Question about GE 27998GE5 Cordless Phone
Needs a new battery what part No?
Needs a new Battery What part no.?
Kindle Reader 5th generation. The screen reads :Needs Repair after I changed the battery.
did you buy an original battery or a cheap copy battery. as some cheap batteries don't have the info of the battery, and the kindle uses this to state the batteries voltage and its model number. if this does not have a info on the battery it thinks there is no battery installed..... also have you tried removing the new battery and checked the battery conditions on the board and the battery as the board can become damaged removing the old battery if not done properly
Jan 26, 2017 | Tablets & eReaders
Vupoint dv-dv1-vp camcorder needs a new battery
Buy a "np-60" battery on ebay or other store. Some will come with a charger.
You can charge the battery via the usb cable from any working usb port.
Mar 19, 2008 | VuPoint DV-DV1-VP Camcorder
Needs new battery and will not adjust to new time
If it needs a new battery, replace it! With a new battery this clock should set it's own time. If it doesn't, there is a problem with the circuit and the clock will either need to be replaced or repaired.
Feb 17, 2014 | La Crosse Radio Controlled Atomic Clock
Second hand moving in 4 second increments instead of 1 second clicks. Does this mean it needs service or just a new battery?
This means it needs a new battery. But if your watch is about 5 years old it is best to have it serviced. The oils in the movement will be drying out and this causes the gear train to require more power from the battery to make it move. By drawing more power from the battery, the battery will not last as long. This shortening of the battery life continues until the watch is serviced or eventually a new battery will not get the watch to run.
All watches require regular service to stay working properly.
Hope this helps,
Ken
www.YellowStoneWatch.com
Apr 10, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
2004 bmw 545i dead battery had dealer install new battery now i have 2nd gear jerking with my autotransmission
LMAO take it back to the dealer and tell him to reset the ECM since he was stupid enough to onhook the battery and not reset it!
Jan 13, 2010 | 2004 BMW 5 Series
98 olds intrigue needs new battery. How do you
The red plastic cover should just pop off, then you will see the head of the terminal bolt. you'll need to remove the braket holding the battery in place, just remember to replace it to hold the new battery still.
Sep 26, 2009 | 1998 Oldsmobile Intrigue
I have a Motorola BR50 that needs a new battery.
- gohh buy a new battery and put it on a prepaid account and or you might possibly need a new sim card .
Sep 08, 2009 | Cell Phones
New ds lite will not save initial settings
Either the battery has stopped functioning properly and needs replacing, or one of the battery terminal connecters has become loose and needs to be replaced with a new battery terminal (as the battery acts as a lithium battery found in a pc to save the bios settings), but they are quite difficult to desolder and reapply, best bet is to probably get another mobo. Touch screen ribbon cable could have worked loose and needs tweaking or the connector is faulty and again needs to be replaced.
Sep 29, 2008 | Nintendo DS Lite Console
GE 27998GE5 Cordless Phone Logo
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
