In order to connect an AV receiver to a TV using component cables (Red & White) you will need to connect the component cables to an available AUDIO "OUTPUT" on the TV (red to red and white to white). Then the other end of this same cable will be connected to an available AUDIO "INPUT" on the AV receiver. The TV (via the menu or setup button) may have to be set to where the audio signal is output to a home theater and not to the TV speakers. Once connected, the AV receiver should then be set to the Audio input used in order to listen to what the TV is showing on screen.
