Question about GE GTWP1000MWW Washer
Will agitate instead of fill
When turning on the washer it will start to agitate rather than fill. it will agitate through all cycles
    Master:
  • GE Master
  • 676 Answers
The pressure switch it broken of the pressure switch is clogged. Please contact me so I can help you.
Posted on Feb 05, 2014
dididsaythat
  • 291 Answers
SOURCE: Washer agitates, but makes horrible grinding noise. Spins okay.
thanks for posting problem solve :0)
Posted on Sep 03, 2007
SOURCE: My washer fills , sits, does not agitate, empties and spins.
I had the same problem. Take the agitator off by pulling on it extremely hard - use allen wrenches in the slots on the sides to help. This exposes the "air bell coupler" - take the 7/16" bolt out and slide it off. Chances are the spline is stripped out inside. The part is 5 bucks online
Posted on Feb 02, 2009
jumptrout51
  • 3361 Answers
SOURCE: will fill and drain wont agitate or spin
Replace the lid switch.
Posted on Mar 11, 2009
mgprice
  • 744 Answers
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Posted on Jul 19, 2009
  • 410 Answers
SOURCE: GE washer model WJRR4170E1WW won't spin or agitate
.I am not a repair professional. I am a 78 year old man
who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Dec 02, 2009
My washer is starting the cycle on agitation not filling completely and on last spin cycle it starts to fill with water.
I found what seems to be an easy fix thatt solved the problem with my Maytag Centential washer that stated agitating before it filled with water. After opening the control panel and tilting it back, just pull the clear plastic hose that attaches to the cycle and leveling switch. Blow into the hose and you will probably feel water that's caught in the hose blow out the other end. Reattach the hose to the cycle and leveling switch. Now test it by starting a cycle and hopefully it works for you like it did for me. If you know how to open the control panel, this fix takes about 2 to 3 minutes start to finish. I feel bad for those people that have mentioned having repairmen replace parts that may know actually be at fault. I doesn't appear to be a bad switch, but instead a poor design the sometimes doesn't clear water from the hose causing the leveling sensor to think water is in the tub. This has now happened twice in the three years I had this washer. I hope this fix works for you if you too have premature agitation for the MVWC6ESWW1 washer.
Oct 23, 2013 | Washing Machines
I turned the washer on. It started agitating
sounds mor like the pressure switch is stuck closed
Oct 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Starts to agitate as soon as cover closes, will not spin
Bad timer. It has welded points making it imposiable to change anything on time. Needs replaced.
Please rate solution
Aug 28, 2009 | GE WBSR3140DW Top Load Washer
Kicking out water during wash cycle - spin instead of agitation
Try these
  1. Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  2. The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  3. Check the drain control lever
  4. Test the drain control coils
  5. Check the cam bar
pls rate my suggestion..
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
Whirlpool LXR9245EQ2 top loading washer tub won't fill
try taking the knob off and see if the nut is tight on the timer,it might if came loose
Jun 18, 2009 | Whirlpool Washing Machines
Whirlpool LXR9245EQ2 tub won't fill at beginning of cycle
HI, you have a combination issue. the Water fill level pressure switch and, the cycle selector switch are both damaged and, they should be replaced. the total cost of these switches will run you about $90.00.
We recommend the hands of a skilled service tech when repairing this type of electrical issue.
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
My machine will not fill with water.
It sounds like the switch that controls the water level is stuck ,thereby telling the controller that it is already full of water, causing it to start agitating right away.
Give the top of the console panel a good tap, this may release the switch if it is stuck.
If this does not work, then possibly the pressure hose is blocked that controls the switch.
Plz rate my solution.
Thanks.
Jan 02, 2009 | GE WBSR3140DW Top Load Washer
GE GTWP1000MWW Washer Logo
67 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
