps.Where can I buy it?
They are always coming up on ebay!
Posted on Oct 20, 2007
My 2 year old can get out of bugaboo even though she is strapped in? Is there extra straps or a harness for bugaboo
The Bugaboo's like 99% of all strollers have a 5 point harness. Two shoulder straps Two Lap straps and a center strap with the main body of the buckles. 2 year olds become little Houdini's pulling the shoulder straps off in both strollers and car seats. There are small buckle units you can buy that lock the two shoulder straps at chest height these are excellent at keeping kids in their place. Ask any nursery supply shop they should have them.
Oct 10, 2011 | Bugaboo Baby Gear
Need to remove the cover from a britax eclipse si..how
Press and hold down the harness release button. With your other hand below the chest pads, pull the shoulder straps forward as far as possible. With the Eclipse Si fully reclined, open the seat-belt guard at the back of the shell. Pull the yoke out from behind the seat and unhook both shoulder straps. Pull the cover from the top of the seat so that you can see the slots in the seat shell. Pull each shoulder strap and chest pad strap forward and towards the centre of the shell, easing the metal tab and straps through the slot. Then thread them through to the front of the cover. Unfasten the buckle and remove the comfort pad. Gently pull the cover off the seat, easing the shoulder straps, chest pads, harness buckle and adjuster strap through the slots in the cover.
By Geraldine Thorne
Feb 24, 2011 | Britax Eclipse Si - Chantilly
How can pull adjustment belt
The shoulder straps feedthrough a loop in the adjustment belt so when you pull on the belt it tightens the straps. When you say it came out, if it has come out completely then you will need to remove the car seat and locate where it connects to the shoulder straps before feeding it back through the hole again
Aug 15, 2009 | Maxi-Cosi Baby Gear
Passenger side shoulder strap doesn't tension properly on 88Vette
have you checked the tension when the brakes are being applied some of the newer vehicle seat belts don't tighten until you step on the brakes
Jul 15, 2009 | 1984 Chevrolet Corvette
Car seat adjustment for britax eclipse
Tilt seat back and slacken straps fully. Follow each shoulder strap through back of seat and down towards lower back of seat. There you will find (maybe hiding under a plastic cover) a metal bracket that retains the straps. You can slide the straps out of this, pull out and thread back through at a higher point.
The actual tension adjust ment is usually a metal clip that you push or pull which is located in the centre/ front are of the seat, or front/centre, underneath where the child's feet hang.
Apr 05, 2009 | Britax Eclipse Si - Paris Convertible Car...
Evenflo Discovery 5- Pink and green
you need to take the seat to the dealer for safty reasons
Mar 31, 2008 | Evenflo Discovery - Midland Blue
Can't remove carseat cover
There is a trick to this. All the straps are kinda connected together. The main harness is one piece, a clever clip on each of the lap section. (one on each side) needs to be removed to allow the belt to slide through the seat and cover openings. Once here the strap needs to go through the actual seatbelt buckle. Once the buckles are off you can pull the harness through the shoulder opening. The note to take here is that the harness runs through a loop on the adjuster belt (a narrower belt that runs from the back of the chair under the it to and through the adjusting fastener) Once through the loop you can pull the main harness strap free from the chair. Now the next part, depress the release clip of the adjuster and with the other hand pull this belt free from adjuster. It may require a bit of two handed work as belt nears the end. You should now have a wide belt, a narrow belt, 2x clips and 2x harness buckles. All you need to do now is remove the adjuster which usually requires the manipulation of a metal 'B' buckle which is sewn into the loop to be twisted sideways to allow it to pass through the opening. You are home free now. The cover should be elasticated around the edging and easily removed for washing.(you can also put the straps in too) Now is also a good time to just give the actual seat a good clean too. Refitting is reversal of removal. However REMEMBER and NOTE the way clips,buckles and which openings the straps went through when removing. There are usually a couple. Mark the items with a marker if you think you'll forget. On refitting you might want to put it to the next one up. (as a child grows ie. the shoulder straps should be above the shoulders when the child is seated, equally important is they must be the same on both sides.) I think there might be a couple of slots for the adjuster strap. You might want to move that one out too. Have your child seated in the chair before you start the reassembly and mark out the openings the staps need to pass through which would be most comfortable for the him/her. Good Luck.
May 29, 2007 | Evenflo Victory 5 Comfort Touch
Cosco 5-point omega carseat
ok I had such a hard time with this, i looked on the internet for hours and found NOTHING!! haha so i went to babies r us and checked out a similar one so here it is.
first the strap goes on the bottom, pull them even and the add the buckle, plastic buckle thing, and the other thing soft thing. then put the strap through the back of the seat (you should have two ends) not the must go OVER the adjusts! now take the metal piece that adjust the length and pull it long enough for it to reach the two straps and hook them up!! haha if this isnt good enough go to a store that carries the alpha omega elite car seats and check it out! GOOD LUCK!!
May 10, 2007 | Cosco Alpha Omega Elite 5-Point 22-155
Peg Perego Elegante Stroller Logo
132 people viewed this question
Top Peg Perego Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Are you a Peg Perego Baby Gear Expert? Answer questions, earn points and help others
