Question about Emerson NR303TT CD Shelf System
I have an Emerson Record player NR305TT or the NR303TH....not exactly sure. Anyways, while trying to take off the needle to replace it, there are four wires that disconnected and now, I cant lift the arm high enough, to get those wires back into their places and the needle back on. I need someone to tell me how to lift the arm higher than the inch it goes. Thank you
  • Sue Bee
    Sue Bee Jan 06, 2014
    Does ANYONE know of an answer to this??? How do I lift the Needle Arm HIGHER so I can attach the wires and the needle??
How do I adjust the pitch / rotation speed for the turntable of my Emerson NR305TT ?
If the pitch is adjustable then there will be a little round knob to adjust it near the pivot of the turntable tonearm. If not the pitch is not adjustable.
Jun 23, 2016 | Emerson Nr305tt Heritage Home Audio System...
Unable to find repair parts for emerson nr305tt stereo
As the unit is obsolete, the repair could easily cost more than the unit's worth. Consider buying a used one off Ebay (currently there are 9 units available. One going as low as $16 + shipping.)
Apr 15, 2014 | Audio Players & Recorders
Idler Wheel on Record Player
That old Emerson turntable is a relic from another era. It is unlikely that you can find replacement parts.
Dec 27, 2013 | Emerson Audio Players & Recorders
E190246 Transformer Power ? Secondary Voltage ?
The transformer that i had. PN: E190246 Mfr: HF-4822L2TN (single in/output) (ie... two wires in and two wires out)
(Hang Fung Eletronic Ltd.) has a 42.2 vpk >15watts
(power supply for an Emerson 4 in one Entertainment system
(record, CD, cassett, radio)
Emerson Model: NR305TT 19watt
Found info here http://www.olilio.com/file/detail/FQGS2.E190246.html
I hope this helps somebody..
wildhoss109
Apr 25, 2011 | Teac DC-D2831 CD Shelf System
Power transformer appears bad. What is the ac voltage out of the transformer?
Check the part number on the transformer: the link at the bottom may help it if it is listed there..The transformer that i had. PN: E190246 Mfr: HF-4822L2TN (single in/output) (ie... two wires in and two wires out)
wildhoss109
Jan 15, 2011 | Emerson NR303TT CD Shelf System
Putting a needle in my nr303tt
the needle should slide on and off. you should consult your owners manual or if you do not have one, you can download and print one from the emerson web site.
Replacment needles can be purchaced from the only authorized distributor of emerson parts(Fox International LTD. , Inc.) (800) 321-6993. Don't forget to provide your model number.
Mar 06, 2009 | Emerson NR303TT CD Shelf System
Emerson NR305TT - Replacement Turntable Needles
I have the same model. Though I haven't replaced the needle yet, I was able to remove the broken one. You'll see that the arm has a red plastic attachment. It houses the needle in a very thin strip of something like electrician's tape. There is a very small separation on the front (end of the arm facing you) of the tone arm, where the arm (black plastic) and needle "cartridge" (red plastic) come together. I used a metal nail file and pried them apart very gently. At this point the red plastic "cartridge" with the broken needle was hanging but still connected on either side. The red plastic "cartridge" is made with tiny plastic 'bumps' that pop into indentations built into the black plastic of the arm. Again, using my metal nail file, I simply held the arm and pried the red plastic "cartridge" away from one side. It popped off the other immediately and fell away from the arm. Voila!
Hope this helps!
May 29, 2007 | Emerson NR305TT CD Shelf System
My Emerson NR305TT will not produce sound. Turn table works, CD Player works, FM Tuner Works, everything works except no sound comes from the unit. The on switch and volume seem to work as I hear a faint...
You have one of 3 problems:1) bad solder joints in the amplifier or preamp section 2)defective output transistors/ICs in the power amp or 3)missing or incorrect voltages to the amp section. If the unit has a headphone jack plug in a headset. If you have sound then everything is OK thru the preamp section and your problem is in the power amp. Any competent repair shop should be able to solve this one easily.
Jun 19, 2006 | Emerson NR305TT CD Shelf System
Emerson NR303TT CD Shelf System Logo
51 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
