Question about HP z545-b Digital Entertainment Center PC Desktop
Does z545 support zenith dtt 901 - HP z545-b Digital Entertainment Center PC Desktop
What is the code of zenith converter box to program with my universal control remote?
If the remote is universal, you should be able to perform a code search to find something that work with your Zenith converter. If you search through all codes stored in the remote without success, you may have to try another universal remote. Some of the newer RCA universal remotes specifically control converters and other devices.
Feb 25, 2015 | Zenith Televison & Video
MY ZENITH MOD DTT901 DIGITAL CONVERTER ONLY PICKS UP TWO SPANISH STATIONS, 39-1 & 2. NO LOCAL NETS. I AM USING RABBIT EARS. WHAT'S WRONG?
Do you have digital tv that pick up local channels on rabbit ears? If you do, something in the DTT 901 menu is set wrong.
Jun 30, 2011 | Zenith Analog to Digital Audio Converter
Hello , i have zenith Dtt 901 converter box, it was working fine for 1 year just now i cant change channel, it moves fast, volume it goes up by it self, acting like crezy, what cuz like this? i was...
What I would do: I would make sure the remote has new batteries, then I would bring up the DTT 901 menu and go through it as if you were programming it for the first time. Mine was going off by itself after an hour. Turned out it had changed the auto off feature from off, to one hour. I reset it to off and it is working fine. Maybe an electric spike has fouled the menu settings. Also very important to have surge suppressors on all electronic products.
Mar 14, 2011 | Zenith Analog to Digital Audio Converter
We have a converter box. model number DTT901. we cannot find the remote that goes with it. are we able to manually scan for available channels? or is there an universal remote that we can buy that will...
I bought two extra remotes for my dtt 901. I can't remember where i got it, so google dtt 901 remote. Someone sells them. If you see any new dtt 901 boxes, let me know as one of mine just crapped out.
Jan 12, 2011 | Zenith Analog to Digital Audio Converter
I have a DTT 901 converter. I am trying to program a sony RM V302 universal remote to the DTT 901. How do I find the remote code or can it be done. There is no reference to the DTT 901 at sony esupport...
If the remote is older than the converter, it will probably not have a code set for it. This is a common problem since the code sets programmed into any remote are generally already somewhat 'behind the curve' and contain only data that applies to devices which have been on the market for 6-12 months. Unfortunately, no two manufacturers utilize even a basic menu of commands and even have different codes sets within their own product lines.
You might try the remote maker's website to see if updates are available or even possible.
Aug 12, 2010 | Zenith DBZN-311 Remote Control
Need the code zenith dtt 901
What code, I do not understand your problem. Please go into more detail. I have two Zenith DTT 901 converter boxes, each is on a 15" Sony TV. They work perfectly after I corrected a wrong setting on the menu.
Jun 17, 2010 | Zenith Analog to Digital Audio Converter
Tv on/off codes for hitachi when used with a zenith converter box dtt 9901. Can't use zenith remote to turn tv off and on. I followed manual instructions, didn't work.
You can download the entire manual for the Zenith DTT 901 from the web free. Google it, when you download it, it should have the codes you want.
Feb 20, 2010 | Zenith Analog to Digital Audio Converter
Zenith DTT 901 box codes
I found that these websites should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
Jul 09, 2009 | Logitech Harmony 550 Remote Control
There's no code for a Zenith DTT 901 to an RCA universal remote?
Hi.
Try this RCA code for Zenith -> 001
Regards...
/Tech5508
Feb 16, 2009 | Zenith DBZN-311 Remote Control
Is the LG DTT 901 the same as the Zenith DTT 901
I don't think there's an actual LG DTT 901. They make the digital converter boxes for Zenith (DTT 901) and Insignia (NS-DXA1-APT). Look at this chart:
http://en.wikipedia.org/wiki/Comparison_of_CECB_units
Jan 09, 2009 | Logitech Harmony 550 Remote Control
HP z545-b Digital Entertainment Center PC Desktop Logo
14 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
