Question about LG Cell Phones
How to insert sd card - LG Cell Phones
I WOULD LIKE TO HAVE A MANUAL FOR INSTRUCTIONS ON HOW TO INSERT MY MICRO SD CARD INTO MY COMPUTER AND WHAT TO DO WHEN I INSERT THE MICRO SD CARD
You'll need an adapter to convert the Micro SD card into a normal size SD card, slot the Micro SD into the SD card adapter and then plug that into the computer.
Most computers then pop up a box to tell you that you've plugged something in, so you can then browse what is on the card.
Double clicking on the items on the card will then enable you to view the images/items.
Aug 16, 2016 | Cell Phones
Hello Why ist that my zte v795l model phone ask
try changing lower capacity sd card. or maybe the sd card insertion is inverted?
Oct 15, 2014 | ZTE Cell Phones
Camera says insert an sd card when I already have one. will not let me take pictures
maybe the problem is in your SD card, try to used another SD card. and check if it works.
Feb 14, 2014 | mid M9100 9" Dual Camera Android 4.0 ICSOS...
Micro sd card too big for garmin gps nuvi 1450
A micro SD card is the correct memory card for the 14xx series. A 2 GB should be just fine. Some units can not handle a large memory SD card. This has nothing to do with the physical size however.
Are you sure it isn't a micro SD card that is inserted into a standard SD card adapter? A standard SD card is much larger and will not fit into the 14xx series. Look at the end of the SD card that does not have the gold pins and see if there is a ridge where the micro SD card may be inserted into the larger standard SD adapter. Using a fingernail, you can slide the micro SD card out from the SD card adapter. Also, the micro SD card will only insert one way. Try flipping it over and inserting it again, always with the gold pins facing the Nuvi.
Apr 06, 2013 | Garmin nuvi GPS
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
When i insert sd card it say not supported card
Try formatting the SD card using your computer. Insert the SD card in your computer. Open My Computer, find your SD card drive, right click on it and select Format. Choose FAT for the filesystem and continue with the format. When the format is complete, insert the card into your DVD Camcorder and try again.
Feb 22, 2011 | Samsung SC-DX103 DVD Camcorder
My Fuji digital camera model Finepix Z20 is showing a protected card message when I insert both my old SD card and my new SD card. My old SD card was working fine yesterday but now it says protected c
Good day,
This is a common problem that many people experience with their SD Cards.
It is normally an easy fix and you can follow a method that I posted on my tips here:
http://www.fixya.com/support/r7042428-sd_card_write_protect
Please feel free to let me know if this was helpful!
Regards
May 06, 2009 | Fuji Finepix Z20fd Digital Camera
Saying Insert SD Card When Its Inserted
well i had the same problem so i took it to tmobile and the guy on the register inserted a new SD card and he said that my old SD card was ful. so i ask him how can i clear it out and he showed me this lil usb SD card reader that they sell at the store and it was 9.99. but other then that basiclly it means that your SD card us full and you just hook it up to the usb SD card reader and plug it to any computer and go back and clean your files and re-use it again. thats about it. hope that help! : )
Apr 23, 2009 | HTC G1 Smartphone
Can't detect SD card
Try removeing your sd card. start your tt and after it has booted then insert the sd card.
Hope this helps
Nov 21, 2008 | Tomtom ONE GPS Receiver
Can not detect sd card
Make sure your card is NOT an SDHC. the HX470x only reads standard SD cards. The largest that I have found is 4GB SD (not SDHC)
Oct 07, 2007 | HP iPAQ HX4700 Pocket PC
Cell Phones Logo
467 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
