Question about Sharp Aquos LC65E77UM 65 in. LCD HDTV
Screen is yellow - Sharp Aquos LC65E77UM 65 in. LCD HDTV
Our n64 gives us a yellow screen when it's turned on
Well a yellow screen means that the capacitors have something wrong with them then. A capacitor issue.
Nov 24, 2012 | Nintendo 64 Console
Shaking yellow screen
Well a yellow screen means that you have a bad capacitor inside of the console.
Apr 13, 2012 | Nintendo NES Console
Yellow edge to preview screen
hello. you may be involved in a recall. please read this http://www.nikonusa.com/Service-And-Support/Service-Advisories/COOLPIX-Service-Advisory.page
please rate my answer as very helpful thank you. joe
Feb 15, 2010 | Nikon Coolpix S203 Digital Camera
Hitachi rear projection LCD with yellow blobs on screen
I have the same tv and the same problem, but my yellow is a cloud around the outside of the screen. My tv was recently moved, and a repair shop told me that sometimes in a move these tvs light engine takes a shock and causes a yellow "band" on the screen. I am hearing that these light engines are not cheap either. Hope this helps you.
Dec 01, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
Yellow discoloration on screen
the screen is yellow green color all the we have had it worked on once already does anyoblemne have any comments on how to solve this problems?
Jan 27, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi projector model CP X260 projects yellow spot on screen
This is probably the polarizing filter. It will need to be replaced. It should not cost very much to fix.
Jan 07, 2009 | Office Equipment & Supplies
Yellow corners on 56" RCA Rear Projection TV
possibly cleaning of the lens and the mirror might improve the picture. it could be what is termed a glycol or fliuid issue. dirty glycol will cause this yellow halo effect. the glycol came be changed a rather expensive and evovled repair i think
Jan 15, 2008 | RCA P46810LV 46" Rear Projection...
YELLOW SCREEN
hi there, check your video cable, most of it has a broken cable. ty
Dec 26, 2007 | Balance CM2015 15" LCD Monitor
Yellow screen on tv
lots of times when you go and buy your tv's for example like big screen... usually it will tell you that you shouldn't play like play station and things like that on them and i don't know why...
Dec 05, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Sharp Aquos LC65E77UM 65 in. LCD HDTV Logo
18 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
